Question about Sanyo TRC-6040 Desktop Cassette Transcriber / Recorder
The foot pedal is sticking. Will not stop when I want it to stop. Keeps on playing
Motor runs unaided, have to turn off power to stop it
Is the foot pedal not returning to the off position? Try disconnecting the foot pedal. If the machine stops running, then your problem is in the foot pedal. If it keeps running, then your control board is bad.
Mar 19, 2014 | Husqvarna Rose
Have a cub cadet lt 2042. When you take your foot off the forward pedal, unit keeps moving and does not stop. will stop if you hit the reverse pedal. Was told the damper was bad and that has been r
there is a adjustment on the linkage i looks like a triangle shape block with a offset screw on the rear axle near where the rod meets the rear axle move it a little at a time
Jun 08, 2012 | Garden
When I take my foot off the pedal it rewinds farther than it should
Hello on a BM-147 there is only one adjustment responsible for auto back space when you used foot pedal and that adjustment is next to the Display is call Reverse Time that controls the reverse function when you take foot control off from play but if the problem is when you take the foot off on REW and unit keeps going you have a bad foot pedal you can get a replacement at http://www.tvps.com/Products/ECS-Sony-IN-75-Heavy-Duty-Foot-Pedal---Pre-Owned__ECS-PIN-75.aspx
May 17, 2011 | Sony BM-147 Desktop Cassette Transcriber /...
My transcriber keeps going after I take my foot off the foot pedal. Also, the reverse time is not working correctly. I got a new foot pedal, but the problems still exist.
Does your transcriber have a digital display? If so, turn off indexing by holding down both stop and reset together for about 5 seconds. Also turn off the Auto Stop if on.
Dec 15, 2010 | Sony Audio Players & Recorders
Husqvarna 2000 sewing machine foot pedal stuck on but not pressed
you may need to take foot pedal apart and clean it the contacts inside may be dirty and causing it to stick
Dec 13, 2009 | Husqvarna Viking 1
I have a 720. Sometimes when I press play it will rewind.
Hello I can read your full problem but when it hapen unplug your foot pedal to see if the pedal is causing the problem here is a link for a original foot control replacement http://www.tvps.com/Products/Philips-LFH-0210-Foot-Pedal---New__PH-LFH-0210.aspx or just send your unit for service at Send an email to service@tvps.com or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Jun 15, 2009 | Philips Desktop 720-T Desktop Cassette...
Tape completely rewinds when I let off the foot pedal
Make sure the button for back space is not at max is the second button from the right side if problem don’t get fix unplug the pedal from unit and try to play and stop if unit work Ok the problem is your pedal. Needs to be replaced.
Apr 02, 2009 | Panasonic RR-930 Desktop Cassette...
Foot pedal FF or Rewinds when pressing Play
It's possible that there's a broken wire in the cable that connects the foot control to the machine. This usually happens near the plug that plugs into the machine, or by the end that goes into the foot control.
You can usually duplicate it if you put the auto-backspace up a bit and then hold down the play pedal on the foot control. While holding down the play pedal, try moving the cable near the machine or near the foot control in a circular motion. If the machine stops, rewinds or fast forwards, then odds are that the problem is with the cable.
Mar 13, 2009 | Dictaphone 3750 Desktop Cassette...
Foot pedal dead, machine keeps sewing!
There is no suppressor in the foot control of a 425. Only the control unit, which may need to be replaced. If the machine accelerates to full speed, it may have a problem with the "stop right" board which tells the machine whether to stop with the needle up.
You could have several problems, so go see a qualified Husqvarna repairman. You may contact Husqvarna customer service to locate the best one in your area.
Mar 12, 2008 | Husqvarna Freesia 425
Sanyo TRC-6040 Desktop Cassette Transcriber / Recorder Logo
Top Sanyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sanyo Audio Player and Recorder Expert? Answer questions, earn points and help others
