Question about Konica Minolta BizHub C252
Replace filter Filter replacement
  • Konica Minolta Master
  • 6,696 Answers
There are two filters which one
Posted on Jan 14, 2016
How to replace filter
Hello! Happy to help with that. To replace the filter simply twist the dirt cup lid off of the dirt cup. Remove the old filter and replace with the new one. Twist and lock the dirt cup lid back on. This vacuum takes a Dirt Devil F1 filter. Follow the link below to purchase the filter directly from dirtdevil.com. Thanks!
F1 HEPA Filter
Aug 11, 2014 | Dirt Devil Featherlite Bagless Vacuum...
How to locate and replace internal filter?? For frigidaire
Good Afternoon Friend,
I understand that you are trying to locate and replace the internal filter for your Frigidaire dehumidifier, model# LAD304NUL. I also see that you cannot find your manual. To locate and replace the filter, follow these easy steps.
a. Remove the filter every two weeks based on normal operating conditions.
b. To remove the filter, remove Bucket then pull filter downwards.
c. Wash the filter with clean water then dry.
d. Re-install the filter, and then replace Bucket.
I have also included the link for your manual, where I found these instructions. Hope this is helpful.
-Best Regards-
WP
Frigidaire Manual Search Results
May 30, 2014 | Frigidaire Dehumidifiers
What I need to do service D on my ML 350 2008 mercedes?
SERVICE B REPLACE CLEANER FILTER, INSPECT SERVICE BRAKE SYSTEM, REPLACE CABIN AIR FILTER, LUBRICATE DOOR HINGES AND LATCHES,REPLACE ENGINE OIL AND FILTER,INSPECT SERVICE EXTERIOR LAMPS, READ CLEAR FAULT CODES, TOP OFF FLUID LEVELS,LUBRICATE HOOD LOCKS, INSPECT SERVICE INTERIOR SWITCHES,INSPECT ADJUST PARKING BRAKE,RESET SERVICE INDICATOR LIGHT,INSPECT SERVICE STEERING AND SUSPENSION, LUBRICATE SUNROOF GLIDES,INSPECT ADJUST TIRES AIR PRESSURE,ADJUST LUBRICATE THROTTLE LINKAGE,REPLACE WINDSHIELD WIPERS.NOW 60000 MILES INTERVALS YOU NEED FLUSH BRAKE FLUID,FLUSH COOLANT,REPLACE FUEL FILTER,REPLACE POWER STEERING FLUID,REPLACE SPARK PLUGS,REPLACE TRANSMISSION FLUID AND FILTER.
May 25, 2011 | Mercedes-Benz ML350 Cars & Trucks
Purchased focus sport 2006 model no service manual. Mileage 43,000 kms. Need to know service intervals either time/mileage perhaps a copy of the service schedule will suffice.
These maintenance intervals come from the maintenance interval calculator
at www.autozone.com, using a starting point of 25,800 miles (43000 km), and
assuming 1000 miles (1666 km) driven per month, and "severe driving conditions," which
are actually normal usage characteristics, such as frequent short trips, urban driving, waiting in traffic, driving in hot weather, trips under 16 km in cold weather, etc.
STARTING MILEAGE: 25800 (43,000 Kilometers)
Item
Action
Service History
20000 miles or 32000 kilometers
Battery Check
Oil Filter, Engine Replace
Engine Oil Replace
Vehicle Inspect
Brakes and Traction Control Inspect
Tires Rotate
21000 miles or 33600 kilometers
Steering and Suspension Lubricate
Engine Oil Replace
24000 miles or 38400 kilometers
Engine Oil Replace
25000 miles or 40000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
27000 miles or 43200 kilometers
Engine Oil Replace
30000 miles or 48000 kilometers
Battery Check
Air Filter Element Check
Wheel Bearing Lubricate
Fuel Filter Replace
Engine Oil Replace
Fluid - A/T Replace
Cabin Air Filter Replace
Vehicle Inspect
Cooling System Inspect
Wheel Bearing Inspect
Ball Joint Inspect
Drive/Propeller Shaft Inspect
Exhaust System Inspect
Steering and Suspension Inspect
Heat Shield, Exhaust Inspect
Tires Rotate
33000 miles or 52800 kilometers
Engine Oil Replace
35000 miles or 56000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
36000 miles or 57600 kilometers
Engine Oil Replace
39000 miles or 62400 kilometers
Engine Oil Replace
40000 miles or 64000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
42000 miles or 67200 kilometers
Engine Oil Replace
45000 miles or 72000 kilometers
Battery Check
Fuel Filter Replace
Engine Oil Replace
Vehicle Inspect
Ball Joint Inspect
Tires Rotate
48000 miles or 76800 kilometers
Engine Oil Replace
50000 miles or 80000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
51000 miles or 81600 kilometers
Engine Oil Replace
54000 miles or 86400 kilometers
Engine Oil Replace
55000 miles or 88000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
57000 miles or 91200 kilometers
Engine Oil Replace
60000 miles or 96000 kilometers
Battery Check
Fuel Filter Replace
Spark Plug Replace
Fluid Filter - A/T Replace
Engine Oil Replace
Fluid - A/T Replace
Vehicle Inspect
Ball Joint Inspect
Tires Rotate
63000 miles or 100800 kilometers
Engine Oil Replace
65000 miles or 104000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
66000 miles or 105600 kilometers
Engine Oil Replace
69000 miles or 110400 kilometers
Engine Oil Replace
70000 miles or 112000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
72000 miles or 115200 kilometers
Engine Oil Replace
75000 miles or 120000 kilometers
Battery Check
Fuel Filter Replace
Engine Oil Replace
Vehicle Inspect
Ball Joint Inspect
Tires Rotate
78000 miles or 124800 kilometers
Engine Oil Replace
80000 miles or 128000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
And you can continue the pattern from there...
