Question about Breville BBL600 5Speed Blender
Blender works for 2 seconds and turns off - Breville BBL600 5Speed Blender
We blender dial stopped working blades do not turn how to fix only used about 15 times
The speed control board is gone. Parts may be next to impossible to find. If the blender is not very expensive or out of warranty, it may be cheaper to get a new one.
Apr 16, 2017 | Blenders
Why won't the blender start? the on/off light keeps blinking
my Ninja blender wont turn on, power button keeps blinking red ...
https://answers.yahoo.com/question/index?qid...
Dec 11, 2011 - I know I"m not supposed to drown myself in the toilet yet the don't build in a head protector. The blinking light won't go off. It worked last night ...
Ninja Blender Red Light Is Flashing ' Appliance Repair ...
appliancerepairquestions.com/question/ninja-blender-red-light-is-flashing/
Mar 29, 2015 - My new Ninja Blender has a power button that is flashing red. ... and the top of the blender is on and secure but the light keeps blinking / flashing. ... How do I set the oven off from demo mode asked by Anonymous, 2 months ago ....Whirlpool MDU1955XTSS2 won't turn on asked by Anonymous, 4 months ...
cuisinart blender red light flashing but Questions & Answers ...
www.fixya.com > Forum > Tags
Dec 26, 2015 | Euro-Pro Ninja Nj600 1000 Watt Xl...
Blender freezes with ee as an error black & decker cyclone 18 speed digital blender
Important: This blender has an intelligent system that
automatically shuts off the appliance after 2 minutes
for speeds 1 to 18 and after 20 seconds for the PULSE
and CRUSH functions. If this occurs, the LED display
shows "EE"; unplug the unit and wait 30 seconds.
Dec 26, 2009 | Black & Decker Blenders
WHEN i PUSH ANY BUTTON TO TURN IT ON, IT WORKS FOR A FEW SECONDS THEN IT STOPS, i HAVE TO UNPLUG IT AND SHAKE IT, IT WORKS FOR ANOTHER FEW SECONDS THEN IT STOPS AGAIN. wHAT CAN i DO TO FIX IT?
Sounds like the brushes are not making good contact or you have a defective switch. Run the blender witout the container or blades . Free run it for 5 minutes id you can and see if that helps.
Oct 20, 2009 | Krups 574 Power Xtreme VI Premium Work Top...
Blender stops after about 2 seconds on every setting
correct - replacing the cord is suggested and simple.
Aug 04, 2009 | Breville BBL550XL 5-Speed Blender
Received the Breville Ikon 600 blender as a Christmas present in 2006 and have used it 3 times, with the third time being this past weekend. The product is now out of warranty and low and behold, it...
My IKON 600 Blender fuse had blown. It was located on the circuit board and can be found by removing the bottom of the blender. Fuse is Fast Blow 10A, metric 5mmx20mm. The fuse blew because the bearing in the bse of the jar froze. Bearing # 608-RS. The beraring froze because the seal in the base of the jar was leaking. Solution: Clean seak surfaces, replace bearing and fuse. Total cost of $6 with my labor.
Apr 16, 2008 | Breville CBL10 BlendMaster Classic Work...
My rarely used Sunbeam Blender Model #4181 stopped working
It sounds like one of a number of things...
* The contacts in the switches fried
* The motor itself fried
* The controller section fried
If you saw smoke, something fried... probably cheaper to simply replace the unit. Even if it still worked, it's a 120V electric appliance used with liquids, and I wouldn't trust it... I'd hate to hear that your blender started a kitchen fire.
Mar 22, 2008 | Oster 4134 / 4126 Classic Beehive Work Top...
Stopped working
i had the same problem after only one month, took in back to walmart and they would do nothing. i love the big heavy glass jar on this model so i baught another on thinking i broke it some how and guess what, the second one stopped after one and a half months. called around and no one would do anything for me, company sucks, i took the bottom cover off the blender to expose the problem and there is a problem with the curcuit board and built in breaker. i ripped out all the speed buttons and curcuit board and just wired in a on/off switch to the motor. works great again. i still had a extra broken blender so i took a old chain saw i had and turned that one into a gas powered blender. problem solved, any questions please feel free to ask.
Sep 01, 2007 | Black & Decker BL5000 ProBlend Work Top...
Blinking lights on KitchenAid blender
Alternating blinking lights on a Kitchenaid blender indicate a bad circuit board which is unable to run the motor properly. Unplug the blender, take the jar off, and turn the spindle by hand. Then plug it back in. If it does not work properly, try a different outlet (perhaps not in the kitchen). If nothing works, the blender needs to be repaired.
Aug 27, 2007 | KitchenAid KSB3 Classic Work Top Blender
Breville BBL600 5Speed Blender Logo
32 people viewed this question
Top Breville Blenders Experts
Mike
Craig Butler
Craig Butler
Joseph Hoffmann
Are you a Breville Blender Expert? Answer questions, earn points and help others
