Question about Video Game Consoles & Games
Crack or unlock questerium sinister trinity - Video Game Consoles & Games
What cause manifold to crack 88 ford 150
I am assuming you are referring to an exhaust manifold crack. There could be a number of reasons. It could simply have cracked from age, having heated and cooled thousands of times in its life. Or it may have been struck inadvertently. More sinister problems could be a blocked catalytic converter causing back pressure and excessive heat. If the engine has been running a little rough lately, a burnt exhaust valve can cause excess fuel to be burned in the manifold, resulting in overheating and cracking.
Aug 04, 2014 | Cars & Trucks
Password protected bios
Download trinity kit for free. Burn an iso to a disk. Then boot from the trinity kit cd. I've use this software to crack the password.
May 24, 2011 | Panasonic Toughbook CF-73 Notebook
I have the Trinity 788, when I put my finger on it, it beeps and makes the sound of unlocking, but handle just turns without turning lock mechanism. What have I done wrong
Trinity Keyless Biometric lock:
I can't answer your question directly, but I can steer you to their website, which includes a support phone number that you can call, as well as links to Customer support and Frequently Asked Questions:
http://www.axxisbiometrics.com/products/locks/latch-style/trinity788/
I'm sure they can answer your questions. Good luck!
May 18, 2011 | Trinity Keyless Biometric Fingerprint Door...
I HAVE AN HTC P3600 AND IS IN PORTUGESE HOW CAN I CHANGE THE LANGUAGE INTO ENGLISH OR GREEK;
you will need to unlock the CID(country Identification) first to allow you to flash an english (or greek if there is one) rom
unlock using the trinity cid and sim unlocker found here
http://pof.eslack.org/trinity-unlocker/
Easy auto-install Instructions:
  1. Unzip unlocker and run AUTO_Unlock_v1.bat
If you don't want to install automatically, or for some reason the process doesn't work for you, here are the manual instructions:
  1. Transfer SSPL/SSPL-TRIN.exe to your phone and run it
  2. Tri-color screen will appear
  3. Disable activesync (file -> connection settings -> uncheck "allow USB connections")
  4. Connect your phone to your computer using the USB lead.
  5. Run RUU/ROMUpgradeUtility.exe
  6. Follow the flashing process (Check the "I understand..." and "I completed..." boxes and update!)
  7. Allow your phone to reboot.
  8. Transfer TRIN_Unlock_v1.exe program to your phone and run it
  9. Click the Unlock Button, select unlock option. Select if you want SIM/CID unlock.
  10. Click "Unlock!" and wait until process finishes.
  11. When done, turn off your phone for 10 seconds and reboot after that.
after successfully unlocking the cid you will be able to flash any rom to your phone, english, chinese, greek etc
after unlocking the cid/sim i recommend downloading hardspl and installing this as well. This allows a good recovery rate if anything went wrong during flashing.
hard spl can be found here
http://forum.xda-developers.com/showthread.php?t=299659
UNDERSTAND ONLY FLASH ROMS MADE FOR YOUR PHONE (trinity) you cant flash roms made for other phones, if you try , you could end up total destroying your phone, with no way of reversing it
Greek rom (i found one) is here
http://rapidshare.com/files/70268122/Gelly_01.exe
English rom is here
http://rapidshare.com/files/251545131/TRIN_WM6.5__3_00_707_53__B23002.rar
PASS:- PhamQuang
If you found this info useful please vote for me
Apr 01, 2011 | HTC P3600 Pocket PC
I have a Trinity Keyless Biometric Ringerprint Door Lock Adel 788. The scanner reads my fingerprint but the internal lock/unlock won't operate. I already tried resetting the lock to factory out of the...
This is the website for Axxis Biometrics, the manufacturer:
There is a phone number and email address which you can use to contact them for technical support.
Feb 14, 2011 | Trinity Keyless Biometric Fingerprint Door...
Video Game Consoles & Games Logo
49 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
