Question about Flotera Contemporary Citta Island Range Hood
Where do i find replacement light bulb for flotera island range hood
Need electronic transformer model dlq2001s please advise where i can buy it
hi, could you buy the item you looking for? I am also looking for the same item.
May 07, 2015 | Flotera Contemporary Citta Island Range...
Anybody know about flotera range hoods?
Flotera would be a good source of information.
Jun 08, 2014 | Kitchen Ranges
How to change the light
There are three different models... two wall models (the WL24 and the WL36) and an island model (the IS24). The instructions for changing the lights on all three models are the same.
Light bulb:
  • Make sure your hood is disconnected from the main power supply.
  • You may see a screw at the edge of the light cover. Unscrew it and remove the light cover.
  • Replace the light bulb with the same model as the original. There may be a decal near the bulb that indicates its rating. Don't exceed 25 watts! It's best to bring the old bulb to your store to have it replaced exactly.
Spotlight:
  • If you don't see a screw, then - using a screwdriver - lever the support ring, then grasp it & pull it straight down and off. This ring supports the glass cover - remove it as well (don't drop it!).
  • Replace the lamp with the same type (12V, 20W, G4 fitting).
  • Replace the glass cover and the support ring - it should snap back in.
Fluorescent light:
  • This needs to be changed by a qualified installer. Don't attempt it yourself.
Mar 02, 2011 | Futuro Altair Kitchen Hood
Can I put a 35 watt bulb into a Rangehood?
Yes it will possibly just be a little brighter... but should do no harm. The original 2 would equal 25 Watts the replacement 35 Watts.. the 5 Watts in neither here nor there.
Jan 31, 2010 | Kitchen Ranges
I'm trying to change a light bulb in napoli zepher hood. I can't seem to unscrew the old bulb....what do I do now?
Standard bulb? Make sure the power is off. Put on a glove and keep trying. If you end up breaking it, try a screw driver into the base. No luck, you can get a replacement lamp holder at a appliance parts or hardware store. I have a tool designed to remove the broken base, but that does you no good and I dont know if they are made any longer. I got mine in '64.
Your lamp has been in so long, it baked itself into the socket (grease, etec)
Oct 26, 2009 | Zephyr Island Hoods: Napoli Island Hood
Hi my Kuppersbusch fan is not working. Is this common, any suggestion?
My extractor hoods lights have stopped working(2X 20W). I've replaced the bulbs with new ones but no joy!
Any suggestions?
Carl Dally
Oct 23, 2009 | Kuppersbusch K IKD12250.0E Island Range...
Miele DA270 Vent Hood Light Bulbs
I just bought two at Home Depot for around $7 each. I, too, saw the inexpensive internet ones and decided to spend the extra money and look at them first. I bought bulbs by Philips, called Desk & Cabinet (for enclosed bulbs). They are 20W and 12 volts as you said. It's a G4 Base T3. Now that I have these, I'll likely buy the cheaper ones next time.
Mar 24, 2009 | Miele 90cm Decorator Island Hood - Vented...
Flotera Contemporary Citta Island Range Hood Logo
161 people viewed this question
Top Flotera Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Flotera Kitchen Range Expert? Answer questions, earn points and help others
