Question about EK Success Papers shapers medium nesting punch-circle 1 inch
There wasn't any paperwork with the punch when I got it specifying what type of media it would cut. I tried to cut a piece of felt, and now its lodged in the punch and I can't get it out.
How do you attach the feet to the sofa? Came without pre-drilled or tapped starter holes or a diagram.
Are you sure there are no existing holes? I have seen where they are actually covered by the material/felt that they staple to the bottom. On the other hand, if it doesn't have holes, try this. I will assume that the feet have a course type wood screw thread. Take a piece of cardboard and cut it to a 4" X 4" square, this should be enough to cover the corner of the sofa. (if not make it as big as needed) Locate the wood corner of the sofa and mark that area on the cardboard. Now you have a template for your feet. Given the center of the wood location on the cardboard, punch a hole through it. This is where you will have to hold the cardboard to the bottom and with a drill, mark a hole on the sofa. Repeat this for as many legs it has. Now judging what size screw the feet have is a matter of gauging it, like stick it into a straw, or next to a pencil. You want a drill bit smaller than the screw size. (15% smaller is good) When you drill the sofa wood, I suggest measuring the screw of the foot and mark the drill bit for that depth. (a small piece of masking tape around the bit will do fine- blue painters tape works better) Once you have drilled all required holes for the feet, proceed to screw them on. If they are a bit tight, or not going all the way in, use your drill bit and make minor adjustments to the depth or diameter of the drilled hole.
Dec 30, 2014 | Furniture
Why does the auto cut not work consistently on my Topaz 30 when embroidering
Where the cutter comes out notice carefully where the cutter lies. This place needs to have a piece of felt. Yours is worn out. You can fix it by glueing a new piece there.
Dec 01, 2014 | Sewing Machines
Telios 1600
There are two main filter outlets on the Telios. One behind the dust bag inside the vacuum (white felt with a black carbon layer usually - or a HEPA paper cartridge that slides right in at the back, though the HEPA filter cuts the suction power considerably, so just get the carbon type with the white felt if you can). The main motor filter at the top is between the power pedal and cord rewind. This is usually a 7 layer microfilter, but you can use any filter such as universal cut to fit types or even a Dyson DC01 filter that has been cut to size.
Apr 30, 2014 | Vacuums
Swingline 74030 manual hole punch handle is locked down
by locked down I am going to assume you mean it will not go back to the normal postion when it is not making a hole. this can be caused by too many of the scrap pieces of paper that are left from making the hole. clogging the punch area. remove all the excess pieces of paper that may be stuck in the whole punch, then try again, you may have to pry the handle and or push and pull it until it releases. do not use again until the handle moves smoothly, clean the areas around the punch.
Mar 07, 2014 | Swingline 74030 Manual Hole Punch SWI74030
AEG Lavatherm 33600. I replaced the belt
the felt is to stop rubbing you can get it from a craft shop. I changed the felt bearing cover with a nylon type washer works better and now don't get static discharge when taking out the clothes. under a 5ver for the lot.
Sep 30, 2013 | AEG Dryers
Aeg lavatherm 33600
just remove the door front panel....the replacement felt is self sticking..........fix the felt with the join at the top...........
cheers
Jul 30, 2017 | Frigidaire GLEQ2152ES Electric Dryer
I'm trying to install the felt polishing tip, and it's only a round piece of thick felt. How do I install it on my dremel?
there in the kit is a shaft with a screw tip on it, you need to thread the polishing disc on the shaft, the shaft has a threaded screw, not the internal type
Feb 06, 2011 | Dremel Variable - Speed Multipro Rotary...
I changed the battery in my winchester digital safe while the door was closed. after i changed the battery i punched in my code and the door will not open. it beeps twice indicating that i punched in the...
was there not a key also? if not then remove the new and start over, if it still wont open refer to your paperwork that came with the unit there is always a number to call for questions.
Oct 16, 2010 | Winchester (026196062448) (20 - 60x70 mm)
Hp 4250 tn when i try to print get an error 13.05.00 papper never makes it though the fuser
Error message means "Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken."
For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation.
Try cleaning your feed rollers...
There are two types of rollers in printers: hard plastic and rubber. Plastic rollers can be cleaned with alcohol (isopropyl). Rubber rollers can be cleaned with a rubber roller cleaner and restorer like the one in the link (you can find other brands, but make sure its for rubber).
http://www.lmcomp.com/80008.html
Jul 27, 2009 | HP LaserJet 4250n Printer
My LGKU990 Viewty Screen is unresponsive. Sometimes it works and sometimes not. Even starting up the phone is a mission in that I have to punch in my PIN, and it sometimes sems as if its entering either...
use a piece of copier paper, run it in the perimeter of the screen. you will see a groove. there are debris lodged in there, dig it out with the piece of paper. and it will work. worked for me. inside there are digitizer that. there are pressure from the debris causing it act weird.
Mar 31, 2009 | LG KU990 Viewty
EK Success Papers shapers medium nesting punch-circle 1 inch Logo
127 people viewed this question
Top EK Success Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an EK Success Office Equipment and Supply Expert? Answer questions, earn points and help others
