Ricoh sc670 I have an mp301spf with sc670-00. I've replaced both the controller and bicu and still have the same issue.
  • 114 Answers
SOURCE: I turn on my ricoh aficio 2027 this code SC670
670 D Engine response error After powering on the machine, a response is not received from the engine within 30 seconds. • SBCU installed incorrectly • SBCU defective • Controller board defective
You can try to reseat the connectors on those 2 boards, if that doesnt work you may need to replace those boards.
Posted on Mar 17, 2010
SOURCE: Ricoh MPC 7500 - SC670 We are getting SC670. Can
sc 670 on ricoh MP 1600
Posted on Dec 10, 2010
  • 903 Answers
SOURCE: ricoh mp6500 sc670 error code
sc670 is an engine startup error. A lot of times if you reset the copier (turn it off with the orange switch on the left side of the front cover, then turn it back on) the error will go away. If it doesn't the BCU board may need to be replaced.
Posted on Mar 19, 2011
santosj27
  • 263 Answers
SOURCE: My Ricoh 3350B copier has
Hello!
This error meams that you have a communication error modem.
This may happened after a instalation. Did you install a new fax board?
Make sure that the fax board are well instaled. It have a jumper that needs to put it ON.
If this does not helps reply to me and give more info.
See you!
Posted on Jul 17, 2011
  • 44 Answers
SOURCE: Ricoh (Aficio) 1224c. code sc670 we
Hi, it looks like a bad controller board. Try resetting it from in service mode with 7807. Also if you can view or printout the error history with 5990-004 for further trouble shooting. Hope this helps
Posted on Aug 06, 2011
I have a Ricoh MP C2500 and it shows SC202 error How do I fix this
Replace your polygon mirror motor or complete laser unit if you have one available. Replace this a.s.a.p as it can cause your BICU to pop. If your machine is already dead and you picked the code up on the web browser you need to replace the BICU as well. Do not replace the BICU without replacing the polygon motor. If you do you will pop the BICU again.
May 24, 2016 | Ricoh Aficio Mp C2500 Color Laser -...
What do I do ? i got code SC981-00 0N RICOH 450e
[SC981] - poor connection between BICU and MSU (HDD controller)[
[SC981]- poor connection bet
Aug 20, 2014 | Ricoh Aficio 450e Black and White Copier
Ricoh aficio 3035/3045 error sc 672 not able to proceed to service mode also, kindly help me pls.
possible a bad operation panel replace or 672 B
After powering on the machine, the
communication circuit between the
controller and the operation panel is not
opened, or communication with
controller is interrupted after a normal
startup.
Controller stall
Controller board installed incorrectly
Operation panel connector loose or
defective
690 A GAVD block I2C bus error
An error is detected in the GAVD
communication I2C control register of
the GABIC2.
I2C bus on BICU defective
691 A GAVD FCI block I2C bus error
An error is detected in the FCI
the GABIC2.
692 A CDIC GAVD block I2C bus error
An error is detected in the CDIC
the GABIC2.
700 B ARDF original pick-up malfunction
After the
Sep 21, 2012 | Ricoh Aficio 3045, 3035 Kit
Ricoh mp6500 sc670 error code
Mar 16, 2011 | Ricoh Aficio AP3800C Laser Printer
Aficio 2045 sc670
engine respond error
fault:
after powering on the machine,a respond was not recived from the engine within the specific time
possible causes:
bicu board
controller board
Sep 03, 2010 | Ricoh Aficio 450 Copier
Sc 144 en ricoh mf1515
Communication Error between BICU and SBU
Symptom:
The BICU cannot correctly establish
communication with the SBU.
Possible Cause:
• Loose connection of the flat cable
between the BICU and the SBU
• Defective flat cable between the BICU
and the SBU
• Defective BICU
• Defective SBU
Sep 03, 2010 | Ricoh Aficio MP1600SPF Copier
Sc 670 aficio 2045
Did you shift the machine recently? If yes check the connectors in the controller and other boards.
Or the boards are not installed correctly.
Worst case BICU board or controller board defective.
Mar 10, 2010 | Ricoh Aficio 1035 Copier
When use adf with letter paper sise, push print botton then askme paper 5 1/2 X 8 1/2 inch´s, why do this?
is there any sensors on the adf unit, if so is the paper being feed into the adf unit, there might be a bad/defective sensor, try placing a letter size sheet on the document glass and make a copy, if it copies you have a problem with the adf, and it needs to be serviced
Feb 19, 2010 | Ricoh Aficio 2018D All-In-One Laser...
In Ricoh aficio 401
The SC360 is Hard disk drive error 1. This means that the machine does not detect the connection signal from the HDD.
CHECK THESE; poor connection between the HDD and the HDD controller,
the AC power connector to the HDD is disconnected,
HDD defective,
HDD controller board defective,
BICU defective.
Make sure all connections are tight and secure, make sure power is connected securely, make sure HDD ( hard drive) is not bad if so replace. If the above are fine, replace the controller board and if the problem is still there, replace the BICU board.
Nov 15, 2008 | Ricoh 6513 Copier
149 people viewed this question
jasbo
jasbo
