Question about Whirlpool GX5FHDXVY Stainless Steel (248 cu ft) Bottom Freezer French Door Refrigerator
GX5FHTXVQ07 remove the freezer top basket
Have water dripping with no ice maker in freezer
Pull the upper basket out, rearrange food so it does not exceed the top of the basket, then trigger the light switch to make sure there is power going to the freezer compartment.
Sep 29, 2014 | Amana 21.9 cu. ft. Bottom Freezer...
Can i remove the shelves in frigadaire frezzer model frs6r4eq4
Good Afternoon Friend,
I understand you want to know if you can remove the freezer shelves in your Frigidaire refrigerator, model# FRS6R4EQ4. All the shelving in your freezer is fixed, however the bottom shelf, which is located on top of the freezer basket, should flip up to allow more room for tall items that you wish to store in the freezer basket. Hope this is helpful.
-Best Regards-
WP
Jun 14, 2014 | Frigidaire Refrigerators
Er ff
You need to remove the freezer door and basket. then remove the rails on both sides. then there is a panel at the back of the freezer. Pull at the top part of the panel and it will come out.
Feb 07, 2014 | LG LFX21980ST Stainless Steel Bottom...
Bottom basket
Flo,
The manual does not say specifically if the basket can be removed or not, but the basket is on rollers. If you can pull the drawer out and tilt upwards, the basket may release. Otherwise, the basket may not be designed to be removed.
Jan 17, 2014 | Frigidaire 13.7 cu. ft. / 388 liter...
Bottom basket in freezer
Flo Shirley,
I understand that you are having trouble removing the bottom basket in your Frigidaire freezer. To remove the basket, pull out, and lift up. This basket clips in to the actual glides that hold it at the bottom of the basket.
-Best Regards-
Electrolux side by side freezer baskets remove how
Hello augustus_ eli - To remove the top and/or bottom basket, pull the basket(s) out until it stops. Then, lift up on the handle and pull out at the same time to completely remove the basket. To reinstall top and/or bottom basket, align the basket with the rails and push in. The middle basket is held in place by four retainer clips; two on each rail. Before removing the basket, note the location of each retainer clip. To remove the baskets from the retainer clips grasps the handle firmly and pull up. The basket should release from the retainer clips. To reinstalled the basket place the basket on top of the retainer clips and press down.
Nov 27, 2012 | Electrolux EI26SS55GS Stainless Steel ...
How do you adjust freezer basket dividers?
We have a similar, though not identical Maytag/Whirlpool refrigerator with bottom freezer. My comments refer to our specific freezer, it is possible that there is some variance in the freezer baskets. Although it LOOKS like you ought to be able to adjust the divider from side to side, with our basket, you CANNOT. the key is to look at the spacing of the wire pieces that make up the basket body. On ours, the spacing at the center, where the divider is factory mounted, is wider than all the adjacent wire pieces. This means that in locations other than the center, the divider does not fit. We just removed the divider to give more flexible placement of items. To remove the divider I suggest first pulling the entire basket out of the freezer. Take your food out so you can turn the basket sideways, and you will see the clip mechanism that is built-in to the divider itself. You need to use a flat screwdriver or similar tool to flex the inner part of the clip back and then wiggle the divider until it pops free of the basket. Repeat process on the other end of the divider.
Aug 10, 2010 | Whirlpool GX5FHTXTS Stainless Steel Bottom...
Im thinking of buying the MFF225VE bottom freezer but am wondering can you remove the freezer baskets to clean the bottom floor of freezer?
The baskets do come out, there are some tabs that can be depressed on each side and the bins come up. If you want to take the entire drawer out you would need to remove a couple of screws from each side to accomplish this.
Let me know if this was helpful or if you have questions.
Thanks
Jun 14, 2010 | Maytag MFF2258VE Top Freezer Side by Side...
Amana ARB2117BW - Bottom Freezer Door Won't Stay Sealed
This problem was posted in the wrong section. My model didn't have it's own, so its in ABB1927DE Bottom Freezer Refrigerator - perhaps you could create a section for it.
As it turns out, I looked more closely at the baskets inside. We had noticed that if the top basket was slid all the way forward when we closed the door that it would close better. So I looked to see if they or the slides were out of alignment. They seemed ok, but then I saw that the way the bottom basket was hanging didn't seem right - it was not quite nestled into it's retainer slot. I took the baskets out and turned the bottom one around. It fit perfectly into it's retainer slot. I then replaced the top one (it was already in correctly) and closed the door. It sealed correctly the first time. I tested it several times after that and it sealed tightly. Closing the top door did not make it unseal as it had done before.
Jan 23, 2009 | Amana ABB1927DE Bottom Freezer...
Zanussi Electrolux frost free fridge/freezer - freezer defrosting
My husband left the freezer door open a couple of months ago, causing ice to form. The loud rattling noise was the fan hitting the ice. The reason why the temperature started to rise but the noise stopped was because the fan had got stuck in a block of ice and was no longer working. Simple solution - defrost the freezer for 24 hours. Touch wood, it is all working fine now!
Aug 29, 2008 | Zanussi ZI921 / 8FF Bottom Freezer...
Whirlpool GX5FHDXVY Stainless Steel (248 cu ft) Bottom Freezer French Door Refrigerator Logo
23 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
