Question about Smeg FA311X Top Freezer Refrigerator
Smeg dishwasher fault - stops mid cycle.
My SMEG DF 612 SE dishwasher has flashed a fault code. From the manual: E6 "The appliance is not able to pump out the water from the tank". There does not appear to be an obvious blockage in the machine or the outlet pipe. Subsequent washes have either finished but left a residue that looks like an absence of rinse aid or it has just 'stalled' during the cycle and left all the lights on. Any ideas? Thanks
SOURCE: Smeg dishwasher
Hi, You can download SMEG dishwasher manuals from here: http://www.smegtech.com/site/smeg/myapp/libretti/index.php?lang=EN Al.
Posted on Feb 10, 2007
  • 641 Answers
SOURCE: smeg dishwasher problem
Water supply to the dishwasher is done through an electromagnet valve,loocated at the pipe's enterance to the machine. Test that it get power (with a multi- meter). In case it get power and dosen't work - You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from the machine before doing it !!!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace for a new valve. Good luck
Posted on Jul 20, 2007
  • 641 Answers
SOURCE: smeg dishwasher wash cycle freezes ,
Thanks for the information.
Posted on Jul 24, 2007
  • 69 Answers
SOURCE: SMEG FA550X
Its not possible for water to get in your pump, its a sealed unit, and runs in oil/gas mixture I would look for water in any motor relays, and wiring junction boxes.
Posted on Sep 23, 2007
  • 52 Answers
SOURCE: My Smeg dishwasher DWF 64 SSE won't go onto rinse or dry
Easy one first try this to see if it helps
Water pre-heating
Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Posted on Jan 29, 2008
My smeg Module DF 612 SDX7 dishwasher tripped the circuit last night early into its cycle. We could smell burning coming from the dishwasher. Any ideas and what we can do to fix it?
If you can get it to operate for a few seconds, that will at least tell whether the motor is still good and turns freely. Otherwise it sounds like board may have failed.
Jun 21, 2015 | Smeg Dishwashers
Error 8 light on. I think all lights flash, then far right light stays on. Recently had issues with it. Not emptying properly. How do I fix it??
6. Troubleshooting
In case of a malfunction, the dishwasher will identify the program by switching on a combination of lights.
When an alrm is present, all the PROGRAMS lights (4) come on, while the PROGRAM PHASES lights (7) identify the error code:
E2
The system which limits the water level inside the dishwasher (safety unit) has been tripped.
E3
The appliance is not able to pump out the water.
E4
Temperature sensor disconnected.
E5
The appliance is not able to take in water.
E6
The appliance is not able to pump out the water from the tank.
E7
The appliance is not able to measure the amount of water loaded accurately (on models with turbine flow-regulator only).
E8
Anomaly in the system which distributes water to the basket (where installed).
56
CODE
E9
PHASES LIGHTS
DESCRIPTION
E1
The anti-flooding system (if installed) has been tripped.
The maximum level of water for loading has been exceeded (on models
Jun 02, 2015 | Smeg 18 in. DWD409SS Built-in Dishwasher
Error 8 . How do I rectify it?
6. Troubleshooting
E2
E3
E4
E5
E6
E7
E8
56
CODE
E9
PHASES LIGHTS
DESCRIPTION
E1
Thjere is something wrong with the distribution. Check for blockages.
Smeg dishwasher. Fills but will not run
Sounds like the pump is jammed, the humming is probably from the pump motor.
Oct 29, 2014 | Dishwashers
Smeg D1 612 CA dishwasher wont run
You may have to give a little more information.
Have a look at the manual, here -
http://www.manualslib.com/manual/343502/Smeg-Di612ca.html
and check for error codes/lights etc (p17; faults E1-E9)
Hope this helps
Oct 28, 2013 | Smeg Dishwashers
E6 error codesmeg dishwasher
another tech wrote this previously hope this helps
noavatar_s.gif p57bub
Rank: Apprentice
Rating: 0%, 0 votes
I had this problem and fixed it tonight. When selecting a program water pumps into the machine, but with no drain i ended up with too much water and error code E6.
I traced the fault to a broken wire between the electronic module in the door and the pump. The point at which the door opens and closes on the cables had frayed the insulation and broken through the wire. As this was the live feed to the pump and a potential short from 240VAC to the chassis its dangerous!!
Repairing the wire break and re-insulating fixed the problem
Jul 13, 2010 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
Smeg DI 612 C Domestic Dishwasher
I was told by a SMEG engineer that I needed to replace the detergent dispencer. Just waiting for him to get back with a new one.
Aug 15, 2008 | Smeg 24 in. DWI612 Built-in Dishwasher
E6
Repairing the wire break and re-insulating fixed the problem.
Lee
Dec 10, 2007 | Smeg DWI614 Built-in Dishwasher
Smeg FA311X Top Freezer Refrigerator Logo
109 people viewed this question
Top Smeg Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
Charles T Nevin
Charles T Nevin
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
