Question about Dell A215 Computer Speakers
MY AIR CLEANER BLOWER WILL NOT WORK
BLOWER USED FOR HEAT AND AIR CONDITIONING
2001 Chevy blazer air conditioning blower is throwing very little air. what and how I can get it back to normal?
Is the issue there when using heat and air-con?
If so, then check the blower motor and fan switch for fault.
Check any cabin air filter if fitted for clogging.
If only an issue with hot air flow, then check the heater matrix hasn't bunged up.
If only a cold air flow, then check the air conditioning car evaporator in the cabin for signs of clogging.
Clogging can be more of an issue in pet owner's cars as pet hair readily clogs up these two components in cars fitted with no interior air cleaner element/filter.
Nov 05, 2012 | Cars & Trucks
Air conditioning blower stop working is it a a costly problem
NEW CARS HAVE ELECTRONIC CONTROL MOD MOUNTED ON
THE BLOWER MOTORS YES BOTH GO BAD / IF YOU ARE
HANDY WITH TOOLS THIS SHOULD COST NO MORE THAN
$200.
Oct 25, 2012 | Air Conditioning and Heat for Pontiac...
Air conditioning for pontiac g6
Need more specifc info.
If no air is moving, it could be the blower motor.
I've owned several Pontiac models, and have noticed heater blower motor problems.
My son own a 2003 Pontiac Bonneville. One day he said when he turned on the heat that no air was moving, I removed the heater blower motor and throughly cleaned it. I hooked up back up and it worked fine. The motor can get dirty form accumlated dust and grim. Do a search online for its location.
Good luck.
Jun 14, 2012 | Air Conditioning and Heat for Pontiac G6
Air conditioning
check blower motor resistor common problem on most vehicles..
Jul 11, 2010 | 2004 Infiniti I35
The heating and air condition does not blow
start by checking all your fuses, next if fuses are good then check the blower motor resistor, these resistors go bad often,its located in engine compartment,on the rightside on blowermotor housing
Mar 01, 2010 | 1994 Pontiac Bonneville
Air nor heat works the blower doesn't come on
leak in the radiator? Check your coolant...
Apr 28, 2009 | 2001 Ford Taurus
Heating and air conditioning
The blower motor works on high setting ONLY when the blower resistor is bad. The blower motor resistor is held in place with 2 screws and attached into the heater housing under the right side of the dashboard. You can identify the resistor by the big wires that are connected to the connector. If this heating/cooling system is the auto temp type, the part is a bit high on the price.
Feb 10, 2009 | 2005 Jeep Grand Cherokee
Replaced the blower motors and had Air Conditioning. Now no heat
Thank you, however, I have the problem under control.
Jan 09, 2009 | 1999 Dodge Intrepid
1995 Buick Lesabre- heater blower
Notes Electronic Automatic (RPO C68)/ Dual Zone Air Conditioning (RPO CJ2) 62396444
Jan 09, 2009 | 1996 Buick LeSabre
Dell A215 Computer Speakers Logo
Top Dell Audio Players & Recorders Experts
jairo sanchez
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
