Question about D-Link DAP-1522 Xtreme N Duo Wireless Bridge/Access Point (DAP-1522/B) Pre-802.11n
New connection of DAP1360 - D-Link DAP-1522 Xtreme N Duo Wireless Bridge/Access Point (DAP-1522/B) Pre-802.11n
Pin
1) reset your browser (internet explorer).
2) connect your access point (AP) to your pc directly using LAN port and CAT5 cable
3) type in default IP address of AP->192.168.0.50 (Or Current IP address of Ap) in browsers address bar.
4) username = Admin and blank password (i.e. password is no text)
5) Click on Advance Button then click on Wi-Fi Protected Setup button on left menu pan.
6) See the image below record your current pin, if you wish to change it just press generate new pin button.
7) Don't forget to say thanks :)
Apr 13, 2013 | D-Link DAP1360 IEEE 80211n (draft)...
Can't configure in repeater mode
Try turning off the WEP and connecting. Are you using repeater mode on your router, or just adding the repeater to your network?
Jan 03, 2018 | D-Link DAP1360 IEEE 80211n (draft)...
Limited acces? How toslove this
Most likely your access point is losing connection with your router. I looked into buying one of these, but decided against it when I saw on some message boards its problem with connectivity. Best thing to do is do a hard reset and then update your firmware to the latest version.
Jul 18, 2011 | D-Link DAP1360 IEEE 80211n (draft)...
I cant get into config my dap1360 by typein in the dlinkap or 192.168.0.50
just make sure that you belong with in the same IP range.
default DAP-1360 IP is 192.168.0.50
username : admin password : <blank>
change your PC IP address to 192.168.0.xxx (e.g. 192.168.0.2)
from there you may choose wizard or manual configuration.
you may change your DAP-1360 IP add according to your network settings in the office and you must change you PC IP address with in the same range.
Mar 24, 2011 | D-Link DAP1360 IEEE 80211n (draft)...
CANNT USE THE DEFULT IP I NEED ANOTHER IP TO GO TO THE AP TO START THE SET UP
PUT LAN CABLE FIRST FROM THE ROUTER TO YOUR PC / LAPTOP. FROM CONTROL PANEL CLICK NETWORK CONNECTION THEN RIGHT CLICK THE CONNECTION THEN STATUS/SUPPORT
YOU CAN SEE DEFAULT GATEWAY COPY HE NUMBERS, OPEN INTERNET EXPLORER
PUT THE NUMBERS CORRECTLY TO IE WEB BROWSER THEN ENTER.
Dec 22, 2010 | D-Link DAP1360 IEEE 80211n (draft)...
My D-Link DAP 1360 seems to drop connectivity as well as slow down 5.5 Mbps - distance 5 m. Works perfect when close-by ie 30 cms - 1m
How many other wireless networks are detected at your location?
It could be interference from those other routers.
Nov 18, 2010 | D-Link DAP1360 IEEE 80211n (draft)...
D-Link DAP-1522 Xtreme N Duo Wireless Bridge/Access Point (DAP-1522/B) Pre-802.11n Logo
52 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
