Router declare itself as gateway
My ISP said my router declare itself as gateway and all traffic go through my router.
I have upgraded software version to 1.08.00 (23 Dec 2008 14:39:14) - results the same.
I know the same problem there is on the LinkSYS routers and it fixed with upgrading to new version of software.
Router - 3COM 3CRWER300-73
Thanks to all.
    Sergeant:
  • 322 Answers
Go to your browser, type your gateway ip and go to the router settings. In advance routing, there is a dropdown menu there where you can change the router setting to either gateway or router. Click and choose router.
Posted on Jun 14, 2009
I have a Netgear DG834G v4. Wireless connection is fine, ISP is fine and Internet via wireless is perfect. Nothing via the LAn ports seems to work. Both XP and Win 7 machines see Lan as an undefined...
DHCP SERVER in Router and DHCP server in Wireless Conflicting - Set WI Fi DHCP router leases to say 192.168.0.10 to 192.168.0.100 and default gateway as 192.168.0.1 and on the router set the router's ip address to 192.168.0.1 make the Wi Fi router address 192,168.0.2 . Set in the router the DHCP address leases to 192.168.0.101 - 192.168.0.254 and default gateway 192.168.0.1 or deactivate one of the dhcp servers and rely on one dhcp server like the routers and then deactivate the wi fi's dhcp server.
Jul 28, 2017 | NetGear DG834G 54 Mbps 802.11g Wireless...
I have a belkin adsl g router model f5d7633-4 will this support voip and g729 codec
The router can support voip as long as your ISP provider will allow to pass voip traffic. regarding the g729 codec. it will also allow it as long as your pbx server (or software) can support it.
Dec 23, 2009 | Belkin (F5D5231-4) Router
Is this modem upgradable to docsis 1.1
Yes this can be upgraded to docsis 1.1 and you can get the update from your ISP for this device
Sep 16, 2009 | Arris SBG1000 Wireless Cable Modem Gateway...
ADSL ISP provides same address for IP and Gateway
Can you manually change the WAN IP on the router?  If so, give it an IP like 123.12.167.5 and set the gateway address to 123.12.167.1.  If it asks for a subnet mask, give it 255.255.255.0.
If she has a Linksys router, you may need to change the operating "MODE" on it.  A lot of Linksys routers have 2 modes of operation---Router mode and Gateway mode.  For her configuration, make sure the Linksys is in Gateway mode.  This will fix the NAT problem.
Cheers!
Mar 26, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
2wire 2700HGV cannot detect wireless Linksys IP camera WVC54GC
Purchase a different router and return the 2wire to the ISP explaining it is not compatible with your equipment at home. You may need to provide them with the new router's MAC address.
Nov 21, 2008 | 2wire 2700HG-B Router (2700HGB)
Will sync but online LED won't work
4 Select the connection type from the Connect Type drop-down menu. ? Always Connected means that Internet connection to your ISP is always on. ? Auto - Triggered by Traffic means your Router will automatically connect to your ISP every time a PC needs to access the Internet. ? Manual - Start in Disconnected means that after re-booting the Router, the Internet connection will need to be re-established manually by the user. ? Manual - Start in Connected means that after re-booting the Router, it will automatically establish a connection to your ISP.
(from http://h20628.www2.hp.com/km-ext/kmcsdirect/emr_na-c02582095-1.pdf )
this sounds like Manual - Start in connected mode will get the ip address and dns settings automatically from the ISP
using adsl on phone line then use pppoe for the protocol
DCHP server has to be set up also and on
The DCHP server ip address range is 192.168.1.20 to 192.168.1.254 with subnet mask 255.255.255.0 and default gateway is 192.168.1.1
pppoe protocol allows the ADSL to connect many computers on the one isp global ip address allocated to your line via using different port numbers to translate the computers internal ip address on the dhcp server through the router.
Jul 01, 2017 | 3Com OfficeConnect Router
Ip assigning
hello!
-- what is the exact model number of your router?
-- the ip address that you are trying to assign to your router, is it provided to you by your isp?
-- what is your nrtwork setup?
1. try to reset the router and try again to assign the static ip address.
2. make sure you will input all ip address correctly including the subnet mask, gateway and dns numbers
3. if its still not working try to upgrade the firmware or software of your router, maybe its corrupted thats why its not accepting the settings
Apr 28, 2008 | Lucent CellPipe 20S Router
Wi Fi fine, ISP fine, no internet via LAN connection though.
Make sure your firewall is not blocking your ability to go to websites. I saw this the other day, somehow the users firewall was set to block all internet traffic out of the computer.
Jan 21, 2008 | NetGear DG834G Router
Re broadband speed.
to upgrade your router software..
Nov 19, 2007 | 2wire 2700HG-B Router (2700HGB)
Computers & Internet Logo
82 people viewed this question
Alun Cox
David Payne
David Payne
