Question about Xerox WorkCentre 6400X multifunction ( fax copier scanner ) ( colour ) Laser Printer
Xerographic error message
Local interface problem detected
interface is like the units have to be compatible to work
most of these messagers is an indication that a driver is missing
Feb 04, 2013 | Xerox WorkCentre 5687 5675 5665 165 275...
Code 09-700 xerox 4150
09-700 Toner Supplying Error RAP
The toner module has stopped supplying toner to the xerographic module.
Procedure
WARNING
Switch off the electricity to the machine. Disconnect the power cord from the customer
supply while performing tasks that do not need electricity. Electricity can cause death or
injury. Moving parts can cause injury.
1. Check that the tape seal has been removed from the xerographic module, PL 9.10 Item 1.
2. Remove the toner module, PL 9.10 Item 2. Check that the locking lever opens and closes
the toner shutter.
3. Install new components as necessary:
• Toner module, PL 9.10 Item 2.
• Xerographic module, PL 9.10 Item 1.
Jul 27, 2011 | Xerox WorkCentre 4150 Black and White...
Xerox 4150 my paper is a light shade of grey, what can it be thank you
Giacomos,
Is the paper a shade of grey with no image? or is there an image with a grey background?
If there is a image with a grey background you should try a new toner module. If that doesn't resolve the issue, clean the xerographic drum, make 10 blank copies, if the cleaning doesn't resolve the issue than install a new xerographic module.
Hope this help.
Apr 05, 2011 | Xerox WorkCentre 4150 Black and White...
9-xxx Codes are all Xerographic problems such as toner problems, developer problems, Drum Cartridge problems, ADC (Auto Density Control) problems too.
Aug 12, 2009 | Xerox DocuColor 12 Color Copier
Aug 12, 2009 | Xerox DocuColor 12 Printer
Xerox 5328 copier error
U9-3
Xerographic process problem.
The Exposure sensor detected low Exposure Lamp intensity. Switch the Main Power Switch off then on in order to clear the Status Code. Go to the U9-3 Xerographic Process Problem RAP
U9-4
The Main PWB sensed that the Toner Dispense Motor was not running. Perform 20-3 U Codes Clearance . Go to the U9-4 Xerographic Process Problem RAP
U9-5
The CSDC zero point was too high during auto setup. Perform 20-3 U Codes Clearance . Go to the U9-4 Xerographic Process Problem RAP U9-5 Xerographic Process Problem RAP .
Aug 09, 2008 | Office Equipment & Supplies
Error code 9-343
all 9-xxx codes are xerographic problems,such as toner,drum,developer or auto density.install or replace one or the other.
Jun 30, 2008 | Xerox DocuColor 12 Color Copier
I got a Error code 9-343
any 9 -xxx code is related to the xerographic area of the machine NOT the fuser area- you don't mention the model number so I can't be specific, but try the Drum/CRU/toner area, make sure you haven't dislodged anything (modules, plugs, sockets etc.)
May 08, 2008 | Xerox DocuColor 12 Color Copier
Problem with xerox Doc Centre 470ST
uwasbisi... It is not un-common for the Xerographic modules for these models to be defective right out of the box. I myself experience about a 50% DOA rate. You may want to try another one.
Before you do that though, try this...
Remove the xero-module and the toner cartridge. Look into the now empty compartment area's (you may need a flashlight), and directly above and center to the magnetic developer roll/housing (under where the toner cart was, and directly left of where the xero-mod was), there is a photo-sensor mounted to the toner/developer housing that faces the (now removed) xero-module. It is rectangular in shape. About 3/4" tall and 4" long. Clean it off with a dry lint-free rag thoroughly. Do not remove toner/developer from the face of the magnetic roller that faces the xero-module. Only clean this sensor above it.
This is the sensor that "reads" the toner density produced on the module during set-up, and if it's dirty (and it DOES get dirty considering it's location), it can cause the type of problem you are experiencing.
All that being said, there are many other issues that may be the culprit as well (from a bad stapler safety gate on a sorter, to power supply board problems). Are you getting any service/error codes (you should be) in conjunction with the service message? You can look under the "error history" under "machine status" to the right of the touch screen.
Let me know.
Oct 08, 2007 | Office Equipment & Supplies
Open Questions:
See all Xerox WorkCentre 6400X multifunction ( fax Questions
Xerox WorkCentre 6400X  multifunction ( fax  copier   scanner ) ( colour ) Laser Printer Logo
122 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
