Question about Broaster Pressure Fryer
Internaly cleaning the fryer
Where can I get a wire cleaning brush for the fryer?
Not sure how to clean heating element
There are various fryer cleaners or degreasers that can be used. In most cases, the fryer is drained and wiped out, filled with water, and the appropriate amount of cleaner is added. Usually, the fryer is turned on and the cleaning solution is boiled for a time. Follow the directions for the cleaner. If heated, be careful that it does not boil over. A nylon scrub brush can be used if necessary but not metal scrubbers or utensils. Repeat if necessary. Rinse thoroughly with clean water. Use protective gloves when working with fryer cleaners and be careful not to get the cleaner on painted surfaces, aluminum depending on cleaner's instructions.
Sep 09, 2014 | Kitchen Appliances - Others
How to clean the top of the Philips airfryer
Clean the outside and inside
  • outside of the airfryer will not get greasy like a conventional deep fat fryer
  • clean the outside with a moist cloth, inside with hot water and a soft sponge.
  • clean the heating element with a soft to mediym bristle brush, after dry with paper towels. DO NOT use a steel wire brush or a hard bristle brush
http://airfryerreviews.com/how-use-philips-airfryer-tips/
Jul 04, 2014 | Health & Beauty
I have a pitco deep fryer... Everything works fine, but when the burners go off, I get a popping sound that blows out my pilot light
It sounds like the burners and tubes may be dirty and clogged in your fryer. The burners are removable and need to be cleaned periodically. The tubes can be cleaned when the burners are out using a burner cleaning brush. If the above mentioned items appear to be clean, you may have a gas pressure issue.
Jan 08, 2013 | Kitchen Appliances - Others
Cleaning insrtructions
Gp to a restaurant equipment store or a food broker type place, or I can ship the product to you via UPS, but there are prodcuts developed specifically for cleaning fryers out, like Mr. Muscle, Degreaser, etc. You would fill your fryer up w/water, add the solution, like a packet of Mr. Muscle, and continue to boil the mixture for some time in the fryer.... After it's boiled for some time, use a fryer brush on your heating elements, etc, which you can also buy at a local store or I can ship one to you. When the fryer is clean, you will drain the mixture out and rinse several times. You want to make sure you get all the soap residue out of the fryer or it will destroy your oil after you add it in and try to cook with it...Rinse several times, then add your oil and you should be ready to go. You can also drop your fryer baskets in the mixture just like you are cooking and the boil out product will clean them too.. Be sure to drop them again as you rinse the whole unit out.. Hope this helps. Buy a couple of green pads too, and they should help you with any outside baked on stuff
Good luck,
Susan
REO
Dec 12, 2011 | American Range AF45LP Deep Fryer
How do i clean the buildup in my heat tubes on a pitco 35c fryolater. the buildup ignites and burns. wire brush?
Certainly, you can use a specially designed wire brush for cleaning the tubes... We sell them ourseles, however first I would recommend using a product called Deep Fat Fryer Cleaner. It comes in either a liquid or a powder, and is mixed with water, directly in the stainless frypot itself. You then turn up the heat, and boil the mixture for awhile. There will be directions on the product....You fryer brush is shaped like a small L so you can reach all around the tube area and in the drain area as well. By using the boil out product first, you will loosen up all that baked on crud and get rid of some of it, and keep in mind, that with commercial equipment and the crud that builds up.... You have to get the equipment warm before you can effectively clean it. A griddle must be turned o n to warm, a fryer also. Be sure when you are done, to rinse all the soap **** out of the ss pot. If not, you will ruin the next batch of oil that you use and with the price of that stuff, you don't want to take a chance on doing that. I also recommend a fryer additive from Miroil... It keeps you from ever dumping a whole vat of oil again. You can go online and look over the product information, and if you are interested, I can give you pricing, as it comes in a powder or a liquid. It keeps your product golden all week long, no golden brown at the lst of the week and darker product as the week goes on... You will have consistent golden brown product all week long, period... Miroil also recommends keeping your oil temp to 325 or below... Most people use 350 and it's too hot and ends up burning up the oil. That and the soap **** not getting rinsed out completely are what deteriates your oil and runis it. Those brushes are manufactured to take high heat without hurting them and they run $23.50 each. I also have straight brushes too. The miroil additive runs $29.95 a litre bottle, which will do 55 applications for a 50# fryer. (You use different amounts for different size fryers, and it makes a difference on how many days a week you are open and how many hours the fryers are on). A 3 pack runs $88.95. I also have the powder deep fat fryer cleaner, which comes in a 9 lb jug, for $11.95. I also carry Mr. Muscle individual liquid packets of deep fat fryer clean for $1.95 each. You just dump one in the fryer, along with your water and boil it, then rinse well.
