Question about Ryobi Garden
Plug gap rlt30cd - Ryobi Garden
NEED SPARK PLUG GAP FOR 9BSXS 190-1VH
The gap is .040 and is pretty much a standard gap.
May 17, 2017 | Cars & Trucks
What is the spark plug gap for the above car which is 4 cylinder. thanks
1988 Oldsmobile Cutlass Ciera, original GM plug gap .045".
this is what i would gap new plugs too, AC Delco Part # R44LTS plugs probably gaped at this already.
press the helpful button
How To Change Spark Plugs on 1987 Cutlass Ciera SL 3 8L
Spark Plug Gap NGK Spark Plugs Tech Video
How to Gap Spark Plug
Feb 04, 2016 | 1988 Oldsmobile Cutlass Ciera
Spark plug gap
How to Gap a Spark Plug - YouTube
? 2:57
https://www.youtube.com/watch?v=IuW3svdqKZM
Oct 15, 2012 - Uploaded by ChrisFix
How to correctly gap a spark plug. This is a fast and easy video on how to gap a spark plug and spark plug gap ...
FAQ: Find My Engine Spark Plug & Gap ' Briggs & Stratton
www.briggsandstratton.com/.../identifying-the-correct-s...
Briggs & StrattonFollow this step-by-step image guide to locate spark plugs in different Briggs & Stratton engine types. ... Spark Plug Type & Gap Chart for Briggs & Stratton Engines. Now that you've found the part you'd like to replace, you can use the chart below to identify the genuine Briggs & ...
Spark Plug Gap - AutoZone
Dec 15, 2015 | Cars & Trucks
Ngk spark plug gap for 2005 hummer h2
check Gap: .040
Bosch Spark Plug: Part Number: 18594-05120685
PLATINUM -- Original Equipment is Iridium. Gap is Preset
OE Fine Wire Platinum -- Do Not Gap, Gap is Preset
OE Fine Wire Iridium -- Do Not Gap, Gap is Preset
Sep 22, 2013 | Spark Plugs BR4HS Plug 10/BX #3322
Need do know the spark plugs gap
If you're replacing the spark plugs in your car engine, you'll need to set the gap before reseating the spark plug. The gap is the distance electricity arcs between the ground electrode and center electrode. The gap must be set correctly to ensure maximum performance. Here's how to set the gap of a spark plug.
  1. Remove the spark plug wires. Use a socket wrench to remove the spark plugs from their chambers.
  2. Clean the spark plug if you are not replacing it with a new one. Remove all dirt and debris from the spark plug.
  3. Check the owner's manual for your car (or any appliance with spark plugs) to find out the recommended gap setting.
  4. Use a gap tool to check the gap of the spark plug. Slip the tool between the ground electrode and center electrode. The gap tool should fit snugly at the recommended gap width indicated on the tool.
  5. Push the tool between the electrodes a few times to ensure proper gap. If the gap is too wide, push the ground electrode firmly against a flat surface to narrow the gap and then check again with the gap tool.
  6. Repeat Step 5 as necessary until you reach the correct gap. Reseat the spark plug and reattach the spark plug wires
Good Luck
Dec 10, 2010 | 1997 Pontiac Grand Am
How to fix my Ryobi Wipper Snipper - Model# RLT30CD? Hi, I having been using the bump feed and all of sudden its not bump feeding. What should i do about fixing this up? Cheers Clint Baird
You may have dirt in the spool, keeping the line from feeding. Or, the string is slightly tangled on the spool, not allowing it to feed properly.
Jim
Nov 26, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Spark plug gap
Notice: This engine has aluminum cylinder heads. Do not remove the spark plugs from a hot engine, allow it to cool first. Removing the spark plugs from a hot engine may cause spark plug thread damage or cylinder head damage.
Gap the spark plug, using round wire type spark plug gap gage.
Gap Adjust the spark plug gap to 1.14 mm (0.045 in).
DO NOT coat the spark plugs with anti seize compound. Over torquing could occur and damage to the cylinder head threads may result.
