Question about Kaldewei 7347 White ConoDuo ConoDuo bathtub with moulded panel and levelin
Kaldewei bayj tub only works properly when water is
Dishwasher stops working a few minutes after being started
Make sure the water is turned on to the unit first--next, is there water entering the tub? Check the float switch--the round, plastic, "flying saucer" shaped object at the bottom of the tub. Gently lift up on it and carefully listen for a very soft "click" sound. That is the tiny switch underneath working. If something gets trapped under the float switch, the washer won't fill with water. Next, if water is indeed in the tub, did you hear the motor pump running? If it runs and then stops, there might be a problem with the control board--check to see if the drain pump works properly--cancel the cycle and listen for the drain pump turning on and draining out all the water. On almost all dishwashers, at the start of a cycle, the drain pump will turn on briefly to pump out any standing water left in the motor base(you can't see the water but it's there) so it doesn't get sprayed onto your dishes. Then, fresh, hot water enters the tub, when the water level reaches the proper level, the float switch rises, tells the computer enough water is present, then starts the main pump. If the water is not being drained out, try to listen for the drain motor humming. If it is running but not draining, it is probably jammed with food or other debris and must be cleared. If the water is turned on but no water is entering the tub, check the inlet water valve underneath the washer--the water line is connected directly to it. It is electrical and operates on 120v. You will need to carefully disconnect the connector from the valve, activate a cycle, and using a voltage meter, check to see if 120 volts is present. If it is there and no water is entering, most likely the valve is bad. If there is no voltage at the valve, either a wire is broken or the main board is defective.
Jul 30, 2015 | KitchenAid Kitchen Aid Superba Series...
Water come out backside automatically
Hi parag vyas - This is not a normal location for the water to be leaking and often it is because the water is leaking out of the rear tub. More than likely, the unit is not draining properly or a damage tub. Therefore, as the tub spins, the centrifugal force is driving the water up the sides of the tub. At this point, I personally recommend consulting a certified technician for an accurate diagnosis and to assist with the repair(s).
Jun 09, 2013 | Electrolux Washing Machines
Water comes out both spout and showe head when temperqture control is adjusted
Something is blocking the flow thru the tub spout. Make sure the dirverter moves properly. It mat be stuck partialy closed.
If that does not work take the tub spout off and see if you still have the problem. If that fixes it get a new tub spout.
Mar 31, 2011 | Delta & Lockwood& Tub & Shower Faucet
We have installed a moen 82490 one handle tub & shower unit. When we turn on the water you could shower and bath at the same time. If you pull the plug for just a shower the water to the spout stops...
If you pull the silver knob on the tub spout up, the diverter located located inside will redirect water up to the shower head and when lowered it will return the water to the tub spout. It sounds as thought the diverter is not working properly. Hope this helps..
Mar 08, 2011 | Moen & One Handle Tub & Shower Faucet
I just bought my hot tub, it shows ''FLO'' on the panel when i turn it on. I did every thing they say on the panflet but it still doesn`t work. Anything else i should do??
The problem is that the flow switch for your water heater is indicating no flow. Therefore your water heater will not operate. Without proper water flow your heater will burn up. Check that your valves are open. Check that your pump is running. Check that your filters are properly installed and not restricting flow. Check the wiring to your flow switch and make sure the flow switch operating properly (i.e. put a ohm meter across the contacts and see if you have continuity when the switch closes).
Sep 18, 2010 | Apollo Pool & Spa
When tub filling, it drains out at the same time.
The outlet of the drain hose must be higher than the water level inside the tub--normally the pump inside removes the water when needed. Get a plumber to install a proper height drain pipe for you.
Jul 16, 2009 | Haier XQBM22-C Top Load Washer
Duet whirlpool washer has water in tub after non-use
Sounds like you need to check your water inlet valves and make sure that they are working properly. Inlet valves when the go bad will allow water to push through do to the water pressure just sitting there not doing anything. Try to figure out if the water is hot or cold. Or you can use a volt meter and see which on is not functioning properly
Feb 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kaldewei 7347 White ConoDuo ConoDuo bathtub with moulded panel and levelin Logo
23 people viewed this question
Top Kaldewei Home Experts
john h
Tom Chichester
Are you a Kaldewei Home Expert? Answer questions, earn points and help others
