Question about LG 47" 47lv4400 Led Lcd Hdtv 1080p Trumotion 120hz
Vertical ghost lines
Vertical ghost line in farthest left side of tv and horizontal flickering from bottom of the tv to the top
Thin red line running from top to bottom of screen
What is this thin red line that is on my screen whenever my ...
https://answers.yahoo.com/question/index?qid...
Sep 23, 2010 - There is a very thin red line going from the top of my computer screento the bottom, ... If it's a single-pixel-wide red line from top to bottom it's a failure in ....have thin red lines running down the screen??some are thicker than ...
Thin Vertical Red Line [Solved] - Acer - Displays - Tom's Hardware
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Jul 12, 2013 - 5 posts - ‎2 authors
hi all i am having a Thin Vertical Red Line on my Acer LED moniter ... the screen is having a part fail(cable or the screen/control board it self.).
Why is there a straight vertical line going from top to bottom on ...
forums.androidcentral.com > ... > Samsung Galaxy S6 edge
Apr 15, 2015 - 7 posts - ‎4 authors
Just bought the Samsung Galaxy s6 edge yesterday. After I charged the cellphone for the first time and turned it back on there was this straight.
Jan 26, 2016 | Samsung UN60ES6100 60-inch LED TV
Red light flashing 4 times
sounds like it's toast http://community.sony.com/t5/Television-Picture-Sound/Vertical-Lines-of-death-KDL-52W4100/td-p/29582
Mar 26, 2014 | Sony KD-27FS170 27-Inch FD Trinitron WEGA...
How can i set the time? I made it with the digital clock, but i can't find out how to change the analog clock!
The analog hands and face are clean looking and manage to give the watch a classic face. It won't turn any heads, positively or negatively. The hands are rather thin and silver which makes it blend in too easily with the face. Stupidly, Casio put a vertical and horizontal silver line on the face which further causes the hands to be visually lost. The hands aren't hard to see, but because they blend they aren't easy to see either. And there is no second hand at all; but the digital portion covers that function.
The digital portion in the bottom can only display two rows of information. So it's either day/date, or time/seconds. The top row is hard to see because the face shadows over it partially. The numbers are on the small side; not for old eyes. The digital portion has all the fundamental functions: time/date, hourly chime, chrono, 3 alarms, count down, dual time, and even "data bank" which is a very crude phone/number data bank.
The LED's are the old 80's yellowish tinge type and do a very poor job of illuminating the face... but if you're in the dark, it'll do the job. The hands have glow in the dark paint on them which also helps you just barely make out the time in the dark.
There is just nothing great at all about this watch; but it does everything you REALLY need a watch to do. Couple this with the 10-year battery, 100M water resistance, and $25 price tag, and you have something that just gets the job done reliably and economically. It might be plain vanilla, but it's real and hits the spot.
Oct 31, 2012 | Watches
I have a tcm 217362 watch with a digital compass how can i set it up to show me north it currently shows cal. and when i press the top right and left button it shows err.(probably error) it is a black and...
Hi john30x,
You have to calibrate the compass.
1. Press the upper right button (switching to compass mode)
2. Press and hold upper left button. The "CALL" will appear on the display. You are in compass calibrating mode.
3. Rotate the watch horizontally (around his vertical axis) slowly, so to be sure that he point the North at least 2 times.
4. Now press the upper left button again to input the
declination (this is the angle between the magnetic and real pole). It is different for the area around the world, that you want to explore.
5. Switch between the positions of the cipher by pressing bottom left.
6. Change the cipher by pressing bottom right.
7.
Switch between the active position by pressing bottom left. Now you have to enter East or West declination
8. If you are ready press the upper left. "END" of calibration will appear on the screen
Once you calibrate and set the declination you can use the the compass by pressing upper right button. As the compass is very sensitive It is good idea to calibrate it on a field, far away of metal objects and electromagnetic fields (cables, ect.). You need to calibrate the compass each time you want to use it by different surrounding.
Remember the compass function of your watch need much more energy than the watch itself. Don`t worry to change the battery when dead. The water resistance remains good even after. Very robust and accurate device. I hope that should help.
May 15, 2011 | Watches
I can't set the time. I've looked on-line and still can't figure out the step by step instructions. They don't seem to match my watch which is a women's 1440 Sport watch with gray band.
Hi aausenhus,
You can easily change the time of your Timex watch by following the steps below.
1. With the time and date showing, press the top left button.
2. Press the right top button (this sets seconds).
3. Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm).
4. Press the bottom left button, minutes flash. Press the top right button until correct minutes.
5. Press the bottom left button, month flashes. Press the top right button until correct.
6. Press bottom left button, date flashes. Press the top right button until correct.
7. Press bottom left button, day flashes. Press right top button until correct.
8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished).
