Question about Nordic Track NordicTrack Treadmill, A2550
The display is blank and will not turn on, belt will not turn on....power cord is lit
Unit comes on,runs for ten seconds,(w sign on page on screen)then turns off.
"Hello, Sounds like you have a bad monitor, or video cable, replace."
Nov 08, 2015 | Computers & Internet
Lights on but not cooling, LCD display is lit up but blank
The LCD is light up by the lights in the refrigerator, so that doesn't mean the board is turning on just the interior lights. I would have to recommend a service call.
Sep 21, 2013 | Sub-Zero Refrigerators
Just got cq56-115dx laptop this morning. turned it off after setting it up. Turned it back on and only have blank screen. Power shows lit up.
Hi.
Remove the AC power (charger) and then take the battery out. Plug in just the AC power supply and turn the laptop on, see if it boots up and shows a display on-screen. If it boots let it boot up and then shut it down as normal. Reinsert the battery and try as normal.
If you still get a blank screen can you then tell me if you get any post (splash) information like the Compaq Presario logo before it goes blank.
Good luck.
Jun 28, 2011 | Compaq Presario CQ56-115DX Laptop
No display
The following applies to Acer Laptops...
If the power indicator is lit but nothing appears on the screen - The computer's power management system automatically blanks the screen to save power. Press any key to turn the display on.
If pressing any key does not turn the display back on, check the following....
1. The brightness level might be too low. Press Fn and the right cursor key to increase brightness level
2. Display device might be set to an external monitor. Press Fn and F5 to toggle to the internal display
3. Backlight might be turned off. Press Fn and F6 to turn on the backlight.
4. If the Sleep indicator is lit, the computer is in Sleep mode. Press & release power button to resume.
May 09, 2011 | Acer Aspire One PC Notebook
My HP Officejet 7410 Unit is powered and the HP Invent logo is displayed on the screen with the progress bar moving at the bottom, but the power button is not lit and none of the other printer functions...
I will advice you reset the printer, follow the steps below to reset the printer,
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold ?# and 6? keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
If that did not fix the problem, try this,
  1. Unplug the power cable from printer while the printer is powered on.
  2. Press and hold OK and HELP buttons while plugging in the power cord. Wait for the screen to go black or blank before releasing the keys.
  3. Just turn on the printer and configure your printer new.
The problem should be fix with this.
Take care.
Sep 14, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Maytag MDE7500ay dryer with LCD display. The screen is lit up but the display is blank. No words. Unplugged and plugged back in.
It is possible that the electronics section has encountered the following.:
1. Failure of Power to the main board.check the power supply.
2. If P.S. is OK.then Failure of the microcontroller / display drive.
3. If OK then the cord/connection of the display.
If mP is a suspect then the main board can be faulty.
Sep 11, 2010 | Maytag Neptune MDE7500AY Electric Dryer
My problem is a weird one. My family has had a Photosmart 3310 All-In-One printer for a while now (I'd say about 3-4 years), and it's worked fine until recently. Now, the light is on around the on button,...
Hi, I suggest you do a full system reset on the printer and see if that fixes anything. Please do the following. Come back and check with me if it doesn't work.
Performing a semi-full reset of the All-in-One
  1. Use the Power button to turn on the product.
  2. Unplug the power cord from the back of the product.
  3. Press and hold the # button and the 6 button.
  4. While holding the buttons down, plug the power cord into the back of the product.
  5. Continue to hold the buttons down until the control panel display goes blank.
  6. Release the buttons, and then use the Power button to turn on the product. The reset information appears on the control panel display.
Aug 12, 2010 | HP Photosmart 3310 Printer
When printer is turned on it reads 256MB and that is it. No menu buttons or anything else will work. Never get ready light.
First, try to unplug and wait 30 sec. then replug the printer into the wall to try to reset it. Then, read below to see if there is a solution if the '256mb' display problem persists. Control panel display is blank No display message Cause Solution The printer’s on/off button is in the standby position. Verify that the printer is on. Fans might run while the printer is in standby mode (off). The printer’s memory DIMMs are defective or installed incorrectly. Verify that the printer’s memory DIMMs are correctly installed and are not defective. The power cord is not firmly plugged into both the printer and the power receptacle. Turn off the printer and then disconnect and reconnect the power cord. Turn the printer back on. The line voltage is incorrect for the printer power configuration. Connect the printer to a proper voltage source, as specified on the Power Rating Label on the back of the printer. The power cord is damaged or excessively worn. Replace the power cord. The power source receptacle is not working correctly. Connect the printer to a different power receptacle. Printer is on, but nothing prints Cause Solution The printer’s Ready indicator light is not lit. Press STOP to return the printer to the Ready state.
Jul 14, 2010 | HP LaserJet 4700 Printer
Blank Monitor on my DELL
Your display is having problems with the Inverter that generates high voltage to lit the lamp.
This issue is explained (including how to fix it) here:
http://josepino.com/?howto-repair-dell
Good luck
May 07, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
DR-C500 problem with turning the system ON
Make sure all power connectors, cords and plugs are inserted securely and that the outlets are in good working order Be sure to select an audio source (CD, AM/FM, etc.) For powered systems, unplug the power pack for a few seconds, and then reconnect it. This allows the unit to reset itself after a power surge or power interruption. good luck!
Jan 07, 2006 | Onkyo DR-C500 Multi-disc DVD Player
Nordic Track NordicTrack Treadmill, A2550 Logo
14 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
