Question about Brookstone Tipsy Wobble Light
Unable totap to turn off. Does it use one or two batteries.
Also difficult to always tap to turn on
Does not tap on or off
I have brought 5 at a sale and only one works now. Batteries are fine but they just do not function like they were supposed to. They started working and then just decided one day to not turn on anymore. you can slam it and you see a brief flash of light but nothing enduring or lasting longer than 6 nanoseconds. So Far writing the store and no results.
Mar 18, 2014 | Brookstone Tipsy Wobble Light
Unable start
Unplug the power cord
Take out the battery
Hold Power button for 30 sec
Tap Power button 30 times
Put battery back in
Plug power cord back in
Press power button to turn on.
Sep 13, 2013 | Lenovo ThinkPad Computers & Internet
The safety lock is enabled and I am unable to turn this off. I am also unable to navigate to an address or favorites. It is also on the wrong time zone.
The safety lock is active only while the device is moving. When you stop, you can access all buttons again. To switch off the feature,
  • Tap the map display to go to the device main menu
  • Tap "Change Preferences"
  • The TomTom XL device hides many menu options by default. If you can see an icon "Show ALL menu options", tap this one next. It should show as "Show fewer menu options" now.
  • Locate the icon "Safety Preferences" (a red heart on blue background) and tap it. This will allow you to deactivate the safety lock feature.
  • You may want to hide the lesser used menu options again.
In order to set the time properly:
  • Tap the clock button to set the time and to change the way the time is displayed.
  • The easiest way to set the time is by tapping the Sync button. Your ONE XL will then take the time from the GPS information it receives.
  • After using Sync to set the time, you may have to adjust the hours depending on your time zone. Your ONE XL works out your time zone and always keeps the time correct using the GPS information.
  • You can only use Sync if you have GPS reception, so you cannot set the clock in this way when you are indoors.
Dec 28, 2010 | Tomtom One XL GPS Receiver
The studs bolts that are screwed into the head are broke off even with the head. I have a 1993 Dodge Ram 150 with a V-6 motor. How do I get these old studs out of the head? The studs are broke off on the...
You need a set of (easy outs) You need to drill a hole in the center of the bolt,insert easy out and carefully turn the easy out counterclockwise. It will bite into the bolt as you turn it If there is not enough room to drill you may try a centerpunch totap the bolt in reverse Hope this helps You can get easy outs at any place that sells tools
Dec 22, 2010 | 1993 Dodge D150
Hi, On the fuel tap what is the Prime position function.
You have a vacuum operated fuel tap. It should have 'on' , 'res' and 'prime'.
In the prime position fuel will always flow from the tank. In the other positions the engine must be running to allow fuel to flow. If the bike has been standing for a few days, fuel will evaporate from the carbs and the bike can be difficult to start. By switching to prime for a minute, the carbs are replenished and starting should be easy. Dont forget to return the tap to on or reserve once started.
Sep 06, 2010 | 1997 Suzuki GSF 1200 Bandit S
Difficult to turn the water heater
step one... remove from wall
step two... throw in dumpster
step three... purchase and install a quality tankless water heater.
Rinnai, takagi, Noritz are the only brands I install now. Aquastar (Bosch) always had problems, then purchased by Bosch but never fixed the problems, just put their name on it and sold them at Lowes or home depot.
Garbage!
Jul 31, 2010 | Bosch & Tankless LP Hot Water Heater
Wolf Commercial Gas Range: turning knob on and off very difficult
easy pull the tap apart and clean it with metho and repack it with gas tap grease and take note how you pull it apart also watch out for the spring in side it
Apr 25, 2010 | Wolf Manufacturing Gas Kitchen Range
Battery problem
Tip: Check the fluid levels on each chamber. If any chamber is low, carefully top it up. Use only distilled or deionized water, NOT tap water. Tap water has minerals in it that will not do the battery any good.
The humble battery is a very common cause for motorcycle breakdowns! Unfortunately they are awkward to get to and therefore do not get checked as often as they should.
A battery only requires a little monthly maintenance to perform perfectly. Keep the battery charged to 100%, recharging when the lights dim, the starter sounds weak, or the battery hasn't been used in more than two weeks. Other than that, follow this simple check list every month:
- Check the electrolyte level
- Top up only with distilled or deionized water, wear gloves and protective glasses. Top up in a well ventilated area, Beware of fumes.
- Keep the top free of grime
- Check cables, clamps, and case for obvious damage or loose connections
- Clean terminals and connectors as necessary
- Check inside for excessive sediment, sulfation or mossing
- Make sure the exhaust tube is free of kinks and clogs
- Replace caps firmly
- Finish up by testing the battery with either a hydrometer or voltmeter. To extend the service life of your battery, make monthly battery maintenance part of your routine.
Storage can be hard on batteries. In fact, non-use can leave them unable to hold a charge.
Store your bike in a place that is always warmer than 32 degrees. If your bike is outside remove the battery from your bike and store it in a location that is always warmer than 32 degrees. This will insure that your battery does not freeze and crack.
If you remove the battery from your bike DO NOT store it on a concrete or metal surface, place the battery on a wood or other non-conductive surface. Batteries stored on concrete or metal will discharge over time.
Place a charger on your battery. Trickle charge your battery at least once a month. A battery that is fully charged will have a longer life and is less likely to freeze during cold winter weather.
May 17, 2009 | 1990 kawasaki ZXR 750
1999 Ford Taurus Wont Start
Tapping the starter does not always work. I would check all the connections on the battery and starter. If these are good replace the starter. Don't forget the grounds.
Nov 03, 2008 | 1999 Ford Taurus
Brookstone Tipsy Wobble Light Logo
181 people viewed this question
Top Brookstone Cooking Experts
Tom Chichester
ray gallant
Are you a Brookstone Cooking Expert? Answer questions, earn points and help others
