Question about Vehicle Parts & Accessories
Drivetrain noise on a 99 expedition - Vehicle Parts & Accessories
I have a 99 blazer 4x4 it is humming in he rear end we had the rear bearings n seals changed new diff cover new fluid and it is still humming what is it??? PLEASE HELP!!!
99 Blazer driving hum,noise - Blazer Forum - Chevy Blazer Forums
blazerforum.com > ... > Steering, Suspension & Drivetrain
Dec 31, 2007 - 99 Blazer 4x4 has constant noise-humming that occurs non-stop and increases and ... Sounds like it is coming from rearend but not 100% sure. 99 LT 4x4 Rear End Whine
Nov 5, 2013
7-5/8 or 8.5" ring gear?
Jan 16, 2012
99 Jimmy 4x4 humming noise
Dec 24, 2009
More results from blazerforum.com
Sep 30, 2015 | Cars & Trucks
I have a 99 ford expedition eddie bauer 5.4 v8 4x4 & everything has been running perfect I had my oil changed within a week a knocking noise where the engine is started not sure if its belts or rods?
Histart the car while you look under the bonnet for the noyse,
you can get a stepherscope off ebay to make it easyer to pin point the noyse,all the best.
Apr 28, 2015 | 1999 Ford Expedition
I have a 1997 ford expedition xlt humming noise
your differential has no effect on your rpm range the diff is part of the drivetrain components im not quite sure but this might sound like a bearing starting to go out. Question is is the noise coming from the motor or the differential to figure this out drive the vehical and while it is humming shift it in to neutral if the humming noise is still present then it would be part of the drivetrain. if the noise goes away then you know its the motor making the noise.
Sep 28, 2014 | Cars & Trucks
Will a 1998 licoln navigator transmission fit a 1997 ford expedition
call a junk yard they will be able to tell if it will cross match
Apr 08, 2014 | Transmission & Drivetrain for Ford...
WHILE DRIVING MY 99 EXPEDITION WHEN I HIT BUMPS I HEAR A LOUD RAGGEDY NOISE UNDER THE TRUCK, IT SOUNDS LIKE METAL PLATES BANGING TOGATHER
I will venture to gues mind you that it is your muffler. You might crawl under there and shake it to see it is loose. Best of luck and please give thumbs up for the guess or at least no thumbs down. Thanks, Raz
Apr 20, 2010 | 2007 Ford Expedition Eddie Bauer EL
99 expedition trans feels like it engages but will not move.fluid level is ok
Check out these things: rear wheels locked up because of emergency brakes coming apart inside rear drum/rotor.
Rear axle broke
4x4 controls switched half on-half off.
Torque converter broke
All of these problems will not make much in the way of noise. You will need both rear wheels off ground and trans in neutral to turn the rear wheels. If they turn its likely the torque converter.
Aug 06, 2009 | 1999 Ford Expedition
Upper engine knock
PULL VALVE COVER INSPECT ROCKER ARMS AT REAR OF MOTOR FOR LOOSE OR BROKE SPRINGS OR ROCKER
Mar 23, 2009 | 1999 Ford Mustang Cobra
Vehicle Parts & Accessories Logo
13 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
