Question about 1986-1997 Nissan Pickup Side View Mirror
Power to coil no power coming out replaced and still samething
Computer only shows red light nothing else
    Sergeant:
  • 253 Answers
You could have gotten a bad one, try another one
Posted on Aug 14, 2014
My Toyota avanza catalistic convetor gets red hot,I was told it has clogged.I have bought a new one over the weekend but it still does the samething.
It could be a number of things. Your oxygen sensor comes to mind first. It tells the computer it is too rich or lean and the computer tells the throttle body and injectors to either lighten up on the fuel or add more. If it isn't working properly it can be in a rich mode telling the computer to ease up on the fuel causing the engine to run lean and cooking the catalytic converter. DON'T PARK ON DRY WEEDS!
Nov 28, 2016 | Toyota Cars & Trucks
Sony DHC FLX5D hifi system shows a red light near power on switch but won't start
You opened the case to check the fuses, do that again and look at the devices that resemble small cans. See if the are bulging, leaking or exploded.
Jan 06, 2014 | Sony Audio Players & Recorders
PS3 wont power up
try another outlet if the light still will not turn green you will need to contact sony,
if the light does turn green let me know and we will get this fixed
Dec 24, 2011 | Sony Playstation 3 (PS3) Console
Replaced bulb in Sharp XG-E1200U, the red power light comes on, when I turn the switch on nothing happens.
When the XG-E1200U shows the standby light but does not power on, it usually means several of the 100uf 16 Volt surface mount capacitors have dried up on the main board. Recommend replacing all of these for continued reliability.
Sep 03, 2010 | Sharp (BQCXGE1200U1) Projector Lamp for...
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
When I hit power button on computer, power light doesn't come on...and the fan kicks on, but nothing else happens. nothing shows up on monitor except the test screen with 3 colors...the computer doesn't...
THis sounds like a power supply issue.. I had a similar issue with mine. my fan would kick on for about 2 seconds then shut off.
Hope that helps
Ciza
Oct 29, 2008 | Gateway (4000274) Motherboard
Ignition coil
yes it can be a bad coil or improperly installed coil they do have a plus and minus for the coil
ignition coils come in different modes of power make sure by dealer the right mode of coil was used and installed
the computer after a replacement like this make sure that the tech reset the computer so that it can read properly if the comp was not reset you might get the same error again
May 29, 2008 | 1998 Ford Windstar
No boot
Sounds like the motherboard is getting power to the lights but not to the rest of the computer. try to drain all the power out of the laptop by unplugging it and holding the power button for 30 seconds. Then plug it back in and try again if this does not fix it your motherboard is probably shot and would need replaced.
Jan 21, 2008 | Compaq Armada 1700 Notebook
Sceptre X7g Monitor Flashing Red & Blue Lights. Blank Screen
i fixed this problem by unplugging the monitor, unplugging the video cables. Then hold down the power button while plugging it back in. Release power button and then press power button for on. It worked then. I got the icon for no signal, i plugged back in my monitors. Sceptre X9W
Sep 11, 2007 | Sceptre X7GNAGAV 17" LCD Monitor
1986-1997 Nissan Pickup Side View Mirror Logo
Top Hardbody Pickup Vehicle Parts & Accessories Experts
ray gallant
David Harrelson
David Harrelson
Lawrence Oravetz
Are you a Hardbody Pickup Vehicle Part and Accessory Expert? Answer questions, earn points and help others
