Question about Shark SHKMSDHRS6160 250w Motorcycle Audio w/ 2 speakers FM splash proof remote
Wired remote bad
Looking for replacement
Thermostat model UMC 117 keeps coding C7 why?
Generally, C7 is communication problem with remote
Error codes are considered start point for troubleshoot.
Causes can be: Bad remote, bad wire to remote, loose wire connection at remote, loose wire connection at unit, bad PC board.
In no particular order:
Check wire connections.
Disconnect remote and let water heater control temperature at default 120 degrees F, and if no further problem develops, then that might eliminate PC board as source of problem.
Replace wire to remote.
Replace remote.
Call service technician to diagnose problem.
Contact Rheem about PC board and other options.
Before calling service technician, open following links for troubleshooting resources:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
Aug 14, 2011 | Rheem Tankless Hot Water Heater...
Hi! I have a Samsung Series 3 32" LCD. Just recently the TV seems to be malfunctioning. The remote has stopped working, If the source is set to PC, it will change to TV by itself and then flick...
Sounds like you have a bad keyboard. Unplug the set and take the back off. Look where the keyboard is and follow the wires to the main board. Your looking for a pinched wire. If you find one, put a little electric tape around it and move the wire away from what is pinching it. If the wires are fine then you need to replace the key board.
Jul 14, 2011 | Televison & Video
I have a Liftmaster garage door opener & remote. The remote began to work only intermittently. I replaced the battery (I didn't reprogram remote when battery was changed & remote worked for a...
COULD BE A BAD REMOTE, I WOULD TRY ANOTHER ONE FIRST.
COULD BE A FREEZER ETC. PUTTING OUT INTERFERENCE.
OR
Anytime a door opens and/or closes randomly or doesn't work consistently I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote signal.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone
Nov 10, 2010 | liftmaster Chamberlain Garage Door Opener...
I have a problem code...its says check EO
Signal transmitting/receiving
error
(Indoor controller does not
respond to remote controller
signal.)
During individual unit control
1) Bad contact of transmission
wire
2) Signal transmitting/receiving circuit
is abnormal.
1) Check the transmission wire.
2) Check with another remote controller. If "EO" is
still indicated, replace the indoor controller
board.
If other check code appears. replace the original
remote controller.
P3 Signal transmission error
(Remote controller does not
respond to indoor controller
signal.)
wire
is abnormal.
3) Wrong operation due to noise
wave emitted
Nov 10, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Door opens by itself in storm
Here are some things you can check.
Look at the LED light next to the SMART/LEARN button on rear of the motor unit. You may need to remove a light lens cover in order to see it. If the light is flashing rapidly this means you have a stuck button on one of your remote controls. Take the batteries out of each remote control. When you remove the batteries from the bad remote, the light will stop flashing. This remote needs to be replaced.
If one of your neighbors remote controls is inadvertently programmed into your receiver, you door will open when their remote is activated. If this happens you will need to clear out your receiver and reprogram your remote controls. Press and hold the smart/learn button for 6 seconds or until you see the small LED light near the button turn itself off. If the above steps have been followed and the symptoms continue, there may be an electronic short in either the wall control button or the receiver logic board. In this case, remove the wall control wires from terminals 1 and 2 on the motor unit. Should the symptoms persist after the wires are removed, replace the receiver logic board. If the symptoms stop with the wall control wires removed from the motor unit, replace the wall control button, and the wires leading to the wall control button.
Aug 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 139.18415 opens intermittently by itself why? Can I change the Channel?
You can't change the channel but here are some things to look at.
Look at the LED light next to theSMART/LEARN button on rear of the motor unit. You may need to removea light lens cover in order to see it. If the light is flashingrapidly this means you have a stuck button on one of your remotecontrols. Take the batteries out of each remote control. When youremove the batteries from the bad remote, the light will stopflashing. This remote needs to be replaced.
If one of your neighbors remotecontrols is inadvertently programmed into your receiver, you doorwill open when their remote is activated. If this happens you willneed to clear out your receiver and reprogram your remote controls.Press and hold the smart/learn button for 6 seconds or until you seethe small LED light near the button turn itself off. If the abovesteps have been followed and the symptoms continue, there may be anelectronic short in either the wall control button or the receiverlogic board. In this case, remove the wall control wires fromterminals 1 and 2 on the motor unit. Should the symptoms persistafter the wires are removed, replace the receiver logic board. If thesymptoms stop with the wall control wires removed from the motorunit, replace the wall control button, and the wires leading to thewall control button.
Jun 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door is opening randomly
Mar 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Amp not working at all, replaced fuses, checked connections on battery and amp but still no power, what other troubleshooting can i look for
flip the amp smell the vents if it smells like a blow dryer or just something awful its burnt up agin check connections on the battery if all els fails take a short wire and touch it (A) on the positive wire from the battery (B) to the remote wire do this all on the amp it should come on if so your remote wire is bad or has lost connection
Feb 03, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
Garage door opens and closes randomly without anyone being around
Some things you can check.
Nov 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door open by its self
Nov 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Shark SHKMSDHRS6160 250w Motorcycle Audio w/ 2 speakers FM splash proof remote Logo
18 people viewed this question
Top Shark Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Shark Audio Player and Recorder Expert? Answer questions, earn points and help others
