Question about Philips HTS3544/37 Theater System
Message on display reads no disc - Philips HTS3544/37 Theater System
The wii won't read the disc
Situation:
  • System displays either error message "Unable to read disc" or "Disc could not be read"
What to do:
  • This message may display if the disc is ejected during play. Return to the HOME Menu before changing discs.
  • If the Wii console is laying flat, verify that the system is not placed upside-down. The game disc slot should be above all three buttons and the SD Card slot.
  • Verify that the disc is being inserted properly.
    • If the console is placed vertically, the disc label will face to the right. Note: Only Wii consoles with model number RVL-001 are intended to be placed vertically (learn more)
    • If the console is placed horizontally, the disc label will face upwards.
  • If the problem occurs with only one game disc, there may be a problem specific to that game. Click here to check our list of specific game issues.
Situation Not Resolved:
  • If only one Game Disc displays this error message, it will need to be replaced. Click here for Game Disc replacement options
  • If the error is occurring with most or all Game Discs or all of one type of game, then this indicates a problem with the system. The console and one or two example discs will need to be sent in for repair. Click here to begin the repair process.
function rvl_ts_sys_unable_read_disc_showsurvey(){ omnitureHelp("helpful_survey:rvl_ts_sys_unable_read_disc",JSchannel,JSprop6,"",""); } var req; var timeout; function rvl_ts_sys_unable_read_disc_psurv(a,sid,pid){ if (window.XMLHttpRequest)req = new XMLHttpRequest(); else if (window.ActiveXObject)req = new ActiveXObject("Microsoft.XMLHTTP"); if(a=="yes"){ document.getElementById("rvl_ts_sys_unable_read_disc_s_yes_button").innerHTML=""; document.getElementById("rvl_ts_sys_unable_read_disc_s_no_button").innerHTML=""; } else{ document.getElementById("rvl_ts_sys_unable_read_disc_s_yes_button").innerHTML=""; document.getElementById("rvl_ts_sys_unable_read_disc_s_no_button").innerHTML=""; } var url="/consumer/surveys/surveySubmit.jsp?a="+a+"&sid="+sid+"&pid="+pid; req.open("GET", url, true); timeout = setTimeout("techDif()", 5000); req.onreadystatechange = rvl_ts_sys_unable_read_disc_psurvr; req.send(null) } function rvl_ts_sys_unable_read_disc_psurvr(){ if (req.readyState == 4) { if (req.status == 200) { clearTimeout(timeout); var outString=req.responseText.substr(req.responseText.indexOf("##")+2); outString=outString.substring(0,outString.indexOf("##")); document.cookie='rvl_ts_sys_unable_read_disc=answered; expires=Wed, 28 Dec 2011 02:16:21 GMT+00:00; path=/'; document.getElementById("rvl_ts_sys_unable_read_disc_s_folowup_div").innerHTML=outString; } } } function rvl_ts_sys_unable_read_disc_techDif(){ //it broke document.getElementById("rvl_ts_sys_unable_read_disc_s_folowup_div").innerHTML="Thank you for your interest in helping us improve our content. It appears our survey system may be temporarily down. Please try again later. If you need further assistance, Click Here to contact us."; } function rvl_ts_sys_unable_read_disc_clearboxsurv(whatto,box){ if(box.value==whatto)box.value=""; } function rvl_ts_sys_unable_read_disc_fsurv(form){ var url="/consumer/surveys/surveySubmit.jsp?p=7" var reasonSet = false; for(var i=0;i-1)reasonSet=true; }else if(form.elements[i].name.indexOf("question2_answer")>-1){ url+="&"+form.elements[i].name+"="+escape(form.elements[i].value); }else url+="&"+form.elements[i].name+"="+form.elements[i].value; } if(!reasonSet){alert("To help us improve our content, please indicate why this page wasn't helpful");return false;} if (window.XMLHttpRequest)req = new XMLHttpRequest(); else if (window.ActiveXObject)req = new ActiveXObject("Microsoft.XMLHTTP"); req.open("GET", url, true); timeout = setTimeout("techDif()", 5000); req.onreadystatechange = rvl_ts_sys_unable_read_disc_psurvr; req.send(null) } Was this information helpful? yes.png no.png
Dec 25, 2011 | Nintendo Wii Console
Does not recognize discs in drive: "NO Disc" message displayed
sounds like the optical pickup is going bad. replace the optical pickup part # 24801016A you can get it at www.vancebaldwin.com . there are four electronis sensors inside the pickup A,B.C,and D. this is the focus and read sensors. the laser must land on all four of the "pads" (sensors) these can appaer to work at first but soon begin to degrade their read ability. the E, F sensors can also cause this problem. no the sensors can not be replaced it's the whole assebly.
Mar 15, 2008 | Onkyo DV-CP701 Multi-disc DVD Player
Tip
Wii "Unable to read the disc" or "Disc could not be read" Messages
If you are getting one of the above error messages:
  • This message can display if you eject a disc during game play. If this is when the message displayed, make sure that you return to the Wii Menu before changing discs if you wish to play a different game.
  • If your Wii console is laying flat, it may be positioned upside down. Ensure that is positioned right-side up: the game disc slot should be above all three buttons and the SD Card slot.
    • If your console is placed vertically, the disc label will face to the right.
    • If your console is placed horizontally, the disc label will face upwards
  • If you know you are inserting the Game Disc correctly, but are still have the same problem with only one game (or if you only have one game), try cleaning the Game Disc by following the disc cleaning procedures.
If the above information did not resolve the issue or it is happening with most or all of your games, a repair is necessary.
on Mar 04, 2010 | Video Game Consoles & Games
My WII will not read any disk and we do not have a menu. All it will say is unable to read disk.
Unable to Read the Disc / Disc Could Not Be Read Situation:
What to do:
WII unit will not read disk when put in. Screen says there is an error and to remove disk but gives no other directions. What may the problem be?
    • Check our list of specific game issues to see if there is a known issue with that particular title.
    • If you know you are inserting the Game Disc correctly, but are still have the same problem with only one game (or if you only have one game), try cleaning the Game Disc by following the disc cleaning procedures (click here).
    If the above information did not resolve the issue or it is happening with most or all of your games, a repair is necessary. Please note: So that our technicians are able to duplicate the issue, please include at least one sample game disc that causes this message to appear when played. Click here to set up a repair.
Aug 23, 2011 | Nintendo Wii Console
Unable to read the disc game
Aug 20, 2011 | Nintendo Wii Console
The wii is giving the message "unable to read
  • Ensure that you are properly loading a Game Disc.
Dec 29, 2010 | Nintendo Wii Console
Wont read game discs
    this is From wii web site:
Jun 12, 2010 | Nintendo Wii Console
My Wii will not not read Wii disc's...HELP
Hello :
1:This message can display if you eject a disc during game play. If this is when the message displayed, make sure that you return to the Wii Menu before changing discs if you wish to play a different game.
2:If your Wii console is laying flat, it may be positioned upside down. Ensure that is positioned right-side up: the game disc slot should be above all three buttons and the SD Card slot.
3:Ensure that you are properly loading a Game Disc.
4: your console is placed vertically, the disc label will face to the right.
5: If your console is placed horizontally, the disc label will face upwards
6:If you know you are inserting the Game Disc correctly, but are still have the same problem with only one game (or if you only have one game), try cleaning the Game Disc
good luck .
rate please !
Mar 20, 2010 | Nintendo Wii Console
Philips HTS3544/37 Theater System Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
