Question about Panasonic KX-TG4000B-R Base Only 4-Line 2.4GHz Corded Phone works w/
Panasonic KX-TG4000B answering machine just stopped working
The setting are all fine. In past, we used auto answer. When ansng mach stopped working, we made recorded answer. Still won't work
SOURCE: Panasonic phone KX-TG2740: instructions
I downloaded the instruction manual, based on someone else's solution to a different question about the same product.
Posted on Dec 17, 2008
  • 3 Answers
SOURCE: Panasonic kx-fm386 problem
I NEED THE CD ROM OR DRIVER FOR THIS PRINTER PANAFAX UF-490 OR PANASONIC UF-490
Posted on Apr 12, 2009
cnavarro
  • 2460 Answers
SOURCE: How do I put the answering machine on my Panasonic KX-T7431?
For both of you, the answer isn't easy....unless it's already set up in the sytsem and you just have to dial the magic number :-)
Depending on how it was installed, the Pana TD system has either automatic or manual switching to DAY/NIGHT mode. If your NIGHT program is set up to send calls to voice mail, you can just put the system in nights by dialing 781 on the intercom, and I think in a TD you can do that from any phone. 780 returns it to days. IIRC the * button on a idle display phone will tell you what mode the system is in, as well as when you dial the 78x codes, it will beep once if it changes or twice if it was already in that mode.
If none of this works, or you already have Auto D/N switching set up and it doesn't or never worked, it's going to require some system programming. Your friendly Pana installer will be happy to do that for you.
Carl
Posted on May 14, 2009
martyshaw152
  • 157 Answers
SOURCE: how do i record a answering message on my panasonic answering m/c
Hello jmkraus,
To record a greeting message on the Panasonic Panasonic KXTG1855.
(2 minutes and 30 seconds max.):
1 Press [OK]
2 Press up/down [^]/[V]: 'Answer System' : [>]
3 Press up/down [^]/[V]: 'Record Greeting' : [>]
Hold the handset about 8 inches away and speak clearly into the microphone.
4 Press [OK] to stop recording.
5 Press [OFF]
Here's the Panasonic KXTG1855 manual download link:
http://phone.manualsonline.com/manuals/mfg/panasonic/kxtg1855.html
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Posted on Feb 06, 2010
support491
  • 91 Answers
SOURCE: How to set up Panasonic Answering Machine
Recording your greeting message You can record your own greeting message (2 minutes max.). 1 {GREETING REC} 2 Within 10 seconds, press {GREETING REC} again. 3 After the base unit beeps, speak clearly about 20 cm away from the MIC. 4 Press {?} (STOP) to stop recording.
Playing back the greeting message Press {GREETING CHECK}.
You can also operate the answering system by pressing dial keys on the handset
Key Operation {^} or {V} Adjust the receiver/speaker volume {1} or {<} Repeat message (during playback)*1 {2} or {>} Skip message (during playback) {4} Play new messages {5} Play all messages {8} Turn answering system on {9} Stop playback*2
Posted on Oct 17, 2010
What is the code 43 in a panasonic KX-FL511
Your error 43 refers to the fact that the fax you are calling does not answer. Talk to them and ask if their fax is set to "Auto Receive". its probably not.
Dec 01, 2016 | Panasonic KX-FL511 Plain Paper Laser Fax
How to continue using device as answering machine but route fax to new HP all in one
hook the answering machine after the fax and set the fax to answer after 4 rings and the machine after 5.
This option should be somewhere within the menu of the HP
Let me know if you can't find it
May 22, 2008 | Panasonic KX-FPG391 Plain Paper Thermal...
Manuel for Panasonic phone KX-TG8521E/8522
Hi Mrs D, The link below is a Free 60 page operating instruction manual for a panasonic phone Model No. KX-TG8521E / KX-TG8522E / KX-TG8523E / KX-TG8524E, Take care....... CHEERS..
http://download.pfrnco.com/product/catalog/cordlessphone/KX-TG8521.pdf
Apr 29, 2016 | Panasonic Kx-Tg8522eb Dect Twin Digital...
How do I leave a message for my answering machine
Ask the service provider
Panasonic KX-TG6531B Digital DECT 6.0 1X Handsets Dual
www.fixya.com/.../p3148769-panasonic_kx_tg6531b_digital_dect_6_0...
Recent Panasonic KX-TG6531B Digital DECT 6.0 1X Handsets Dual Voltage Cordless Phones Integrated Answering Machine 110-220 Volts questions, problems & answers. ... Model KX-TG4021 - How do I put in a new answering message? ... Why won't my answering machine, Panasonic Easa-Phone KX-T1460 allow the ...
change amount rings panasonic kx tg7643 Answering ...
Jan 12, 2016 | Panasonic KX-TG6531B Digital DECT 6.0 1X...
Our Panasonic KX-T7630 phone system does not have voice mail built in. What sort of answer machine should I purchase to use with it?
Any digital answering machine will work just fine for you. These days you won't be able to find any of them made with tapes. You could also check with your phone company provider about voicemail service.
Apr 21, 2011 | Panasonic KX-T7630 Corded Phone
We have a panasonic kx-fm 131 . when i leave the office itdoes not take automatic fax
Panasonic KX-FM131 has Auto answer button at the top control pannel, which enables/ disables FAX auto Answer
Press the button marked in the picture above and the fax will automatically answer the calls in your absence.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Mar 02, 2011 | Panasonic KX-FM131 Fax
Answer machine
Panasonic KX7633 is a Key telephone set, it doesnot have answering machine function. whereas you may divert your calls toan analog extn.by call forwarding.
Jul 06, 2009 | Panasonic KX-T7633 Corded Phone
Phone keeps turning on the answering machine all by itself.
figure out how many times it takes for your phones answering machine to automatically turn on, then call your phone company and have them limit the number of times your phone rings. like say at 14 rings if it auto answers at 15 rings.
Jan 16, 2009 | Panasonic KX-TG2631W Cordless Phone
I Need Help
hi sir
go to the settings>
advanced settings>
answer machine > enable.
it work's thank u. sir
Sep 03, 2008 | Panasonic KX-T7630 Corded Phone
Have one phone line;would like to use phone attached to machine,to receive&call out &fax with out use of answer machine
You can shut off the answering machine this way....press these buttons...
[ MENU ]
[ # ] [ 7 ] [ 7 ]
[ +] [ - ] { FAX ONLY}
[ SET ]
[ MENU ]
You're done now...the answering machine will not answer. If you want to stop the fax machine from answering...press [Auto Answer] off.
Good luck...and I hope this is helpfull!!
Jan 24, 2008 | Panasonic KX-FPG377 Plain Paper Thermal...
Panasonic KX-TG4000B-R Base Only 4-Line 2.4GHz Corded Phone works w/ Logo
26 people viewed this question
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
