Question about Zanussi Ovens
Zcv550mxc cooker What ampage power supply is required
The grill and ovens on my Jackson Topline cooker have just stopped working, the rings work but none of the lights above the switches are on when they are working, any Ideas please? thanks.
I am not familiar with your model of cooker but I assume it is a gas cooker.
Gas cookers have safety devices in the oven and grill the hob rings do not need. I speculate even the domestic oven hasn't escaped the interference from the electronics industry and I expect the aforementioned safety devices depend on (low voltage) electronics and electronics depend on electricity - that the lights aren't working would suggest there is no (low voltage) electricity.
Even in the case of an electric oven the thermostat could be electronic and need (low voltage) electricity to work.
I suspect the internal power supply has failed.
Jun 17, 2016 | Ovens Ovens
My zanussi cooker isn't working after a power cut...even the timer/clock isn't flashing to reset wht can I do
Claire. Have you checked the cooker supply switch? (Usually on the wall near the cooker) If it has a neon light is this on? If not or no neon check the circuit fuse/mcb in the fuseboard. Allan Pointer.
Apr 06, 2016 | Zanussi Ovens
Total electrical output
Bad news really, the supply cable you have there is not going to be capable of supply to any type of electric oven and hob like you listed above. Your supply cable is possibly only 2.5mm in size, and not the required 6mm with a much higher MCB at the fuseboard. Get a registered electrician to run a new cable from the board to your cooking area. A single oven takes about 3.2Kw adding the hob rings will take way over your limit. Curry's listing of that cooker as a load of .75Kw or thereabouts is obviously incorrect.
Jan 15, 2014 | Ovens
HOW TO WIRE A SINGLE INTEGRATED OVEN? Can it be wired into the mains cooker point?
An integrated oven that has a 13 amp plug can be wired into a cooker point without any concerns since you are wiring it into a feed that is capable of handling a greater power requirement than is needed.
For the avoidance of doubt, the other way around, if you are considering putting a 13 amp plug on a unit that is designed for direct hardwiring into a cooker point, you should think again because it is probably capable of drawing more current than the 13 amp socket could safely handle
Jul 19, 2011 | Ovens
MikeandI have just purchased a Zanussi electric oven model no.ZCV550MXC but can't find in the instruction book how long to preheat the ovens for Can you help?
Your best solution for this and all the other problems you may have as a result of losing your manual, is to go to http://www.zanussi.co.uk/node182.aspx put in your model number, hit return and click on the PDF manual it offers you. Then you will have an answer to all your questions.
Feb 09, 2011 | Zanussi Ovens
Daughter had cooker delivered today,is this model surplied with cable.
If it is a single cavity built in cooker, then they are usually supplied with connecting cable, but if it is a full size cooker, then it is not normally supplied with cable,
Mar 18, 2010 | Ovens
Cooker clock requires resetting
You need to press 2 or more of the timer/clock buttons in seqeunce to cancel the auto setting.
The sequence of buttons varies according to the make of cooker, so just keep pressing the buttons until you hit the correct sequence.
Hope this helps.
Jan 06, 2010 | Ovens
Zanussi Electric Cooker and Hob don't work properly
it will have nothing to do with the supply, although it does sound as though he could have done a better job. if the appliances are brand new get Zanussi out to it. shame on the guy for not checking that they worked as they should. hope this helps.
Feb 17, 2009 | Zanussi ZHQ575 Electric Double Oven
Ovens Logo
18 people viewed this question
Top Zanussi Ovens Experts
ashburton
Flipper
Level 1 Expert
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
