Question about Pyramid (PS36KX) 600-Watt Power Supply
Turn on unit beeping light at 16volts won't adjust
Elctrolux dishwasher won't start, display won't light and it randomly beeps
Check continuity of the 4 small wires that connect to the control panel to the control board. They seem to break where they flex for the door to open and close.
Jul 25, 2012 | Electrolux EWDW6505GS Fully Integrated...
We just bought the DE45EJ. We removed it from the box and plugged it in....nothing. No lights, no beeps, no hint of life. The power source is good. The room temperature is normal. The bucket isn't full...
If you just purchased and it won't turn ON, don't waste time trying to fix the unit. Return it to the place of purchase for a replacement unit or a refund.
Thanks for choosing FixYa.
Sep 10, 2011 | Haier 45-Pint Dehumidifier
Hello, I have a Whirlpool dehumidifier Model# AD25USV (recall adjustment already complete) I have never had any technical problems or damages to the unit, and it has worked great, until...
Hello Shane
Mine won't beep at all. But try this trick I watched the guy do when he came to service mine for the recall they had and push Humid button fan button and power button first hold the first two then push the power button and hold all three for awhile. What this did for him was verify all systems working all the lights came one in sequence.
I do this to mine and will beep twice and nothing else. I've taken mine apart to check the fuse and it's still good so there must be a component that is not working.
On the back of your unit you will find a 800 number which will get you in touch with Trans Global Service which serviced it for the recall.
George
Jul 07, 2011 | Whirlpool Dehumidifiers
Red power indicator is lit, this will turn to a blue light with the Insignia logo lit when it comes on unfortunately it will not turn on either manually or with the remote.
Hi:
Have the power supply checked for puffy capacitors that are swollen on their tops. This is a common problem with LCD televisions. The problem is the five volt standy voltage is to low to turn the set on or operate the Micro. These caps are usually valued at 1500u,voltage rating of 10-16volts. some units use 3300uf rated at 10 volts for theirs capacitors. I suggest you use 2200uf rated at 16 volts.
Apr 20, 2011 | Insignia NS-L22X-10A 22 in. HD-Ready TV
Want to turn off the annoying beeping sound every time i push a button on the unit, remote or adjust the volume
Turn the unit off by pressing and holding the volume button till it powers down (NOT VIA THE IGNITION SWITCH!) Once off, press and hold the fuction button (located in the top left hand corner near the volume dial) until unit lights up again and a menu appears, near the end of that menu you can change the beep noises to off like volume or when ignition is off but unfortunatly you cannot change the beep for changing track.
Jun 27, 2009 | Pioneer DEH-P6800MP CD Player
Quit working, unable to turn on unit
replace caps in power supply had same problem. 12volt line week reads around 9-10volts. 2 caps are 1000 at 16v and 47 at 16volts.
Apr 20, 2009 | Televison & Video
Charging Black and Decker Simple Start
First plug the charge adapter into an outlet, then plug into the unit. Push the power button to turn the unit on. Now, push the button for the light. The light should come on. At this point you hit the charge button and the green light should start blinking and there will no beeping. Then turn off the light. The green light should continue to blink and the unit will charge. This worked for me, hope it helps!
Jan 19, 2009 | Black & Decker Simple Start Car to Car...
Re: Won't turn on
your power cable has a short in it. replace it.
May 16, 2008 | Cobra 4000 GPS Receiver
Pyramid (PS36KX) 600-Watt Power Supply Logo
74 people viewed this question
Top Pyramid Computers & Internet Experts
BJ Russell
Jason Morris
Are you a Pyramid Computer and Internet Expert? Answer questions, earn points and help others
