Question about Ovens
911455881c Kenmove drop-in range.
Where can I find an electric range with depth less than 28 inches
Bertha, most stoves are going to be anywhere from 26" deep to 29" deep. Most any stove that I have used or worked on has never been a counter depth stove unless it was a slide in or a drop in stove. When I went to GE's website, I did not many stoves that were less than 28" deep until I got up to $1000 in retail pricing. The only one under that price that was less than 28" was also only 24" in width. Hope this helps!
Dec 08, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
I have a magic chef gas range top , a drop in , and the igniters are all clicking at once , started on their own. any help. ??? Larry
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair
Burners Keep on Clicking
heatman101
Dec 13, 2010 | Magic Chef Ovens
I removed the range door to clean oven. Now I
NOTE: The door removal pins you inserted must still
be in both sides of the door.
1.
Grasp the door on the sides with your fingers on
the front of the door and your thumbs on the
inside surface.
2.
Rest the hinge hanger so that it is flat (at the
bottom of the hinge hanger on the bottom of the
front frame slot).
3.
Position the door with the hinge hanger slots
almost parallel to the front frame.
4.
Push up and in until the hinge hanger slots
become fastened to the range. Lower the door
and rotate it slightly from the front to the back
until the slots are fully fastened. The hinge
hanger will be close to the bottom of the front
frame slot.
5.
Pull door open about halfway and remove the
door removal pins. Save door removal pins for
future use.
6.
Close the door.
Dec 25, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Upon recovery from a power outage, the oven door on a Kenmore model #911455881C engaged the automatic door lock, and it will not release. I have cycled the power off and back on; have tried starting the...
I traced the problem to a faulty motor in the automatic door latch. In an effort to get the range operable again quickly, I removed the latch and got the door open. However since I just removed the latch and did not rotate the cam on the motor, the electronics did not "know" that the door latch was open, and therefore it still would not allow the oven to bake or broil. To remedy this I had to completely disassemble the motor and rotate the cam 180 degrees so the the sensors would recognize an open latch.
Dec 23, 2009 | Ovens
Require Electronic Oven Control Guide for a drop in/slide in electric range model Model CFES365EC Frigidaire range self cleaning free standing
the problem with the oven is that,when we start it to bake sumthing it turns of automatically after half and hour,and it doesnt bake anything...can you please help us with this problem...
Sep 16, 2009 | Frigidaire Ovens
I bought a drop in range and there is an open space at the bottom where the range does not come as low as the older one. Is there a piece I can purchase to cover this opening?
The space at the bottom should be built up to support the bottom of the range. It should not support its entire weight on the counter top.
Jul 17, 2009 | Kenmore Ovens
Roper drop in range broiler will not light
YOU HAVE A SHORT ON THE BROIL CIRCUIT PROBABLY ON THE ELEMENT IT IS ELECTRIC CORRECT?
Jan 07, 2009 | Ovens
Maytag oven will not light
There is no reset button on range. Do you mean your house breaker is tripped? I would check for bare wires shorting to ground.
Look for evidence of mice, as in droppings. If so they probably chewed on wires.
Nov 18, 2007 | Ovens
Ovens Logo
14 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
