Question about Carrier 38CKC042 Air Conditioner
I have a 51GR Carrier window air conditioner and the
I have a Carrier window air conditioner and the control panel needs a reset, anyone can help me with that, its a 51GR window AC
  • 1 more comment
  • gh_ahmed Jun 21, 2009
    it acts weird, it shuts down unexpectedly, it goes to worm all by itself, the thing just gone crazy!!
  • gh_ahmed Aug 22, 2009
    now it give me a CC sign instead of the temp!!
  • taa43 May 11, 2010
    why does it need a reset
TRY:
Power off (Disconnect)
Push together "Temp up" and "On/off" and reconnect power while pushing.
Posted on Jun 27, 2009
Just had airconditoner cleaned, now my air does not blow thru the ducts.
Posted on Sep 20, 2009
I have a Carrier Window Air Conditioner that won't cool it blows out hot air. What's the problem? do I need Freoun or what/
Posted on Jul 12, 2009
What is the E4 alarm on carrier ac
If it is window type AC the possible problem is thermistor or PCB itself.Kindly check the pics below if the control panel is the same.
Sep 06, 2011 | Carrier 38CKC042 Air Conditioner
Tip
CARRIER WINDOW ELECTRONIC CONTROL
CONTROL PANEL ERROR CODE
PROBLEM
REMEDY
E4
Thermistor problem
Shutdown unit and restart
E3
Unrecoverable of E2RAM data
Shutdown and unit and restart
E2
Loss or corruption of stored data
Using remote control go to Cool mode and shutdown the system, and then restart.
E1
Code validation check fail
Shutdown and unit and restart.
FL
Filter check warning
Press the “MODE” and (DOWN) “▼” buttons together until error code disappear.
Note: If the problem persist replacement of control board is needed.
-Push arrow up and arrow down together for 5sec. the room temp. will show.
on Mar 02, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier ckc outdoor unit not starting automatically after installation
It is important that the connections from the outdoor unit is wired to align correctly with the indoor unit where the main control panel is located . The outdoor unit compressor is switched on from the processor here and so it is marked in detail to connect the wires.
Now the if the indoor unit is not powering then there is fault in the main control panel and you need to get help as this is a new unit and warranty should not be compromised.
It is possible that the new unit has a damaged control panel or power and so does not power. take help.
Aug 22, 2011 | Carrier 38CKC042 Air Conditioner
My Carrier Weathermaker 8000 a few days ago the air began to blow non stop and the burners are not igniting. I am getting Code 33. I did all the resets, unplug control board, switch to air condition...
You need to look at the wiring diagram pasted on the door panel to get a starting point where to look. I suspect a bad pressure switch, jump it out and see if it starts.
Mar 09, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier 42QG24-C / 38QG24-C 24000 BTU SPLIT AIR CONDITIONER i need to know how to program the remote control.
i want know that how can connection wiring of indoor panel and out door panel 0f carrier 42qg24-c / 38qg24-c ?
(i need wiring diagram)
Feb 09, 2010 | Carrier BCA101R Air Conditioner
The Carrier comfort zone thermostst displays the
Go to panal and reset control. Small reset button on control board. Let me know if it clears.James
Oct 12, 2009 | Carrier 38CKC042 Air Conditioner
Need btu rating ???
Carrier YCB213D Y Series Window Air Conditioner 21000 BTU 230/208V. No Remote Control. High-efficiency energy-saving units. Quiet cooling for living areas.
Please dont forget to rate ;o)
Aug 17, 2009 | Carrier YCB213D Air Conditioner
Reset button
nope but there is a control fuse
Jun 08, 2008 | Carrier 38BRC048 Air Conditioner
Unit/control panel completely dead
Check your circuit breaker, "off" and "on" the breaker it my be tripped off. If it wont work may be some fuse blown in the control, or the control itself may be defective.
Jan 28, 2008 | Carrier 38CKC042 Air Conditioner
Carrier 38CKC042 Air Conditioner Logo
404 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
