Question about Olympus FE-310 Digital Camera
Sand in Lens of Olympus Fe-310 Digi Camera?
So I think sand was accidentally kicked onto my camera which resulted in the lens being unable to retract and open. Though the red light turns on when power on/off is pressed and camera makes the noise for the lens to open but it just won't open. As well as the shutter is stuck open. Can I fix it myself, and if so how?
  • 240 Answers
Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera. The following photo illustrates unseated guide pins that would cause a lens error.
or
Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Posted on Jun 14, 2009
My Olmpus fe-360 wont turn on the lens won't retract and it beeps when I try to turn it on
The lens is jammed, which means a gear is stripped or damaged, or jammed in the lens assembly, and the electronic "brain" is turning it off, since it's not in the right position (retracted). This can be caused by the camera getting bumped while the lens was out, dust, dirt, or sand can get in the lens through the front of the camera and jam it, or the batteries could be weak. After you make sure your batteries are good, and it still isn't working, go to this web page and try their suggestions. They report about 1/2 of the cameras with a lens problem can be fixed trying their suggestions. If that doesn't work, don't have it serviced- you can buy a better new camera than what you would pay a service shop.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
The page says "lens error" messages, but it also applies to your problem.
Apr 08, 2010 | Olympus FE-360 Digital Camera
Lens will not close
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Dec 21, 2009 | Olympus Stylus 760 Digital Camera
How do I gain access to the lens mechanism
Google the words...disassemble a digital camera.
Sep 30, 2009 | Olympus FE-230 Digital Camera
Sand in lens of Olympus sp 350, won't open
Bad news, as a camera repairman, I can tell you that even by taking it apart I can't guarnatee getting all the sand out- As Dr. McCoy on Star Trek would say- "he's / it's dead , Jim"
Aug 29, 2009 | Olympus FE-310 Digital Camera
Same exact thing......My mom thinks it needs a new battery.
Hi!
It sounds like your camera lens focus is stuck - could be sand or something in the focus gears - that's the weak spot of these lens. If you can't open the lens and check your lens focus gears yourself, you should contact your local Olympus service center or other camera service center. You can contact me too at toms.safranovs@gmail.com and I can give you a good price.
Hope this helps!
Tom
Jul 29, 2009 | Olympus FE-280 Digital Camera
Olympus Fe-310, lens is messed. Possible sand in it but not sure.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 14, 2009 | Olympus FE-310 Digital Camera
The Beach
You may want to call Olympus Customer Service and discuss their repair process and procedures for sending the camera in to have the lens assembly cleaned. Their telephone number is 800-622-6372 option 2 and then option 3
Jan 09, 2009 | Olympus FE-190 Digital Camera
Lens jammed with sand
This does not get fixed - throw it away and buy a new one.
Aug 03, 2008 | Olympus FE-280 Digital Camera
I got sand in my camera
send to repair... a camera repair person should be able to clean and get your lens back on track
Jul 02, 2008 | Olympus FE-280 Digital Camera
Olympus FE-210 lens does not come out
Hey memiche,
You could try resetting the camera to the default factory settings, and directions on how to do this are on page 20 of your camera manual. If this doesn't work then there is either something obstructing the movement of the lens (i.e. sand), or damage to the lens mechanism. If it is something obstructing the movement of the lens you could try blowing compressed air into the side of the lens to try and dislodge whatever is in there. If that doesn't fix the problem you could try putting the camera on a flat surface with the lens pointing up and holding in the shutter button, and while doing that turn the camera on. If none of this works I would have the camera looked at by an authorized service technician. I have included a link to a PDF download of your camera manual in case you need it. I hope this helps!
http://www.olympusamerica.com/files/FE-210%20Advanced%20Manual.pdf
Sincerely,
Allan
Go Ahead. Use Us.
Jun 30, 2008 | Olympus FE-210 Digital Camera
Olympus FE-310 Digital Camera Logo
323 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
