Question about Dean Edge 4 Bass Guitar
My red wire from battery became un soldered where dose it go
    Sergeant:
  • 242 Answers
It should be easy to identify because of the solder where it was connected...You should notice at first glance....However the red wire jumps to another..Sometimes there are 3 to 4 red wires that all run from the main pending on the pick-ups If you have more than one there will be more than one wire...Look closely with a magnifying glass I'm sure you will see it...Follow all red wires until you see the small lump of solder where wire was broken from...Normally when this happens there are still a tiny piece of the wire stuck inside of solder...
Posted on Feb 26, 2015
Battery wire location
First you have to remove all backing plates...Wire feeds through the small hole running from battery area and attached to the volume/treble dials...then to the pickups..Everything is soldered to the switches....If you plan on removing them you will need a soldering gun and silver soldering wire...It takes a steady hand and good vision to do this....I recommend a magnifying glass and or glasses....
Mar 17, 2014 | Dean Edge 4 Bass Guitar
On my peavey pro 15 neo speakers i don't know which wire is for what. What is the black, red, blue and yellow wires for?
black and red will goto 1 speaker. and blue/yellow to the other. typically red and yellow are + and black and blue are -. the crossover board might tell you which is which where they solder to it. but i'm pretty sure the black/red goto woofer. try hooking up both to woofer and listen to it. 1 way is going to sound horribly wrong lol. that will mean you hooked up the tweeter leads to the woofer. but DO NOT HOOK UP WOOFER LEADS TO TWEETER. thats why i say to do it on woofer.
Aug 30, 2011 | Peavey PR15 400w PA Speakers
My DD7 delay wont turn on. The red indicator light will flash for a few seconds then it fades away and does nothing.
If on battery, battery is depleted. If on adapter, connection is probably bad. Often power jack is broken or has bad soldering.
Jun 02, 2011 | Roland Boss DD-7 Pedal Delay/Reverb
In middle of concert epiphone stopped, took it apart where plug goes in wire came off , but can't figure out where to solder it back, it is one wire with outside ground?
If it is a coax with a wire in the center and a shield outside, the wire will attach to the contact that touches the tip of your plug you insert. The shield will attaach to the part that touches the sleeve of you plug. inspect the jack carefully as they can be foolers. When stripping the insulation back un-braid the shield a little to be able to solder it to the jack. Use a pair of needlenose and a helper to keep soldering heat from going up the braid and melting the insulation of the internal wire. Test unit before putting cover on.
Apr 25, 2011 | Epiphone Les Paul 100 Electric Guitar
I have a Marshall channel/dfx footswitch. The jack plug has been chopped off leaving me with a red, blue and yellow wire. Can you tell me where each one is soldered to on a replacement stereo jack plug?...
NEVER trust colors... with an ohmmeter you can tell which is the common lead by testing... find the lead that has continuity to EITHER switch independently... It is PROBABLY the blue one... this will be the "sleeve" of the plug. The schematic documentation is so bad the jack wiring cannot be decipered as to which contact is the tip and the ring. HOWEVER once you find the common of the switches and connect it to the sleeve you have only two choices for the other wires so just try them.
You can also take the back off the pedal to find which color goes to BOTH the switches... connect that one to the sleeve. Try the other two wires for proper operation before final soldering.
Apr 11, 2011 | Marshall Amplification Marshall Footswitch...
I have an Ibanez Acoustic Electric 5AEQ45F. The top part of the pick up became disconnected. One wire, a white one with a female connection, became disconnected and I cannot find where to reconnect. Please...
Realize that there is a white pickup that looks like a wire that ITSELF is the pickup which goes under the bridge. It works like a capacitive mic. One end will be unconnected. This lays in the groove under the bridge.
Mar 28, 2011 | Music
Every thing came un soldered inside
Although that sounds impossible, here is the link you will need:http://www.bcrich.com/learn_controls.asp You will need some desoldering braid, a soldering iron, needle nose pliers and some thin guage solder.
Dec 19, 2010 | B.C. Rich Dark Arts Warlock Electric...
9v battery wires came loose. peavey 5 string bass
The negative battery terminal will go to a black wire and that will be soldered to one of the volume control cases. That makes the remaining wire easy. The negative terminal pole on the battery is the larger round one.
Jul 06, 2009 | Music
My zoom 505 2 distortion pedal for my guitar will not function with batteries and the ac adapter slot is loose in the back, please help
I have had this same problem with mine, since the adapter jack is loose it's probably broken loose from the circuit board inside. I had to carefully dis-assemble and re-solder the adapter jack back to the circuit board. This is un-fortunately a weak point on some of Zoom's pedals, when you or if you get someone who is good at soldering to do it for you ask them to beef the solder joints up a little to help keep it from coming loose again. I re-did mine and I've never had another problem with it.
Mar 09, 2009 | Zoom Music
Dean Edge 4 Bass Guitar Logo
65 people viewed this question
Top Dean Music Experts
Matthew Spark
Matthew Spark
Rick Moore
Rick Moore
Tom Rood
Level 1 Expert
Are you a Dean Music Expert? Answer questions, earn points and help others
