Question about Electrolux EI28BS56IS (278 cu ft) Bottom Freezer Commercial French Door Refrigerator
French door EI28BS56IS
Why is the refrigerator section not cooling?
Sounds like a defrost problem,either bad defrost heater or bad defrost thermostat
Jul 07, 2015 | Electrolux EI28BS56IS (278 cu ft) Bottom...
How do I get ice from model #E128BS561S5?
I hope this page from the manual helps. It might be that you must hold down the button for 3 seconds as stated in the manual, or a stuck bale arm. Otherwise, it may be a bad feed valve to the ice maker.
Nov 26, 2014 | Electrolux EI28BS56IS (278 cu ft) Bottom...
The cooling fan Inge the freezer is not running
Hi James, thank you for your question! If the cooling fan is not functioning properly, then your refrigerator could possibly be experiencing a seal system issue. Let's try resetting the unit by either unplugging it or flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn the unit on. If the issue persists, regrettably, this is not a simple DIY job. I would strongly recommend connecting with a professional to narrow down the precise issue before investing in parts that may or may not be the root cause. You can often locate a qualified service provider through the manufacturer website.
Aug 01, 2013 | Electrolux EI28BS56IS (278 cu ft) Bottom...
New refrigerator installed on thursday still not making ice as of saturday morning. how long before new machine begins to make ice for the first time?
Should have started within 24 hours. Please check your manual and report or make a claim to the manufacture asap. Things you can check are; wiring to the ice maker. There is a wire plug behind it check for proper connection, check the Ice On/Off switch/lever. Hope this helps FixYa up.
Aug 13, 2011 | Electrolux EI28BS56IS (278 cu ft) Bottom...
Ice Maker is dripping water
HI,
The plastic water tub that fills up the ice maker keeps dipping into the ice makers even after I shut the water off and of course freezes and makes a mess. Why is that? What can I do to fix this problem? Thanks
Dec 27, 2010 | Electrolux EI28BS56IS (278 cu ft) Bottom...
Recently purchyased electrolux 3 door . Had water supply disconnected for approx 8 hrs and now have water back on but ice maker will not make ice
You have to open the water hose let the water drain for at list 2 to3 minute so you can have the water line free with air package, and close backthe water hose
Oct 24, 2010 | Electrolux EI28BS56IS (278 cu ft) Bottom...
Electrolux EI28BS56IS (278 cu ft) Bottom Freezer Commercial French Door Refrigerator Logo
27 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