May 14, 2011 | Ford Focus Cars & Trucks
Can I just change the pre-filter because it is full of dust and not replace the main hepa filter
Yes, but keep in mind the warranty requirements:
To receive the full benefit from your Defender ®, replace your filters regularly. • Every 6 months, replace your Enviropure® Charcoal Filter. • Once a year (for Perpetual Warranty*)/up to every 3 years (depending on usage), replace your Medi-Filter® Cartridge.
*Refer to the warranty for information on warranty extension(Perpetual Warranty)
Dec 24, 2010 | Filter Queen Defender Air Purifier
Can I just replace the filter or I must replace
YOU CAN JUST REPLACE THE FILTER BUT THIS FILTER IS MADE TO LAST THE LIFE OF THE PUMP, I WOULDNT REPLACE IT, THIS IS A STRAINER TYPE FILTER, ITS NOT LIKE THE OLD PAPER TYPE ITS MADE TO LAST , THE ONLY TIME TO REPLACE IS WHEN REPLACING THE PUMP, I COULD SEE IF YOU HAD OVER 100,000 MILES ON IT AND IF THATS THE CASE THEN YOU SHOULD REPLACE THE PUMP[ WHILE YOU ARE AT THE TANK. HOPE THIS HELPS.
Dec 12, 2010 | 2000 Chrysler Concorde
How often should I change the Transmission fluid, normal driving ? Thank you Gary
It's listed in your owner's manual. Schedule A is normal driving conditions.
SCHEDULE "A"
7,500 miles (12 000km) or at 6 months
- Change engine oil.
- Replace engine oil filter.
15,000 miles (24 000km) or at 12 months
22,500 miles (36 000km) or at 18 months
- Inspect front wheel bearings.
- Inspect brake linings.
30,000 miles (48 000km) or at 24 months
- Replace engine air cleaner filter.
- Replace spark plugs.
- Drain and refill automatic transmission fluid and filter (4.7L).
37,500 miles (60 000km) or at 30 months
- Drain and refill automatic transmission fluid and filter (5.2L/5.9L).
- Drain and refill transfer case fluid.
45,000 miles (72 000km) or at 36 months
- Flush and replace engine coolant at 36 months, regardless of mileage.
52,500 miles (84 000km) or at 42 months
- Flush and replace engine coolant if not done at 46 months.
60,000 miles (96 000km) or at 48 months
- Replace ignition cables (5.2L/5.9L).
- Inspect PCV valve, replace as necessary.
- Inspect auto tension drive belt and replace as necessary (5.2L/5.9L).
- Drain and refill automatic transmission fluid (4.7L).
67,500 miles (108 000km) or at 54 months
75,000 miles (120 000km) or at 60 months
- Drain and refill transfer case.
- Flush and replace engine coolant if it has been 30,000miles (48 000km) or 24 months since last change.
- Inspect auto tension drive belt and replace if required.
82,500 miles (132 000km) or at 66 months
90,000 miles (144 000km) or at 72 months
- Inspect auto tension drive belt and replace as necessary.
97,500 miles (156 000km) or at 78 months
105,000 miles (168 000km) or at 84 months
- Flush and replace engine coolant if it has been 30,000 miles (48 000km) or 24 months since last change.
112,500 miles (181 000km) or at 90 months
120,000 miles (192 000km) or at 96 months
Thanks for using FixYa -a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 05, 2010 | 2001 Dodge Durango
2002 kia sedona, can you replace the fuel filter without replacing the fuel pump
the fuel filter is inline with the fuel line in front of the fuel tank. Inside the tank is a sock that filters the fuel in the suction pipe to the fuel pump also That sock filter is always replaced upon replacing the pump only.
Apr 18, 2010 | 2002 Kia Sedona
Replace Fuel Filter on 2006 Chevy Aveo Hatchback
If the fuel filter is mounted inside the fuel tank at the pump it does not need replacing and is a permanent filter. All you have to do it follow the fuel lines from the fuel tank to the engine. If the filter is mounted in the fuel line you will find it.
Dec 10, 2009 | 2006 Chevrolet Aveo
Please explain the correct location of the 1999 (4x4) Rav 4 fuel filter and the replacement instructions for this filter using standard / non-specialized tools. I have to get this up and running quickly...
The main questions are: Is your Rav running bad? Is the check engine light on? More often than not, the fuel filter is the LAST thing you would need to replace if the veh is running poorly. That being said, and if you really want to replace the filter, expect to have to replace the fuel line from the tank to the filter. It is common to find that when you removbe the filter, the male lines from the delivery line stay IN the female threads of the filter. This is NOT EASY.Don't fool with the filter until you have exhausted all other avanues. Replace the filter ONLY if you have got a load of really, really bad fuel.
Jul 29, 2008 | 1997 Toyota RAV4
Konica Minolta BizHub C252 Logo
23 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
