Question about Philips Lands Phones
How to delete telephone numbers from repertoire
I am trying to fax and it says "poor line condition/out of memory" please help on what to do
> poor line condition
Disconnect it from the telephone wall-jack.
Connect a telephone-handset to that wall-jack.
Make a call to the FAX-number that you are trying to reach.
Listen. Do you hear "noise" or "static", due to terrible telephone-wires,
either from your location to your nearest telephone-exchange,
or from the target telephone to their nearest telephone-exchange.
> out of memory
Use the control-panel on the printer to delete "old" sent/received FAX documents, to clear-out some memory.
Apr 14, 2011 | Brother MFC-8460N All-In-One Printer
Have a Konica Minolta Di2510 copier. Need to remove the phone number people see on the sent received fax copy. Delete it completely.
Im going to list in order the buttons you have to push.
  1. Utility Button (The only actual button on the control panel. The rest are buttons on the display screen)
  2. Admin Management (The Default pass word is "12345678". After you enter the password hit the end button.
  3. Admin 1
  4. Initial Settings
  5. Self-telephone # info
  6. Self-telephone #
You can delete the number completly or make it any number you want to. Hope this helps.
Mar 04, 2011 | Konica Minolta KonicaMinolta PagePro 4650...
How do you delete contact names and telephone numbers
Go to contact list, all your names will appear. Press options, then multi delete. You can delete which ones you want to. Or press bottom left of screen (looks like 4 dots) then address book then scroll down to delete all contacts, this will delete all at once.
Aug 22, 2010 | LG Vu CU920 Cellular Phone
Display most recent Caller ID telephone numbers not old ones
You have a 7730 PHONE. The system is not determined, but in analog going forward it could be a TA-624/824 or TAW-848.
If you have a TA system, it requires programming http://www.fixya.com/support/t2436730-caller_id_stoped_working_dont_know_clear
Carl
Jun 26, 2009 | Panasonic KX-T7730 Corded Phone
Onetouch 4 internal error 8211
That error occurs when the 3 Quickbooks files don't have the same date. I'm not sure how they get out of synch, but if you check the dates of the files on your Maxtor backup, you'll find they are different.
The easy solution is to delete the files from your Maxtor backup, and then immediately do another backup. Maxtor will copy the current files over and you'll be all set.
Oct 26, 2008 | Maxtor Hard Drive
OLD TELEPHONE NUMBERS
enter the new number that you want to save and the old number automaticaly deleted
Jul 24, 2008 | Bulova Watch
Lands Phones Logo
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
