Question about Nostalgia Electrics Helman Group CCP-510 Circus Cart Popcorn Maker
Heating element not working on the ET-POP6A-B
Boite hotmail se connecter
Hotmail support Microsoft Windows Help
Tous les clients Hotmail ont ete mis a niveau vers Outlook.com. Votre adresse e-mail et mot de passe n'ont pas change. Aussi, vos e-mails, contacts, fichiers, elements de calendrier et les parametres sont toujours la.
May 16, 2014 | Fish
Hi, heating element gone I assume. It works well but does not heat up anymore.
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker
Mar 16, 2011 | Whirlpool 24 in. ADG7540 Built-in...
Plasric dish has fused to the element
Use strong kitchen shears to cut away as much of the bulk as you can. Without gouging the round element, scrape it with the kitchen shear blade and run a short cycle. When the drying cycle has run for several minutes (you will smell that the element is heating)
open the DW and again use the shears blade edge to scrape the residual plastic from the element. You may need to repeat to get it all removed.
After you have cleaned it up, do some checking during some loads to make sure the heating element is not being turned on continuously during all cycles. You have not provided the the make/model number, so it is hard to get more specific.
May 09, 2009 | Dishwashers
Working but is not drying, please need manual or schematic
First check your breaker If you tripped one of the sides your element won't work. the motor would run still but if you are only getting voltage to one side of plug it wouldn't work. Check for continuity on your element.Not the problem? Unplug Dryer.!!! Check your element by ohmning it out.Make sure if it is bad to check for blockage in vventing system on dryer and wall.et .
Apr 23, 2009 | Dryers
I believe the heating element has given it up and I need to know if there is an authorized repair center in Amarillo, TX.
Look on the web, chris322. if you don't find a repair center for Breville in your area, try other main brands like saeco, et al. they may laugh & tell you to buy a better machine; at the very least expect to spend a bit to fix it. don't rule out the possibility of a bad knob or loose wire, though. i suggest checking out ebay or craigslist. starbucks barista machines usually go for $200-$250, and if you buy one used face-to-face and it's working, it will most likely continue working for long while. try finding a heating element to replace it, and call around to electrical repair shops to see if they'll put in it for you. good luck to you!
Jan 07, 2009 | Breville ESP8XL Espresso Machine
The lower heating elements do not heat up enough.
Hi sibboah,
Go to
http://prc.prodregister.com/prodprotect/applica/
And click on "George Foreman" (lower-right portion of the page), it redirects you to a secure webpage where you can register.
https://secure.prodregister.com/prodprotect/applica/gf.shtml
Part of the page reads:
"Call toll-free or visit our websites for assistance if you need more help.
Parts & Accessories:
Phone: 1-800-738-0245 (Monday–Friday, 8:30 a.m. to 8:00 p.m., ET)
Product Warranty:
Service: 1-800-231-9786 (Monday-Friday, 8:30 a.m. to 8:00 a.m., ET)"
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Dec 05, 2008 | George Foreman GRV660 Toaster Oven with...
One side will not heat
check your timer board at the back of unit
Nov 27, 2008 | Hobart ET27 4-Slice Toaster
G5 Grill Suggestion
Hi grillkiller,
Without being privvy to the previous conversation, I suspect it was meant that the heating elements are held in-place during normal operation, and due to some problem have become "unseated" - out-of-position and either not-working, or not working right.
If you need replacement parts, I'd recommend going to the Salton, Inc. customer service website.
Go to
Product Warranty:
Jon
Aug 11, 2008 | George Foreman G5 Indoor Grill
Tumble dryer is workin as normal in everyway way apart from it doesnt et hot
You want too reset you breaker 1st dryer will tumble on 110 needs 220 to dry. If still no heat depending on the model you probablly got a bad element or thermal cut out.
Jul 09, 2008 | Dryers
GE GAS DRYER DCLR333ETOWW
Check the vent sometimes if the vent is blocked the thermostat gets false reading.There are some other problems such as thermostat,Igniter,heating element.
Apr 21, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Nostalgia Electrics Helman Group CCP-510 Circus Cart Popcorn Maker Logo
57 people viewed this question
Top Nostalgia Electrics Kitchen Appliances - Others Experts
Robert
Shehu Pro
Shehu Pro
Christopher Smith
Are you a Nostalgia Electrics Kitchen Appliances - Other Expert? Answer questions, earn points and help others