I hope that's not too much overload... Somtimes I forget to stop and breath... If you have any other questions, please call us at 888-542-5959. We're in Cincinnati, Ohio, but ship everywhere. Our website is www.restaurantequipmentinc.com and email is reocincinnati@yahoo.com. Thanks, Susan
Aug 15, 2011 | Pitco Frialator 35C Deep Fryer
I just need to know how to completly clean the bottom of my imperial fryer
Are you talking about the actual burners? They make a L shaped brush that you can use to get around the burners themselves, and a quick tip is to clean the fryer warm.... Once you heat up a griddle or fryer, the cleaning gets substantially easier. They also make either liquid or dry powder cleaning additives, which also help with the cleaning... Once cleaned, make sure you rinse all the soap residue out of the frypot, as that will help to quickly break down your oil, once that new oil is heated up. Another tip is to ony turn the temperature up to 325, not 350, as that also helps to break down your oil. Keep in mind, no matter what yu do, your fryer will never look clean again.... Even the clean, used ones look alittle used after some use and never look shiny new again. If you need any of the cleaning solutions, I do sell them and would be happy to ship some to you... Our individual packets of liquid Mr. Muscle cleaning solutions run $1.95 each and for a 30-40 lb fryer, you need two per cleaning. The directions says to drain oil out and rinse to clean out loose soils, fill w/'water to oil fill line, and get water boiling. You add the Mr. Muscle while filling w/water.... Boil at about 225 temperature for 10-30 minutes. (225 degrees keeps it from boiling over). While it's boiling, gently use a fryer brush or scraper to remove baked on soils. You can also buy the powder version, which is $11.95 for a 9lb jug... Fryer brushes are $24.95 and can withstand alittle of the high heat.... I stock all of these items and can ship to you, if desired. Try this anyway, whereever you end up buying your products and this should work for you...This is how we clean the dirty deep fryers we get in and we've never had any trouble. Our phone number is 888-542-5959, and we are Restaurant Equipment Outlet, Cincinnati, Ohio. We sell new/used equipment, furniture, smallwares, just about anything you need for a food service business.
Thanks, Susan
Jul 18, 2011 | Imperial IFS40 Deep Fryer
I have a Adcraft DF-6L and it was not cleaned as it should. The elements have a coating on them from the solids from frying. How is the best way to clean these without damaging them? Any help is greatly...
After cleaning fryers for 25 years, I always revert back to EasyOff oven cleaner. Be very careful when you try to scrub or scrape the elements. There are two thermostat cap tubes. If either one is damaged the fryer won't work. The cap tubes have a small charge of gas which expands and contracts to tell the thermostat when to come on and go off. You probably can't get them perfectly clean. Start by putting water in the fryer pan and letting it boil for a few minutes. Pour the water out and if it was really greasy, boil it again. When you have floated most of the grease that will melt away, then spray the elements with the EasyOff, or store brand oven cleaner. Let it stand for 30 minutes and then rewet the element and scrub carefully with a good stiff nylon bristle brush. A steel brush might damage the cap tubes. Rinse completely clean before using the fryer.
Sep 30, 2010 | Adcraft DF-6L/2 Deep Fryer
Hi, my fryer was shut down during the off season and now the pilot wont't light up . There is gas in the tank, all the gas faucets are on ...Is there a commonly known reason for pipe clogging? plz help ....
You must take apart the pilot assembly, remove the 1/4" aluminum tubing and the pilot generator. use 1/2" wrench for the pilot tubing and 7/16" wrench for the generator. with a lighter near the tubing opening..push the knob on the valve and see if you get about a 6 inch flame. Inside the pilot assembly in a small steel pilot orifice. (kinda looks like a small thimble). Take it out. Make sure that is clean... you can use a wire brush. That should solve your problem.
Tom
Jun 14, 2010 | Frymaster Dean MJCFESC Deep Fryer
I need to know the best wayto clean the inside of an IFS40 deep f
Mr. Muscle Commercial oven cleaner, a good brush, a stainless steel scrubbie. Boil out the pot in accordance with Mr. Muscle directions. If all else fails, find "SWELL" oven cleaner in Restaurant supply, use rubber gloves. Spray on, let sit, Use brush and Scrubbie to remove. RINSE WELL!
Apr 27, 2010 | Imperial IFS40 Deep Fryer
What type brushes do you use to clean pitco gas fryers
Cleaning the frypot or the inside of the burner tubes themselves ? The frypot can be cleaned using a RED scrub pad. You can get a boiler tube brush & extension set from United Refrigeration for about $20. You need the brass brush end that screws on the 36 inch t-handle extension.
Jul 19, 2009 | Pitco Frialator Kitchen Appliances -...
Broaster Pressure Fryer Logo
56 people viewed this question
Top Broaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Broaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
