Question about Rosewill RX-DU101 2.5" & 3.5" USB 2.0 Docking Station
Need manual for Rosewill HDD docking station - Rosewill RX-DU101 2.5" & 3.5" USB 2.0 Docking Station
I need a driver for the Nexstar H.D.Dock,NST-D100
digitech have such a product called a usb3.0 sata hdd docking station---xc4696 available for Jaycar electronics shops ( around $50.00 aud ) there is also an adapter that fits inside the docking station to be able to use pre sata hdds as well
Aug 24, 2016 | Sata Computers & Internet
Which USB cradle works for a WDAC24300?
Okeba 2.5" 3.5" SATA IDE Hard Disk Drive HDD Dock Station Clone With USB HUB card reader - CA130 From - Rakuten.com,
or: Sisun 2.5"/3.5" IDE SATA HDD Docking Station +Card Reader Hub - From Amazon.com
Feb 12, 2015 | Western Digital AC24300-00LK 4.3gb 5400rpm...
How to install USB3.0 eSATA 2.5"/3.5" horizonatal mobile HDD Docking station?
Hi
Once you have the drive installed in the docking station you will need to install the drivers on the host PC, if your drive is not showing up in my computer, then either the drive is faulty, the docking station is faulty or the drivers have not installed correctly.
1 listen to the drive can you hear clicking noises from the drive, or is there any activity at all from the drive if not then the drive is either not sat in the holder correctly so is not getting power. or if it seated ok then the drive has gone faulty.
2. If the Docking Station is faulty return it and get it replaced
3 Remove and reinstall the drivers.
Cliff
MCP
Aug 23, 2014 | Dell Dimension Computers & Internet
What power plug do i use with unitek data hdd docking station
The Y-2041 comes with a 12V 4A power supply which is not quite as large as the typical laptop supply. It is manufactured by Ktec and the model is KSAH1200400T1M2.
Jan 19, 2014 | BestOfferBuy Unitek Y-2041 USB 2.0/eSATA...
Why would my hdd docking station driver be blocked from loading (new install) ?
it is common problem when installing unsigned driver. please select the 'install driver anyway' when got pop-up window option. Thank you.
Nov 04, 2013 | Interface 2.5 3.5 IDE SATA Multifunctional...
I have a Rosewill RX-DU100 2.5 / 3.5 Hard Drive Docking Station. The pins don't match up. Do I need some sort adapter?
What type of driver are you trying to connect?
The Rosewill RX-DU100 uses a SATA connection
You can see what a SATA connection looks like by clicking on the link below:
http://www.macgurus.com/images/SATAfaq/Seagate_vs_SATA.jpg
What is the model number of the hard drive you are trying to connect?
Jan 27, 2010 | Computers & Internet
Docking station
typically if it's a complete docking station, it uses your laptop power supply and provides power to your laptop and itself at the same time.
http://www.dell.com/downloads/global/products/latit/en/laptop_latitude_efamily_docking_accessories_brochure.pdf'
according to that brochure the dock is the E series.. and doesnt come with a manual
Dec 11, 2009 | Dell D/Dock Expansion Station Docking...
How does a USB docking station work w/ a regular docking station
the older pc probably needs a usb 2.0 port to run docking station. the manual on the docking station should tell you. you may need to install a usb 2.0 pci card in your older computer for it to work.
Mar 18, 2009 | Dell Inspiron 5160 Notebook
I have an Archos 605 WiFi. I haven't yet connected my Archos docking station to the TV and HDD. Meanwhile, I thought I would copy a programme from the HDD to a DVD, then put the DVD in the computer and...
What kind of HDD do you have, do you have any type of output on it. You stated that you haven't connected the docking station to it and the TV...? The best thing to do is to connect your Archos to the Docking station. Set the docking station up correctly, with cables coming out of the HDD (if it has some sort of output) to the station and out of the station to your TV. Once you set that up, you can use the Archos as a mini DVR or VCR. Go to the REC option on the main screen of Archos, you'll have an option for Video Recorder (tab on top). If you play any source on the HDD, then all you have to do is press the Rec option on the Archos. If you already have a file on the HDD, then try just moving it over into the Archos once you connect the Docking station to your computer via USB or just use the USB cable connected to the computer with the HDD. I use the USB preference as Windows Media Device. (found under menu/settings/system). Is is basically a HDD itself. Remember the Archos will only play certain videos without the purchase of any extra plugins.
Good Luck
Apr 14, 2008 | Archos 605 WiFi Digital Media Player
Rosewill RX-DU101 2.5" & 3.5" USB 2.0 Docking Station Logo
19 people viewed this question
Top Rosewill Computers & Internet Experts
Jim Thurston
JustBeatOnIt
Level 1 Expert
Are you a Rosewill Computer and Internet Expert? Answer questions, earn points and help others
