Question about HSM 225.2 Shredder
Electronic eye does not work
Shredder will not operate. electronic eye may be damaged
How do you clean the "eye" on the Aurora AS1219CD? I heard that may be the problem with it not taking paper. But I am not sure how to go about it.
the best way is to take a q-tip and alcohol and rub the eye if you are facing the shredder it should be on the front but that is th only way we have to do it
Oct 17, 2013 | Aurora Electronics AS1219CD (CrossCut)...
Unit no longer shuts off when on "Auto" setting. I have to use this switch manually to turn unit on and off for every use, and would like to restore original functionality.
Don't know what kind of shredder is is but most have one or two eyes or switches that tell the shredder to start and also tell is to stop. these eyes get paper dust on them and will not shut off
, or they could be bad eyes or switches. Use can air and blow down in center of shredder gears and see if it solves problem. Also shredders shuld be lubricated with shredder oil every now and then....
Sep 20, 2013 | Staples Executive EPS711X Shredder
My Royal 12X paper shredder runs only in reverse but will not run forward. I have noticed other postings regarding cleaning the sensors with rubbing alcohol ant that has been done but was not succesful. ...
If cleaning the eyes did not help then you will likely have to change parts ...you can contact Royal at 1-800-524-0799 for parts and pricing information.
Oct 29, 2010 | Royal CIA 12X Shredder
Shredder does not work for input but does work in reverse
Check the optical eye for debris, or the paper safety for proper operation.
Something is happening with the safety switch - it is not recognizing there is paper there.
Thanks for using FixYa!
Nov 03, 2009 | Fellowes 3011001 Shredder
Motor works only in reverse direction only.model sh1524cp
Your shredder thinks it is jammed ... did you clean the electric eye or the small lever - does it work freely?
Can you use canned air to blow dust out of the top? Have you cleared any paper stuck at the bottom of the unit?
Try these things - I have had occasional success with this kind of fiddling around.
Oct 18, 2009 | Aurora Electronics AS662C Shredder
Exploding paper shredder - very dangerous
I'd call your lawyer and tell him you can't touch any machinery which contains an electric motor because you have been psychologically damaged. Maybe Fellows will settle out of court.
Otherwise ring your local 7:30 current affairs news program.
I don't know why their motor would not be shielded from paper dust.
It is no big surprise that it may be dusty in there.
I'm glad you did suffer any permanent physical damage.
Oct 05, 2009 | Fellowes DM15C Shredder
Stopped working. will operate in reverse only
When shredders only work in reverse, it typically means that they are really jammed up. First thing to do is to UNPLUG the shredder. Then, take a look at the underside of the teeth. You will most likely see a bunch of paper sticking out, if so, try to remove it. I would advise against using your fingers, though.
As a last resort, get someone who is mechanically inclined to take the head unit apart to remove the jammed pieces. Unfortunately, once this happens, it often spells an early demise for the shredder. I have gone through three of these things for the very same reason.
Mar 19, 2009 | Intimus 250 Shredder
Shredder shuts off when shredding, and runs continuely when running
take a q-tip and clean the eyes, if that doesn't work you may have baad eyes or a bad board.
May 09, 2008 | Office Equipment & Supplies
Kobra 240 paper shredder
i had one similar to this i took the cover off and cleaned the sensors in the electronic eyes also there are two relays on the main board that get hung up just tap them. i cleaned real good the machine seemed to work ok after that
Apr 21, 2008 | Office Equipment & Supplies
Won't shut off after shredding.
I FIXED MINE!!! Hey folks same problem AS1018CD would not shut off. CURE: Take apart and clean electronic eye. PROCEDURE: 1. Unplug. 2.  Remove shredder and turn upside down. 3. Remove 6 phillips head screws on back of unit ( 1 is under sticker in middle peel back sticker to access screw. 4. Carefully separate unit. 5. Pull off shredder piece. It is a snug rubber grommet fit and just lifts off( gears everything comes off as one piece. 6. Electric Eye is exposed remove screw holding in and gently slide out and wipe clean. Do both sides. While apart clear all debris and wipe entire unit as clean as you can. Put gear assembly back on grommets. Put top and bottom back together. Replace screws. Plug in. FIXED :-)
Sep 14, 2007 | Aurora Electronics AS1018CD Shredder
HSM 225.2 Shredder Logo
59 people viewed this question
Top HSM Office Equipment & Supplies Experts
Andrew Taylor
Andrew Taylor
ray gallant
ka4iup
ka4iup
Are you a HSM Office Equipment and Supply Expert? Answer questions, earn points and help others
