Question about Dean Edge 4 Bass Guitar
Battery wire location - Dean Edge 4 Bass Guitar
    Sergeant:
  • 242 Answers
First you have to remove all backing plates...Wire feeds through the small hole running from battery area and attached to the volume/treble dials...then to the pickups..Everything is soldered to the switches....If you plan on removing them you will need a soldering gun and silver soldering wire...It takes a steady hand and good vision to do this....I recommend a magnifying glass and or glasses....
Posted on Feb 26, 2015
How to set up and check the digitech qm1548 multimeter and tell me how to check a 12volt truck battery
put the black wire in the black hole , the red wire in the red hole
turn the knob( press the buttons ) to volts ad/dc adjust range to high voltage ( put the decimal point 3 places to the right on the screen
connect the black wire to the negative pole of the battery
put the red wire to the positive pole of the battery and read the dial /screen
the reading on a good battery will be 12 volts to 13.5 volts
now have some one start the engine
check the voltage while cranking-- should be no less than 10.5 volts ( anything less indicates a faulty battery)
once the engine is running increase rpms to around 2500 rpms
battery voltage should now read 14.5-14.8 volts
if it stays at 12 volts , the alternator / regulator is not working
if the running engine voltage is at 11 volts , the battery is supplying power to the electronics
Of course if you do not know how to read a multimeter or know how to follow the user instructions for the meter, what I have detailed here will not mean much , so take the vehicle to an accredited auto electrician and have a proper diagnosis done
Aug 22, 2016 | The Music
Location of battery area in the Mark 152
This is the download able owners manual, should have battery location, if not let me know, I can make a phone call and get info?
Mark 152i Downloads
Mar 09, 2015 | Music
Look, my three-way switch is messed up. I don't know how it happened, I was jamming one day and it just cut out. Now when I set the switch in the lowest setting, i get a very low volume clean
if you are using passive pick ups in the instrument. it will require a battery as a separate power source. it sounds as if that may have gone dead. you would get a response like your describing. all of a sudden things just sound weak. now the battery would be located where everything is wired up. usually in the back there's a access cover. just un screw that and pull it up. if you see a battery, replace it im sure that will take care of it. also you may want to unplug the guitar cable from the guitar input jack when not in use. this activates the the battery when plugged in. it'll save the life of the battery.- good luck!
Sep 18, 2014 | Music
We need to change battery
The battery should be located in the control cavity of the guitar. It is in the back of the bass. Usually 4 screws holding it on. Inside your 9v battery will be located. Good luck
Feb 22, 2013 | ESP LTD Surveyor-414 Electric Bass Guitar
Replacing battery in kurzweil mark 12
As per the manual it says it is located near the power switch. You will need(as per the manual instructions): a screwdriver(Phillips head), a knife, a pair of scissors, and a pair of front end wire cutters as, when shipped from the factory, the three AA batteries were taped or cable tied as a shipping precaution(to keep them from falling out). ***WARNING: MAKE 100% SURE YOU HAVE BACKED UP ALL OF YOUR SOUND PATCHES ON A FLOPPY DISK BEFORE BEGINNING THIS PROCEDURE!!! ONCE YOU START THE REPLACEMENT PROCESS, YOU HAVE ABOUT 30 SECONDS BEFORE THE BOARD LOSES ITS CHARGE AND YOUR SOUND PATCHES GET ERASED FROM THE ROM CHIP.***
Make sure you have all of the needed batteries and tools before beginning.
Hope this helps.
Nov 23, 2012 | Kurzweil Music Systems Kurzweil MARK152I...
My acative stays on even unplugged on my bass
when you say on, do you mean the battery continues to drain? If that is the case, check the battery ground wire at the jack...has it been repaired recently? Sometimes techs reconnect it to the main system ground, which continuously drains the battery whether plugged in or not. Or...sometimes the battery ground wire tab on the jack is touching shielding (if it is loose and rotates)...that would cause the same issue...
Sep 24, 2012 | Schecter Music
I put my battery inside my key board but it wont work and i dont have the wire for it but do u need the wire to make it work
The battery needs to be charged before it will work in your keyboard. Maybe, the battery is out of charge that's why your keyboard is not working.
You need the wire to turn on the keyboard and at the same time to charge the battery. If the battery is already full, you can remove the wire and the keyboard will still work until the power in the battery is drained out.
I hope this helps.
Carlo
var geo_Partner = '82910b1e-9b92-42fd-b83f-fa09a0787ae7'; var geo_isCG = true;
Mar 03, 2011 | Yamaha Full-Size Keyboard
I was jamming, getting a glorious sound as always with my carbon copy as a main feature of my sound, combined with chorus and such. I packed up my gear to go to a group new years eve jam. My buddy called...
DO NOT count on a "new" battery to be good! I always carry an inexpensive meter (about $3 from Harbor Freight) to test batteries. Try yet another battery...
A common failure however is that the wires to some of the battery clips break after having to fight with 9 volt battery clip removal that have wires... The ones without wires have a habit of not making contact at time...
Dec 31, 2010 | MXR Carbon Copy Analog Delay Pedal Guitar
9v battery wires came loose. peavey 5 string bass
The negative battery terminal will go to a black wire and that will be soldered to one of the volume control cases. That makes the remaining wire easy. The negative terminal pole on the battery is the larger round one.
Jul 06, 2009 | Music
Dean Edge 4 Bass Guitar Logo
67 people viewed this question
Top Dean Music Experts
Michial Gueffroy
Tom Rood
Level 1 Expert
rhodesworks
Are you a Dean Music Expert? Answer questions, earn points and help others
