Question about Monster Beats By Dr. Dre Solo Hd S450 Wireless Bluetooth Stereo Headset In Box
S450 headphones not charging
Hi. I just purchased the insignia digital wireless headphones for my boyfriend and the headphones won't charge properly. It says to put the on the dock station and the red light will stay on(up to 4 hours)...
If the red light is on for such a short period of time, it probably means that the headphones are charged. The red light will flash for a long time and then turn green only when you charge on the dock headphones that need charging. I suggest to try to use them without charging them and see if the headphones work.
Dec 30, 2014 | Audio Players & Recorders
Can beats s450 be connected to any soundbar?
If the soundbar is Bluetooth-enabled, yes. But I have not read or heard about a Bluetooth-enabled soundbar yet. And why would you want to connect the headphones to the soundbar ? The only situation where this would make any sense is if the soundbar were hooked up to a TV. If this is the case, your only solution is to use regular (not Bluetooth) wireless headphones, which consists of two pieces: the headphones and a transmitter that you hook up to the audio output of your TV. The transmitter piece transmits any sound coming out from your TV wirelessly to the headphones.
Sep 27, 2014 | Beats By Dr Dre - Wireless Bluetooth...
My auvio headphones show a solid red light
Charge your headphones and while they are charging press the call button and the volume up button and you problem is solved. After that just let your headphones charge.
Jun 14, 2014 | AUVIO Bluetooth Headphones
It is not charging
The battery is most likely dead, replace the device.
Oct 22, 2013 | PURSONIC S450 DELUXE PLUS Sonic toothbrush...
900MHZ CHARGING LIGHT STAYS RED AND DOES NOT GO OFF
Didyou try taking the battery out of the headphone and replacing it? This may act as a reset and allow charging. I'm assuming that these headphones are not brand new, and that you are lining up the arrow on the one side with the arrow on the charging base. This is the only way the inductive charging can occur. Good luck!
Dec 22, 2008 | Sony Camcorder/Audio/Video 900MHz Wireless...
I need the Driver for my S450
I presume you mean "Canon BJC S450 InkJet Printer". If so, go to http://www.nodevice.com/driver/S450/get24576.html.
"Today's the best day of my life...and NOW you're part of it!"
Nov 19, 2008 | Canon BJC S450 InkJet Printer
Canon S450 not responding
Try resetting the printer like this
Canon S450 Printer
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice
5. Release Power button
6: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange.
7: Press Power to set data
Jul 05, 2008 | Canon BJC S450 InkJet Printer
Sharp 36R-S450 Coax broke off Help!!
it should be alot to fix all u have to do is buy the coax connector n solder it
Oct 28, 2007 | Sharp 36R-S450 36" TV
Canon S450 printer not responding
NO BJ Cartridge Orange 6   Re-install cartridge or replace ityou probably don't have the ink cartridge installed correctly. make sure it is pushed and seated properly.
Oct 14, 2007 | Canon BJC S450 InkJet Printer
Monster Beats By Dr. Dre Solo Hd S450 Wireless Bluetooth Stereo Headset In Box Logo
175 people viewed this question
Top Monster Radio Communications Experts
eradiostore
eradiostore
Are you a Monster Radio Communication Expert? Answer questions, earn points and help others
