Question about Dehumidifiers
Kenmore 5751 turns on and shuts off
Why does my 3 week old dehumidifier only flash on and than shuts off ?
This being a dehumidifier it has to be emptied. check the water holding tank, empty it and it should start up again.
Sep 22, 2014 | Kenmore 5230 Dehumidifier
How to repair my kenmore 58054501500
ck the water catch bucket , sometimes ive seen machines stop after running a few minutes because it shook catch bucket from its perch
Jul 16, 2014 | Kenmore Dehumidifiers
My dehumidifier kenmore model 580.52650 is working fine but turn off and turn back on every three minutes it is this dangerous, any solutions ? THANKS.
I think the problem may be caused by the humidity extraction level you have the unit set on. (i.e. It's set to high). Lower the humidity extraction level to 35%. This will allow the unit to run longer and extract more humidity, before it either shuts off, because the humidity level has been reached or the bucket is full and needs to be emptied.
Don't forget, the air intake filter should be cleaned regularly.
Hope this helped you. Please let me know.
Jul 08, 2011 | Kenmore 54501 Dehumidifier
Unit turns on for about a few seconds and shuts off. bucket full light stays on. Micro-switch is ok what else could that be
Possibly., the unit turning ON vibrates the bucket in such a way, that it loses contact with the safety switch and the unit shuts OFF. If the dehumidifier is not sitting level, it would cause the bucket to shake more than usual. In addition, if you haven't cleaned the filter recently, I would suggest that you do that. A dirty or clogged filter causes the unit to struggle and if it is to much to handle, it will cause it to shut OFF. Before you attempt remove the filter, turn OFF the Master ON/OFF Switch and Unplug the unit. Be sure you do it in the order I listed.
Hope this helps you further to troubleshoot and solve the problem.
Apr 08, 2011 | Kenmore 54501 Dehumidifier
Kenmore dehumidifier 54501: Fan does not work. I
Call sears see if the compressor is under warranty
Sep 01, 2009 | LG DH30 GoldStar Dehumidifier
Kenmore dehumidifier 54501 not filling with water
if your humidity level is not highin the house or room you are using it in your humidistat will shut it down try turnning system up to higher setting
Jan 07, 2009 | Kenmore 54501 Dehumidifier
Dehumidifier shuts off after 2 mins
you might have a compressor problem, in which it won't be economical to repair. if you are using the unit in cold weather then it just might be that there is not enough humidity in the air and it is cycling fast.
Dec 04, 2007 | Kenmore 54501 Dehumidifier
Dehumidifiers Logo
24 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
Michael Youngman
Michael Youngman
Are you a Dehumidifier Expert? Answer questions, earn points and help others
