Question about Mitsubishi WD-62528 62 in. LCD Television
P1155 toyota rav 4 2001 - Mitsubishi WD-62528 62 in. LCD Television
Is the p1135 sensor connector the same as the p1155 sensor connector?
Most likely not, they look the same but the plastic shell has a ridge coded into it that prevents hooking it up to the wrong sensor. I think you may have an issue with the O2 heater circuit, loss of ground or power.
Jul 22, 2017 | Cars & Trucks
I have found the code for my 2001 rav 4 the code is P1155 sensor heater circuit, how can i fix that what part do i need to fix it?
Hi, assuming you have the 4-cylinder engine, this is your downstream oxygen sensor. Look carefully at the picture to find the right sensor, as there are several similar sensors on the truck. Before buying a new sensor, check the resistance of the heater in the sensor by disconnecting the sensor and connecting an ohmmeter to the terminals indicated in the second picture. The resistance should be 11-32 ohms, depending on the temperature (if the truck is hot from running, the resistance should be at the higher end of the range). If the resistance is outside this range, replace the sensor. You'll need a line wrench or special socket to remove the sensor, as the pigtail is an obstacle to a regular deep well socket. Please let me know if you have more questions, and thanks for using FixYa.
May 29, 2011 | 1997 Toyota RAV4
I have a code of p1155 bank 1 sensor 2. which sensor is that
CODE P1155 HEATED OXYGEN SENSOR RIGHT HAND FRONT HEATER CIRCUIT MALFUNCTION.
Feb 14, 2011 | 2003 Toyota RAV4
Code p1155
P1155 Air/Fuel Sensor Heater Circuit. (Bank 2 Sensor 1)
Actually P1155 is pointing to a fault with the internal heater for the A/F Sensor (aka Oxygen Sensor) for Bank 2 Sensor 1. The PCM uses this internal heater to get the sensor to normal operating temps within a matter of seconds on cold starts. Replacing this sensor should solve your problem. This sensor is located in the front exhaust manifold.
Hope helps (remember rated this).
Aug 07, 2010 | 2001 Toyota Highlander
I have a toyota rav4 2003 management light came on checked code p1155 oxygen sensor bank1 sensor 2 changed it, cleared code light still,came on again ,changed the other three ,cleared the code again, ran...
The upper sensors are air fuel sensors and the lower ones are o2 sensors. you cant mix these up. Assuming you did everything right and still coding then either the new sensor b1s2 is bad or the wirng(power and ground need to be checked. A scan tool can be used to look at the performance of the sensors too. Sometimes the codes just point to the area of the problem and changing the part isn't the answer.
Nov 15, 2009 | 2002 Toyota Avalon
The check engine indicator is on. code p1155
Your heated oxygen sensor (the heater portion), located on the manifold closest to the radiator has failed. Replace it with a TOYOTA part, or your problems will continue; aftermarket sensors do not fare well in Toyotas.
Sep 17, 2009 | 2006 Toyota Highlander
Getting code p1135 and p1155 on toyota rav4 2002
Here's what the codes mean:
P1135 Air/Fuel Sensor Heater Circuit Response (Bank 1 Sensor 1)
P1155 Air/Fuel Sensor Heater Circuit. (Bank 1 Sensor 2
This is mainly related to the oxygen sensors. It maybe the sensors themselves or an open wire going to te sensors. They are mainly located on the exhaust pipe. One before and on after the catalytic converter.
Apr 15, 2009 | 2002 Toyota RAV4
Toyota rav 4
I work for Toyota, and I will be glad to provide you with the actual answer:
The RAV/4 product is available in two models, a 4WD model and a 2WD model.
The difference between the two is on the 2WD model, there is no driveshaft going under the vehicle to the rear wheels, and no rear differential. There is no "RAV/2"; both models are called RAV/4's.
There is a lot of common confusuion about how the 4WD works. It is full time 4WD. In other words, it is always in 4WD. It does not "kick in/kick out/automatically engage", or anything like that. It is 4WD all of the time. But, when I say "4WD", that is sometimes mistaken for "all wheel drive", and, in this case, the RAV/4 is not "AWD". What this means is that if you raise the RAV/4 up on a lift, and put it in gear, 1 rear and the other side front tires will spin. True "all wheel drive" would have ALL 4 wheels spinning. This is not the case with the Rav/4. What the RAV does have, making up for not having "True AWD" on the 5 speed model, however, is a switch that locks the center differential in the transfer case, which, when engaged, applies a method of "locking" the 4WD system for maximum traction, but it is still not AWD. The automatic version doe not have this ability.
The last "true AWD" vehicle for purchase was a 1970's International Scout.
If you are considering purchasing a RAV/4, that is a very good investement. They hold their value quite well, and are virtually bulletproof; I do not make any "money" off my RAV/4 customers...
Just "gas station work". Very nice cars. I hope that this helps you, please feel free to comment back with any otherr questions...Glad to be of assistance.
Toyota Ed
Oct 17, 2008 | 2002 Toyota RAV4
Mitsubishi WD-62528 62 in. LCD Television Logo
12 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
