Question about Gap Digital Sport Watch
How do i work the alarm
It for some reason just started ringing
Alarm off
- Keep on pressing mode button on watch till alarm mode appears.
- to verify alarm mode check out the time alarm rings and match it with the display while selecting the mode.
- press adjust button to disable
- or press two buttons on right of watch to adjust the alarm
Mar 29, 2014 | Casio G-Shock World Time Analog Digital...
Replaced batteries in Casio Pathfinder watch. Functions work, but alarm does not sound.
there are two reasons for this while changing the battery the small coil sping that operates the alarm as fell out or you av put the back on in the wrong position
Jan 20, 2013 | Watches
I dont know how to turn the alarm off on my casio protrek triple sensor watch and it alarms each midnight!?
Scroll through the screens until you get to the alarm screen and select the barometer button to turn alarm on and off.do not go into edit mode.
Sep 03, 2011 | Casio Protrek Triple Sensor Prg 110T 7VDR...
I just replaced the battery on my seiko. Watch is working fine EXCEPT the alarm will not ring. Help!
mcdevito75 here, By pressing the MODE button until you get to the alarm function and turn it to on or, set an alarm time for the alarm to go off.
Oct 11, 2010 | Seiko Coutura Chronograph Watch
How do I totally cancel the alarm to ring? Is
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals.Rate me, please.
Mar 17, 2010 | Timex Ironman 30-Lap Digital Watch - Full...
How do I enable the alarm on the Eddie Bauer world travel clock with flashlight? I can set the alarm time but I do not know how to enable it. I set it by 2 minutes ahead of the current time and waited for...
From the normal time position, press Mode and the AL function will come up which is where you set the alarm. Instead of pressing SET, press the up arrow. Each time you press the up arrow it changes function. When the alarm function is on a little bell appears above the colon in the time. The snooze has a ZZ that appears below the colon.The unique feature of this clock, is that it is the only one I have seen where the alarm works in the time zone selected. Most others, the alarm only works the home time zone, not the selected time zone. This is a huge improvement.
Dec 24, 2009 | Eddie Bauer Watches
I have a wacky wake up timex alarm clock and can't set it to correspond with daylight savings.
You press and hold down the time set button...once the time starts to flash you use the "fwd" or "rev" buttons to change the time to what you want it set to. The alarm is set the same way...just press and hold the alarm set button until the time flashes. :)
Nov 01, 2009 | Timex Watches
Can't turn off alarm
Here are the instructions to view, change alarm time and turn off alarm:
From normal time display:
Press MODE once to display stop watch.
Press MODE again to change alarm time.
Press MODE again to change time.
Press RESET once to display current alarm time.
Press and hold RESET then press START to turn on and off alarm (watch for alarm symbol on top left)
Press and hold RESET then press MODE to turn on daily alarm vs one time (watch day marker lines at the bottom)
Hope this helps.
May 05, 2009 | Watches
Nelsonic watch with no instructions
Copy and paste this link. It will take you to Bulova's service centerwhere you can download instructions for any of their watches.
http://bulova.com/service/servicecenter.aspx
If you appreciate me finding this answer for you then please rank this solution as "fixya" or at least "helpful" as what I have found for you will solve your problem. :-)
Jan 09, 2009 | Bulova Watch
Changing alarm
Here is a link for the manual for your watch. I could explain how to fix your problem but thought it would be easier with the manual and pictures. If this fixes your problem please rate. Thanks. Good luck in school! http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2747.pdf
Mar 31, 2008 | Casio AW80-7AV Wrist Watch
Gap Digital Sport Watch Logo
12 people viewed this question
Top Gap Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Gap Watch Expert? Answer questions, earn points and help others
