Question about Blendtec Extra Carafe / Jar for the Total Blender (Blend-Tec) Blender
Blendtec blades turn them by hand - Blendtec Extra Carafe / Jar for the Total Blender (Blend-Tec) Blender
Get a manual for blendtec ES3
i have blendtec blender model ES3 they have problem always showing overload?
Apr 06, 2012 | Blendtec Extra Carafe / Jar for the Total...
Does anyone know how to reset a Blendtec ICB-3 to factory settings?
ust removing all power from the machine for 15 secs or more should reset it.You can contact Blendtec here, Not a solution I know sorry. The manual is here http://www.blendtec.com/Resources/A3-31E-BHMV/Connoisseur%20Manual.pdf
you can contact them here
http://www.blendtec.com/contactus.aspx
Jan 03, 2011 | Blenders
My blendtec blender doesn't blend as well as it once did. The motor seems to be running fine, but I am not sure if the blades are spinning properly.
You have already found what is the problem the blades.
The blades after a lot of working hours with ice they have mainly three problems.
One the sharp adjes have created a lot of teeths and are not so sharp any more so the blending is not smooth anymore.
Second problem they have loose a title so they have move from corect place some milimeters and this change the wave motion and again the beleding is not so smooth as before.
Third the blades are secure on an axis which is located in two bearings which have een wearing out so the rotating motion of the blades again is not so smooth as before.
So if you are not able to fix the blades kit or to find someone in your area to do it profetionaly and cheap one good idea is to buy a new blades kid.
Good luck
Aug 17, 2010 | Blendtec ABC Work Top Blender
The blades on my blendtec jug are stiff, any way to loosen them?
What you need to do is turn them by hand each time you use it, before you put your food in. Sugars and other deposits are often left around the blade assembly when you mix smoothies and stuff. Often this sugar is difficult to clean. Turn them by hand first to break the sugar molecules, then when you are done I would add 2 inches of water and a drop of soap. Run it for about 20 seconds and rinse. That should help the next time you use it. It also helps to use it daily. It keeps the molecules from hardening.
Jul 28, 2010 | Blendtec Extra Carafe / Jar for the Total...
Blendtec replacement jar
You can also go to http://veggiesensations.com to buy blendtec total blender parts. Hope this helps!
Jun 30, 2010 | Blendtec Extra Carafe / Jar for the Total...
How to change the blade
You can't. The Jars have perfectly balanced blades that cannot be changed. A replacement jar from Blendtec is cheaper than a replacement blade assembly from other manufacturers. 1-800-253-6383 is the customer service number.
Jun 04, 2010 | Blendtec Smoother Work Top Blender
ICB-3 Blendtec unit is getting power but will not turn on
check thermal fuse internally , one time blown fuse. need a test meter to check this component , can be bought @ Radio Shack apx $ 8.00us
Mar 13, 2010 | Blendtec ABC Work Top Blender
There is a leak in the caraffe(or jar). It is at
Common issue with all of these carafe's. Once the jar starts to leak the bearings are shot and it is time to replace the jar. The bearings are non-replacable. Bad design in my opinion. I was able to get my last jar (I have been through 3 before the 5 year warranty went out) to last by hand washing and not putting it in the dishwasher, but after 4 years of use on this jar it failed too.
Nov 29, 2009 | Blendtec Extra Carafe / Jar for the Total...
BLENDTEC BLENDER WONT WORK WATCH DOG TIME OUT?
That is a motor issue, you need to contact Blendtec customer service. They will let you know if it is still under warranty. 1-800253-6383.
Oct 31, 2009 | Blendtec HP-611-FLP / HP-621-FLP Work Top...
What to do with the Total Blender when overload appears?
The product has a 3-year warranty:
A reading of “OVERLOAD” indicates an overload on the motor. Turn off
and unplug the unit. Plug in the unit and turn the motor on again to clear the
over-load condition. Check the blender jar for blockage. If overload condition
re-occurs, contact your Blendtec service agent.
Mar 25, 2009 | Blendtec ABC Work Top Blender
Blendtec Extra Carafe / Jar for the  Total Blender (Blend-Tec) Blender Logo
48 people viewed this question
Top Blendtec Blenders Experts
eyecam
Ross Keen
Are you a Blendtec Blender Expert? Answer questions, earn points and help others
