How to unclog a shellback laundrytray pump 3 -12-19
  • 56 Answers
1) disconnect power and place towels etc underneath everything
2) break discharge pipe(should be a union fitting for servicing)
3) undo big brass nut under sink basket
4) undo 4 hex head bolts holding pump housing together(sometime can be picked out via inlet and discharge
5) Dont try and take impeller off as the ceramic washer may come off and then you got to get a new one. If motorshaft is rusty, time for a new motor, seal and probably an impeller seal. ceramic impeller seal is epoxied on the impeller
Posted on Jul 04, 2014
Sand in fisher and paykel washing machine error 245
This is a pump stall error code. Remove the pump from bottom of washer. make sure nothing is clogging pump. If problem persists replace pump.
Oct 27, 2012 | Fisher Paykel Washing Machines
E-23 error code on Frigidaire 3577kro
Drain pump relay on board failed or wire off pump
Jul 22, 2012 | Frigidaire GLTF2940ES Front Load Washer
If the hoses are plugged would vinegar work to unclog them instead of lime away?
you must try to unclogged from your machine. or blockage . 2) or test the pump-motor for defective parts inside.
go to http://www.dyson.com/support/help.asp?article=32&product=DC22-MOTORHEAD-US
and select the model exactly, and proceed with common sense for troubleshooting, and see the video.
God bless you
Jul 15, 2012 | Vacuums
F21 code still flashes after i've unclogged line - reset?
if you cleaned out the pump by removing the center part of it and it still shows f21,either you didn't clear everything out of the pump,after you pull out the center piece stick your finger inside where the impellar is to see if you feel anything rapped around it,if it's clear and still won't drain then you need to buy a new pump and remove the old pump and install the new pump part number 280187 and it's around 120 dollars http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/Model-MFW9700SB1/3048/0153200/W0705107/00006?blt=06&prst=&shdMod=
Dec 10, 2011 | Maytag EPIC MFW9700S Front Load Washer
Pump is clogged, how do I unclog it?
remove hose going from tub to pump. Do this at the pump not the tub. Should be able to remove debris now. But really depends on your brand of washer. You may have a clean out on yours too.
Jan 31, 2010 | Washing Machines
How do I unclog the copper line?
The copper line and the pump. Which is the concern?
On the circuit breaker, Turn it off and in five minutes, back on.. Then check the outlet at the cooler to see if it's getting power.The copper water supply line? You do have water to the float control valve? or no?
Jul 10, 2009 | Heating & Cooling
How do i unclog impeller?
can use water blaster - if no way to take impeller off.
May 16, 2009 | Polaris Pb460 Polaris Booster Pump...
I have a front loader. Have had it for 3 years always worked just fine never a problem. It stopped when I was washing a front door mat and has yet to work since. It won't let any water in to fill and...
If the problem is just the pump being clogged,,, its very simple. Remove the back panel, or the front bottom panel (if your model has one) and locate the pump. Make sure ALL power is disconnected, and all electrical parts are covered because once you disconnect the tubing from the drum, and pump, all the water will be let out. If there is nothing clogging the tubing, you'll have to remove the drain pump and take a look inside.
Mar 12, 2009 | Frigidaire ATF6000ES Front Load Washer
HOW DO I GET TO THE PUMP TO UNCLOG IT
take cabinet off and the pump is right there in the front of the motor.remove the top hose and the water will finish draining on the floor.reach in and you should be able to take out the obstruction.
Dec 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
siphon to drain the water then flip the washer sideway and locate the motor cuopling or broken belt and change this to a new one
Jan 07, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
1,071 people viewed this question
Top Washing Machines Experts
