Question about Home Security
Siemens jsjs217 only works after i remove battery and put it back in
Reset bios password
First make sure battery is out and it is not plugged in then take off the bottom of the notebook and look at the motherbord and locate a small CMOS battery (See Picture) and remove the battery. Leave the battery out for about ten minutes and then put the battery back in and put the bottom of the notebook back on. When you start up your notebook and boot into bios your bios will be completley reset.
Jul 08, 2013 | Fujitsu Siemens AMILO Pro V2000 Notebook
Not showing correct battery level
remove batteries; put batteries back. The level will return to normal
Feb 18, 2013 | Siemens GIGASET-S795 GIGASET-S795
How to remove bios password fujitsu siemens laptop
You will have to remove the power cord, remove the battery and then start taking the laptop apart to get to the CMOS Battery that is on the motherboard. On Desktops the CMOS battery looks like a silver nickel and you just take a small flat head screw driver and pop it out. On most laptops it will be inside a vinyl cover and have a cable that plugs into the motherboard, just unplug it. Let the CMOS Battery stay off for 1 to 2 hours then put it back. When you reboot the system will have forgotten the date, time and passwords.
Mar 26, 2012 | Acer TravelMate 2300 Notebook
I will reset the password of bios (pc fujitsu-siemens scenic p300) Grazie Gero gerog@libero.it
There is a jumper on the motherboard that has 3 pins put jumper on other side for 5second and then put back with the power turn off.Or remove battery for a couple of minutes. That will reset the Bios.
Feb 06, 2011 | Fujitsu Siemens SCENIC P300 PC Desktop
My lifebook s7010 won't startup. After put the on button the screen still remains black. The fujitsu logo will not appear on the screen.
Unplug the AC adapter from power cord, then remove the battery.Wait 30 min and put the battery back.Plug the AC in power cord and try again.If not start you need check AC adapter with voltmeter.If the AC working your computer need service.
Nov 10, 2009 | Fujitsu Siemens LifeBook S7010 Notebook
Fujitsu siemens notebook s6120 laptop switching itself off
the processor fan might not be working due to which the laptop gets heated up and switches off. if u dont replace it u might end up burning the processor.
May 17, 2009 | Fujitsu Siemens LIFEBOOK S-6120 PC...
Fijitsu siemens laptop wont turn on
Try removing the battery and cord for a few minutes, then put the battery on, and plug it in. Leave it like that for 10 minutes before turning it on.
Aug 23, 2008 | Siemens Computers & Internet
Screen says USB or Serial on top and v2. 07 at the bottom
Open the Back Cover.. remove the Battery, Simcard, Memory Card and then leave it open for 1 minute.
Put the battery back, start your device then if you get the same message you need to update the firmware...
In the worst scenarios, your Siemens SX66 has a corrupt ROM and need to be fixed as in "Hardware"... which can be done by a Siemes expert.
Good Luck
May 23, 2008 | Siemens SX66
Siemens A65
just replace your cellphone with a new one!!!
Mar 11, 2008 | Siemens A65
Home Security Logo
14 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
