Question about Dewalt Drills
Dw9116 manual i need the manual for it
18 volt charger (Dewalt)
The DW9116 is actually a 120 volt charger so it should cope with 130v AC supply, what is the supply from?
It is normal for a standard 110v supply to run at around 117V
See THIS INFO on power supplies
Jan 30, 2008 | Dewalt 7.2-18.0 Volt One Hour Charger
Dewalt charger dw9116 got wet while charging and won't charge any more
let dry completely . if any corrosion on pcb clean with contact cleaner from radio shack
Jun 14, 2010 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
My DeWalt DW9116, battery charger lead light is fl...
Brown
Brown
Silver
Gold
R21 = 0.11 Ohm at 5 percent
Now can someone help me find the schematic for this model? DW9116
ivanhovideo@gmail.com
On 3/5/12
May 21, 2010 | Dewalt 7.2-18.0 Volt One Hour Charger
Dear All, I need recommendation to change some elements in DW9116 to run by 220-230 V AC. I appreciate for support. Alik
Here is a link to a number of 220v chargers that will work for you. You can, of course, use the 110v charger with a down converter.
http://www.google.com/products?hl=en&resnum=0&q=dewalt+220v+charger&um=1&ie=UTF-8&ei=zn8SS52hCcmUtgfUpezqCg&sa=X&oi=product_result_group&ct=title&resnum=4&ved=0CCsQrQQwAw
Nov 29, 2009 | Dewalt 7.2-18.0 Volt One Hour Charger
My Dewalt 7.2-18v charger model #dw9116 is giving me a "problem powerline" indicator light. What does this mean?
It means there is too high or too low a voltage coming into the charger. Check your chord.
I had the exact same problem. After using the necessary security bit to crack mine open, I found that the large capacitor inside had come loose and needed to be re-soldered.
That fixed my charger.
Jul 16, 2009 | Dewalt Drills
Looking for schematic DW9116
Not Sure if this is the same as yours.
Jun 22, 2009 | Dewalt 7.2-18.0 Volt One Hour Charger
Where online can I download a Dewalt 9116 owner's manual?
Go to Dewaltservicenet.com and in the middle of the page at the bottom find the looking for manual box. Type in your model number and it will take you to a page click in the owners manual and download it from there it is 5 pages long. If I have helped you would you please rate my solution accordingly and thank you.
May 16, 2009 | Dewalt Drills
I require a step down plug
I'm disappointed that Dewalt does not have the full specs on their website so . . .
Check the specifications on the charger's label; they should read something like 120 VAC or Volts AC and 2.0 (or similar) amperes or just 'A' after a numerical value.
If the label does not give you an amperage value you can use the output value instead and substitute the output voltage at the high end if a range is listed.
To get the adaptor (step-down transformer) wattage, multiply the AC values such as:
120 X 2=240 watts input power.
If these AC values are not available;
Take the high end charge voltage if it is a multirange charger, and multiply those values;
One we own DW9108 (- yours is 7.2 - 18) is spec'd at 9.6 to 18 volts and 2.8 amperes:
2.8 X 18=50.4 watts.
You can see that the values do not correspond but it is a multirange device so the maximum current taken from the AC line can be ~ 2.0 amperes but this is charging a specific pack and the peak input current is only momentary so the maximum output current and voltage are the values one should use as a guide. In other words, the output wattage is closer to the value needed.
Since there are losses in any transformation (mostly heat), the required stepdown transformer must be capable of more than the indicated 50 watts.
A safe factor would be 1.5 X 50 (W) or ~ 75 watts minimum to ensure the charger receives the 120 volts it wants.
Anything that will step down your (?) 220 volts and is rated at 75 watts or more will do the job even if the Dewalt draws a little more current at your line frequency of 50Hz which it may.
Oct 09, 2008 | Dewalt 7.2-18.0 Volt One Hour Charger
No Manual?
Online Manual (PDF) For DW9116
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/630429-00,DW9116.pdf
Dewalt DW9116 Product Recall:
http://www.dewalt.com/us/articles/article.asp?ID=187
Nov 22, 2007 | Dewalt 7.2-18.0 Volt One Hour Charger
Drills Logo
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