To turn off the chime and alarm: Press bottom left until in the alarm screen. Then press the top right button repeatedly until the CHIME or CH symbol is gone and/or ALARM or ALM to disappear, then press the bottom left button to go back to main time.
Hope it helps.
Thank you for using FixYa.
Apr 27, 2011 | Timex 1440 Nylon watch
My watch is stuck on military time somehow. I would like to know how to change it back to normal time. My watch is a Armitron Alarm/Chrono WR 165 sports watch. The number on the back is 45/6915. Thanks for...
Welcome to Fixya,
The Armitron WR165 is a digital watch that includes a 24-hour alarm, hourly chime, stopwatch feature, countdown timer and is water resistant up to 165 feet. With a rubber wristband and rugged style, the watch is meant for outdoor enthusiasts and athletes. The WR165 can be found online, in some sporting supply stores and in certain department or general home stores. Setting the Armitron WR165 only takes a few steps to perform properly.
1 - Push the top button on the left-hand side of the watch until the seconds flash on the display.Press the top button on the right-hand side to zero the seconds.
2 - Push the bottom button on the left-hand side of the watch until the hours flash and then the top button on the right-hand side of the watch to increase the hour on the watch display. Note that "PM" will appear on the watch display for PM times, but there is no "AM" indicator on the display.
3 - Press the bottom button on the left-hand side of the watch until the minutes flash on the display.Press the top button on the right-hand side of the watch to increase the minutes on the display.
4 - Repeat to set the month, date and weekday on the watch. Press the top button on the left-hand side of the watch to return to time mode.
5 - Press the bottom button on the left-hand side of the watch to enter the stopwatch mode. Press the top button on the right-hand side of the watch to start the timer. Press one more time to stop timing. Press the top button on the left-hand side of the watch to reset the stopwatch to zero and the bottom button on the left-hand side of the watch to return to time mode.
6 - Press the bottom button on the left-hand side of the watch twice to set the alarm. Press the top button on the left-hand side of the watch until the hours flash on the display. Press the bottom button on the left-hand side of the watch until the alarm number flashes. Press the top button on the right-hand side of the watch to choose Alarm Time 1 or Alarm Time 2. Push the bottom button on the left-hand side of the watch again until the hours flash. Push the top button on the right-hand side of the watch to choose the alarm hour, followed by the bottom button on the left-hand side of the watch to change to minutes. Press the top button on the right-hand side of the watch to advance the alarm minutes. Press the top button on the left-hand side of the watch to set the alarm time and the bottom button on the left-hand side of the watch to return to time mode.
I hope this will help you.
Thank you for usinf Fixya.
Feb 21, 2011 | Watches
How do I set the analogue hands so hat they tell
Push the lower left mode button (C) until the bottom line of the LCD is "HS". Then press either to top right (B) or bottom right (D) buttons to change the position of the hands. The mode button selection is shown on page 1 of the manual. Changing the hands is described in the Analog Timekeeping section on page 4 of the manual. The manual is currently available here: http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2735.pdf
Dec 06, 2009 | Casio WVA105HDA Wave Ceptor watch
Whre do the two vaccum lines hook up, one comes out by the intake on top and the other from the very bottom??
If u re on the kick stand of your scooter there is a vacumn line that connects the main carb and also the one near the black fuel inreacher. Mine is cut and the front hose is open. the back one id okugged. this indicates that the fuel enricher is not working. Scooter runs great, sarting is good but not great.
Apr 27, 2009 | Watches
How dp you alter the time of the hands
  1. Press the Bottom Left side button until you reach time keeping mode.
  2. Press the Bottom Left side button 6 times to reach hand setting mode.
  3. Hold down the Top Left side button until the digital time starts to flash.
  4. Press the Bottom Right side button to advance the analog time by 20 seconds; Holding the button down will advance the time faster. Pressing both of the Right side buttons will lock the time into advancing quickly without holding buttons down; this will continue until you press a button or the clock advances 12 hours.
  5. Press the Top Left side button to exit the settings screen.
  6. Press the Bottom Left side button to return to timekeeping mode.
Mar 12, 2009 | Casio Watches
Invicta Ocean Ghost Chrono Model# 2636
Did you recently have a battery changed. A lot of times on chronos when the battery is changed the battery has to be short circuited to the AC. Which is done by taking tweezers. & touching the positive part of the battery to the part of the watch marked AC. Then try to pull the crown all the way out to time setting position press the top rt button & the second should move keep moving until it lines up with zero. If you haven't had the battery changed try what I told you to do with the crown & the top right button.
Mar 13, 2008 | Invicta 2636 Ocean Ghost Chronograph Watch
LG 47" 47lv4400 Led Lcd Hdtv 1080p Trumotion 120hz Logo
20 people viewed this question
Top LG Watches Experts
Terry Hair
ray gallant
Are you a LG Watch Expert? Answer questions, earn points and help others
