Question about HEWLETT-PACKARD G56-129WM Laptop PC
User profile cannot be loaded
How do I restore my User profile?
Asus k53u accepts password then comes up the user profile service service failed the logon user profile cannot be loaded How can I get round tis problem ?
Start in Safe Mode and then do a system restore back to a date when it was ok. If that fixes it, immediately create a new restore point and name it Profile OK. (Just in case you get it again) This fault has been occurring for months now and usually after an MS critical update! Good backup strategy is paramount.
Sep 04, 2014 | ASUS K53UA1 Notebook
My computer will not let me into the administrator sigh in screen which is me, it aceptes my password but then says unable to load user account
Hello.
If your computer is unable to load the user account, it usually means that your user profile is corrupted.
Boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date when your system worked OK.
To access System Restore in Windows 7: Open the Start Menu. Click on All Programs, Accessories, System Tools, and System Restore.
Hope this helps.
Apr 06, 2011 | Acer Aspire 5315 Notebook
On booting up my Inspiron mini 1012 netbook it keeps displaying 'the user profile service failed the logon' and 'user profile cannot be loaded'
Try logging in on the admin acct then delete and recreate the profile. If it doesn't work you can try switching off the comp then continously press F8 while turning on the comp and choose safe mode, then do a system restore.
Mar 18, 2011 | Dell Inspiron Mini 1012 Netbook...
It will not let me sign in its sayin failed
Please refer the article to resolve the issue.
http://www.vistax64.com/tutorials/130095-user-profile-service-failed-logon-user-profile-cannot-loaded.html
If the issue still persist even after performing the steps, try restoring the Computer to earlier point.
Mar 15, 2011 | Computers & Internet
The problem sayes can not load user pfofile,even It can not boot from the cd-drive
User Profile cannot be loaded-if this is the problem try this:
1.Boot in Safemode. Tap F8 upon turning ON to enter advanced boot option.
2.Select Safemode. Once loaded, do system restore.Follow the steps here(http://support.microsoft.com/kb/948247)
Mar 01, 2011 | Toshiba Satellite Pro L300-EZ1004X...
User profile service failed the login user profile cannot be loaded tried restore to earllier date, changed password
The operating system is corrupted. may need to do a re-installation or Operating system repair. If you mange to get Command mode on the run a check disk
Jun 09, 2010 | Compaq Presario 5000 PC Desktop
Trouble booting vista
This issue may occur if the user profile was manually deleted by using the command prompt or Windows Explorer by a user or by some program. A profile that is manually deleted does not remove the security identifier (SID) from the user profile list in the registry. Since the SID is still present, Vista will still try to load the profile by using the ProfileImagePath that points to a nonexistent path. Therefore, the profile cannot be loaded. This can also be a issue with the user profile entering into a backup state. Manually renamed the C:\Users\(User Name) folder. You can try doing a System Restore at boot to see if it can fix this. If you do not want to repair the user profile, you can delete it and create a new user account If this still does not work for you, then you will be left with doing a clean install
Dec 28, 2009 | Microsoft Computers & Internet
Cant log in to Toshiba A300-1J1
What I would suggest is logging on in safe mode and trying to restore it to an earlier date using system restore. likely the profile is corrupted. By doing a restore back about 4 to 7 days , or before this started happening, will likely fix your issue. If not you will have to purchase the restore cd from toshiba or restoring it from a recovery partition if it has one.
Jul 03, 2009 | Toshiba Satellite Laptop with AMD Athlon...
Logon failed
  • You can try doing a System Restore to see if it can fix this before using the instruction in the tutorial below. See the related links below for how.
  • If you do not want to repair the user profile, you can delete it and create a new user account in OPTION TWO. If this still does not work for you, then you will be left with doing a clean install for your Upgrade or Full version of Vista.
Mar 20, 2009 | Packard Bell iMedia 6826 (P481000502) PC...
HEWLETT-PACKARD G56-129WM Laptop PC Logo
16 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Bilal Ahmed Qureshi
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