If your going to use Platnum plugs, DO NOT GAP them. Just check the gap and if there not the right gap, ask for new one's with the right gap.
The metal on the PLatnum plugs, are harder and my break apart in the cylinder .
Good luck and hope this helps
May 02, 2009 | Pontiac Sunfire Cars & Trucks
Which reel for trimming
Your instruction supplied with your trimmer gives you the information you need. It will recommend which size string to use. Both reels should use the same string.
Nov 30, 2008 | Ryobi Garden
Plug gaps
Manufacturer Spark Plug Gap A spark plug part number might fit hundreds of engines and although the factory will typically set a gap to a pre-selected setting this gap may not be optimum for your particular engine and may not take into account modifications that you may have made to the engine. Spark Plug Gap – Bigger is Better The larger the spark kernel that is generated by a spark jumping the electrode gap, the more likely and complete the fuel burn will be, and the smoother the engine will run. That is, the larger the spark gap that’s exposed to the air/fuel mixture, the easier it is to initiate combustion. This translates directly into improved throttle response. So, the larger the plug gap you can run (without misfires) the better. Unfortunately, the greater the plug gap, the higher the voltage requirement to jump the gap. The difficulty lies in that, any added gap creates more strain on the other ignition parts. Coils, for example, may not have enough stored energy to cross the gap, creating a misfire. Old plug wire insulation can break down at the higher voltages required to fire a larger gap. The stock Ducati coils are good enough to fire a 0.044-inch plug gap. Any gap larger than this will likely result in more misfires (there’s always a few) and subsequent power loss. The correct new plug gap is specified at about 0.024-inch (0.6mm). But, remember, as a plug wears, the gap opens up further. If you use conventional sparkplugs, start with the recommended gap and try opening the gap up in 0.002-inch increments. You should note a progressively smoother throttle response if not more power. When the bike begins to lose power, go back 0.001 - 0.002 inch and this will be your optimum gap. I don't know offhand what the DCPR8E plug comes pre-gapped at but as a good rule-of-thumb, if you go more than 0.008 inch over the out-of-the-box gap you won’t maintain parallel surfaces between ground and the center electrodes. So if you reach that point, change to a plug that starts at a larger gap. The NGK dash 9 series starts at a 0.9mm (0.035-inch) gap, and is used for that reason. If you run iridium or platinum electrode plugs, start with the 0.035-inch gap that they are shipped with. Don't run them at smaller gaps or you'll loose throttle response. If you have a older bike, you may arc over the plug wires before you can reach the optimum plug gap. If the spark plug wires have inadequate insulation, the wire cannot maintain a high enough voltage across the insulation and will arc to ground before firing the plug gap. The factory spark plug leads are stranded wire covered with an EPDM jacket and although the wire itself will last a long time, the jacket will start to break down after a couple of years which is why most good aftermarket wire is insulated with silicone rubber. If this is the case, replace the stock spark plug wires with a set of Magnecor or similar quality wires. This will allow running a larger plug gap without a concern for insulating the higher voltage needed to jump the gap. Ducati 916 Magnecor #2549 wires, for example, run $67. Ignition Amplifiers Running a larger gap is the main benefit of installing an ignition amplifier, such as the one sold by Evoluzione for Ducati's. The Evoluzione ignition amplifier increases the primary voltage to the stock Ducati coil from the existing battery voltage to either 16 volt or 18 volt (user selectable). A higher primary voltage means you get a higher secondary voltage applied to the wires and plugs. The higher the secondary voltage - the larger gap it will jump across. Evoluzione recommends that for best throttle response, you run a 0.060 inch plug gap. One reservation that I have about ignition amplifiers as a group is that they could possibly cause overheating and eventual failure of the stock coils or wires. This reliability consideration has to be balanced against improved performance. An independent test by Road Racing World magazine on a GSXR 1000 saw only about a 0.2 HP improvement, but throttle response is the major benefit.,,,
Nov 10, 2008 | 2008 Buell XB12XT
Plug gaps
Nov 10, 2008 | 1999 Bimota SB8R
Garden Logo
21 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
