Question about Husky 3650 Watt Generator with Subaru Engine
3650 generator won't start!!
My Husky 3650 generator is about a year old and is brand new. It has been started about 3 times and was stored with gas valve closed. Repeatedly tried to start it w/out success. Read trouble-shooting tips; checked spark plug arc for blue spark, made sure switches were on, as well as fuel, choke and that oil and fuel was fuel. Stabil was added to fuel when stored. I don't think engine has even one hour on it. This is very frustrating. I have no idea what this can be. Please help!! Mike
    Novelist:
  • 103 Answers
I assume that the spark plug are good and the gas line is clear. Try to adjust the gas line supply and default engine startup revolution settings try it full half and minimum back and forth it works. Other gen sets requires a mix of oil with its gas, please do it when it is required with exact proportion. Hope this helps. Goodluck.
Posted on Mar 18, 2014
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: Husky 5000 generator will not start
Hi
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and cranking the engine or by pulling the crank rope...watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you may need to replace the electronic module.
Note: If you have to replace the module be sure to measure the position it is in, it is critical to starting.
Take a picture for later reassembly.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
Then follow the procedure below:
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper and or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of sharp instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line/s condition...after a while they will degrade and need replacement.
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel lines from the carburetor be sure to make a drawing or take a picture of how the lines are connected to the carburetor.
Also a good time to take a picture for later reference for reassembly.
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Oct 29, 2012
What kind of oil?
It actually depends on the environment but you will be okay with 10W30
Mar 27, 2016 | Husky 3650 Watt Generator with Subaru...
Husky generator won't start
did you try cleaning the conductor that goes to the spark plug if not try to clean it with a real fine sand paper it should do the job.
Oct 27, 2012 | Husky Portable generator
Centurion 5000 generator won't start after it sets for a month..why?
Maybe this article will be useful for you.
Why Diesel Generator Fail to Start
If you want to know more information about gas generator, this website will be useful for you. Gasoline Generator Set Gasoline Generator Data Supplier Exporter in China
May 23, 2012 | Electrical Supplies
My Subaru backup generator won't start. It started fine last year and ran for about a few days. When I stored it I just shut it off and put it away, didn't add any additives or anything, now it...
you need to take the carburator off and clean it as well as the fuel tank,to start,maybe even a spark plug as well.always use a gas stable additive when you store it,better yet try to get in the habbit of running it once a month
Jun 12, 2011 | Coleman Powermate Subaru 5000W Portable...
I have an ACDELCO 6500 Watt Electric Start Generator. i bought it brand new about 1 year ago and it started up with no problems. Unfortunately I did not drain the gas after using it and it sat idle with...
Fuel will go stale if left for a long time. Drain and clean fuel tank and also drop float bowl on carburettor to remove any old fuel. If there is any sediment in the float bowl a carby clean could also be necessary.
Aug 24, 2010 | BUFFALO ACDelco 6500 Watt Generator...
Looking for a users manual for a gp1kw series gasoline generator ,having a hard time geting it to start.Already install new spark plug and gas.it a 1000 watt 2.4 hp 4-store engine,it about 2 .5 years...
There is a problem with fuel flow or carbueration. I would look for plugged fuel filter (sometimes within the gas tank, or a stuck float level, or possibly even plugged jets..
Apr 03, 2010 | Electrical Supplies
Just won't start
check the spark plug after a failed attempt to start. If dry, then no fuel is entering engine.
Did you leave old fuel in carb? if so, your carb probably is dirty: old gasoline deposits varnish, gum, and you will need to dissassemble carb and clean it.
Nov 14, 2008 | McCulloch 13HP 338 Cc Portable Generator #...
Briggs engine/ genreator
change spark plug and add small amount of starting fluid to breather pull with all settings in proper place if it is going to start it will or you have other problems
Nov 04, 2008 | Coleman Propane Forced Air Heater...
Electrical Supplies Logo
451 people viewed this question
Top Husky Electrical Supplies Experts
Jim Goldsmith
Jim Goldsmith
JOHN LAPIER
Are you a Husky Electrical Supply Expert? Answer questions, earn points and help others
