Question about Kodak Carestream 9000 3D Extraoral Imaging System
Error code -211 - Kodak Carestream 9000 3D Extraoral Imaging System
I keep getting the error code 211. the point is on the red mark at the sde of the machine and everything else in line. but when i start the machine the needles keep getting jammed in the hooks below.
Search for:
Make Model error 211
sometimes the owner's manual will contain information on error codes in the troubleshooting section.
Sounds like the machine may be out of time. Professional service may be required.
Jun 26, 2017 | Sewing Machines
C03ff code coming in bizhub-211 which code should i press
MODEL SETTING ERROR
IN SERVICE MODE-ADJUST-MODEL SETTING
Now choose right model (Like if 211 means 21 PPM so choose 21PPM)
Nov 12, 2016 | Konica Minolta bizhub Office Equipment &...
What does Fault code 078-211 mean on Xerox copier D110?
Found in the Administrator's Guide:
078-210 / 078-211
[Cause] Tray 6 (HCF) malfunction
[Remedy] Contact our Customer Support Center
Before calling, check for paper jam or small pieces of paper in and around Tray 6. There may be a piece jammed around a sensor that is throwing the error,
Mar 17, 2015 | Xerox Office Equipment & Supplies
Bizhub 211 error code 211
Check behind the paper draws for any paper jammed back there . ALSO DO NOT STORE EXTRA PAPER in the draws that extra space is for if the draw is set up for 11x17 paper!!!!!!
Jan 14, 2014 | Minolta Office Equipment & Supplies
Error code 211
how to solve call service for my toshiba e-211 pls reply me . .:(
Jul 15, 2013 | Toshiba E-STUDIO 211C Copier
Riso rn 2030ui error code A01-211
Error type A01: Master feed error Error point 211: Master-positioning sensor in ON during standby.
Feb 25, 2013 | Riso Office Equipment & Supplies
Bizhub 211 error code c500
ihave error code c5oo c501 in bizhub 211
Jan 16, 2013 | Toshiba E-Studio167 Copier
Maintainance call display of konica minolta copier bizhub 211
Maintenance call? from your question it is not clear what is the error code.Please see if there is any code appearing besides maintenance call.Note the error code and tell me again so that i can help you.If it is C0500 or C0501 then press the stop button on the panel and restart the machine do not release the button until the code removes.
Dec 13, 2012 | Konica Minolta KONICA BRAND TN-211 BLACK...
How to solve bizhub 211 code error c0650
bizhub 211 error code C0F32, To solve this code simply replace the developer of the machine.
Feb 17, 2010 | Konica Minolta bizhub C250 All-In-One...
Error 211, 212!!!
Hi Antonyo,
The codes you are getting (211- 212) relate to the boiler tank behind front panel.
210 Temperature probe short circuit Check probe cable (plug contacts)
Replace probe(rinse tank)
Install probe correctly
211 Temperature sensor interruption See 210
212 Actual boiler temperature too high Contactor welded
Incorrect sensor / defective sensor
Check probe / cable (Contact plug II XA5)
Hope this helps ,regards KIT
Jun 06, 2008 | Meiko DV 80.2 Dishwasher
Kodak Carestream 9000 3D Extraoral Imaging System Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
