Question about Califone CLS721 Wireless Headphone - Yellow 72.100 MHz CLS-721
I suspect that the batteries in our 20 pairs of Califone Model 721 wireless headphones (yellow) are dead and will not recharge. Is there any way to take out the old batteries? They seem to be pasted inside the center of the black plastic circle within the earpiece that has the red and white wires leading off of it. Is there any hope of changing out the batteries so that the headphones can be recharged? Please respond to devans@tisde.org
Where do I find the model number
The words "red and blue lights", "paired", "connect" and "beeps" make me believe that your headphones are Bluetooth-enabled. However, I never heard of a TV that is Bluetooth-enabled. Therefore, I do not think that you will be able to pair, nor connect your headphones to your TV. If you want to listen to your TV wirelessly, you will have to use regular (not Bluetooth) wireless headphones, which consist of two pieces: the headphones and a transmitter that connects to the audio output(s) of your TV and transmits the sound from your TV to the headphones wirelessly.
Dec 06, 2014 | iHip Audio Players & Recorders
My headphones seem completely dead in spite of charging
Rechargeable Batteries are notorious for failure, if they are accessible they can be changed to new... hope this helps?
Oct 13, 2014 | Sennheiser RS 120 Wireless Headphones
Battery failure
I know this is almost a year old, but why can't you access the batteries? How have you been using the headphones without either recharging or simple using regular batteries? The batteries that came with the unit are not proprietary and any pair of AA batteries will work. I haven't used the Sony batteries that came with the headphone for years, won't recharge anymore. I have been using Sanyo eneloop AA rechargeable batteries ever since and keep a fresh pair of batteries recharged at all times. And it seems like they go on for ever, but the time between replacing the batteries is about once a month.
Feb 07, 2014 | Sony MDR-IF5000 Headphones
I need ni-cad battery specifications for Acoustic Research AW-721 headphones. I bought replacement ni-cads but they don't charge when the headphones are placed on the headphone cradle/charger.
The AR AW721 headphones require 3 AAA NiMH batteries, not Ni-Cad. The original batteries are 1.2 volt, 550 mAh. I replaced mine with Energizer 850 mAh AAA batteries, which work well and actually last longer per charge than the originals.
Sep 20, 2010 | Acoustic Research AW-721 Consumer...
Hi! My headset keeps disconnecting...as if the battery is dead...how do I recharge the headset?
Based on the manual you are supposed to get a cable that connects to the transmitter and that would be the charger, make sure that you get new rechargeable batteries because most products provide you with generic Chinese batteries and those would last just a few recharges.
I'm giving you a link to download the manual I'm not sure about the model but the principle is the same. (click on the support and manuals tab)
http://www.araccessories.com/ARAccessoriesProductDetail.do?ACTION_TYPE_ID=ACTION_TYPE_PRODUCT_DETAIL&ACTION_CATEGORY_IDSTR_CATEGORY_HEADPHONES&ACTION_PRODUCT_ID=AWD205
if it works for you don't forget to rate me
thx
May 21, 2010 | Acoustic Research 2.4GHz Wireless Stereo...
RCA headphones - nicad or alkaline batteries WHP141
BATTERY INSTALLATION AND INFORMATION
Your wireless headphone unit requires two rechargeable AAA batteries.
Rechargeable batteries are uncharged when you purchase them. Before
you can use the wireless headphones, the batteries must be charged for
16 hours. Follow these steps to install and charge the batteries.
Installing the Rechargeable Batteries
Take care to follow these steps to correctly install the batteries.
1. On the right headphone, locate the battery compartment (1).
Use the finger depression on the compartment to turn the battery
compartment cover counterclockwise to remove the cover.
2. Insert two AAA rechargeable batteries, carefully following the
markings inside to ensure the batteries are inserted properly, with
the + and - ends in the correct positions.
3. Replace the battery compartment cover.
Charging the Rechargeable Batteries
To recharge the headset unit, follow the directions below. Note: The
cradle/transmitter on the WHP141 is not a recharging cradle, although
you may place the headset in the cradle during recharging.
Follow these steps to recharge the NiMH rechargeable batteries.
1. Make sure the ON/OFF switch (2), located on the right headphone,
is in the OFF position.
2. Connect the AC/DC main power adapter to the DC IN power
supply socket (11), located on the back of the cradle/transmitter.
3. Plug the adapter into an electrical outlet.
4. Connect the charging cable (10), located on the back of the
cradle/transmitter to the recharging input (3), located on the right
headphone. The headphones can either be placed in the
cradle/transmitter or placed next to the unit. If the headphones are
connected correctly, the charging LED indicator light on the
cradle/transmitter (8) illuminate.
Mar 27, 2009 | RCA WHP141 Consumer Headphones
Easyshare 721 battery problems
You need high-power re-chargeables - 2300 mAH or 2500 mAh
May 13, 2017 | Kodak EasyShare CX7430 Digital Camera
Sennheiser TR136 Wireless Headphones Nothing Happens
I had a similar problem - after owning them for 4+ years, no sound we coming out, and no beeps -- nothing. The lights on the charger stand were on though.
I tried buying new rechargable AAA batteries and they were NIMH (nickel metalhydride?) and still didnt work. I borrowed a friend's pair of NICM (nickel cadmium?) AAA rechargables though and the problem was solved!
So, it would seem the some of the new chargable battery types might not work in older models of this unit (which is also called the RS 130 now in the US and Cdn web sites).
Hope this helps!
Mar 29, 2008 | Sennheiser HDR 120 Consumer Headphones
Replace the NiMh batteries. They might be bad. Could happen during power surges as you indicated you had. Let them charge up fully 14-18 hours as the book suggests.
Aug 25, 2007 | Sennheiser RS115 Wireless Headphones
Califone CLS721 Wireless Headphone - Yellow 72.100 MHz CLS-721 Logo
Top Califone Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Califone Audio Player and Recorder Expert? Answer questions, earn points and help others
