Question about Maytag Neptune MAH5500B Front Load Washer
MAH6700AWW tub wobbles - Maytag Neptune MAH5500B Front Load Washer
Have a GE WSXH208HWW Spacesaver, Washing Basket is wobbling. What is the problem and can I fix it myself?
2 possible problems. On the outside of the tub front and on the top back are cement counter weights that are bolted to the tub. If they are coming loose, they would cause the tub to go off balance and wobble. If just the stainless inner tub is the one that wobbles, that suggests a bad rear drum bearing. The counter weight problem easy to fix once you get the top and back off and just need re-tightened. The back drum bearing is something even trained techs want to avoid. It requires removing the complete tub/drum assembly from the washer----then splitting the outer tub in half to replace the inner drum and bearing assembly. Cost for parts will be excessive and not worth the repair.
Apr 04, 2015 | GE Washing Machines
Ge transmission shaft wobbles
The tub bearings are worn out, you will have to replaced the outer tub to repair this problem. Good luck. Here to help
Feb 04, 2014 | GE WDSR2080D Top Load Washer
Maf 1375 AAW front loader washing mahcine - water wont drain out???
Remove the back access panel. On the bottom of the tub you will see the drain boot. Remove the boot from the tub and check for any blockage. Also, while you have the boot removed, check up in the tub for any small pieces of clothing that may be hung up in there.
Feb 09, 2011 | Maytag MAH6700AWW Neptune Front-Load...
Need to change tub bearing on frontload neptune model mah300wwa 2nd.year productoin
That bearing is part of the outer tub and is a big job.
you can get a diagram here . The bearing is not shown because it is part of the outer tub.
I would verify that if you decide to do this. but I remeber doing just one and it was a $600.00 Job, Of course that was with labor. the tub itself is over $425.00
the model # I used was mah3000aww
Jan 13, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Washer tub wobbles, washer is level, on spin cycle the tub wobbles so bad it sounds like the tub is hitting the washer.
Sounds like a drum bearing problem , unless you are an engineer , suggest call service agent for estimate.
Nov 08, 2009 | LG WM2101HW 4.0 cu.ft. Washer
Maytag Neptune MAH6700AWW overflows out the detergent tray opening while filling
water leaks out of the plastic box where you put the detergent/bleach/fabric softener, from the OUTSIDE of the box onto tub, drips down tub on to metal tray and into drawer. Anyone had this problem?
Nov 07, 2009 | Maytag Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
19 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
