Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Dyson will not start fully only judders - Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
My dyson dc 33 wont start
Hello, this is Ava with Think Crucial.
If your vacuum doesn't turn on, make sure that plug is fully inserted into a fully functional electronic outlet. If it still not turning on after verifying this, it could be that the power switch is malfuntioning. You may need to replace the power switch by opening up the handle of your vacuum. I suggest to refer to your manual on how to replace the power cord or contact Dyson for troubleshooting steps. 1-844-679-1647
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dc33
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Oct 31, 2016 | Dyson Vacuums
I have a stick dyson DC35. It runs out of power after being fully charged. I have cleaned filter and cleaned all parts numerous times, but still have the problem.
The battery may only be capable of partially charging but indicates it is fully charged, something like 100% of 50%. It may be time for replacement.
May 02, 2016 | Dyson DC35 Digital Slim Stick Broom/Hand...
When I try to use my Dyson DC59 it won't start and blue lights on both sides of the battery start blinking. What does this mean?
Hi there, it's Jack at Dyson.
From what you've described, it sounds as if you may be using your DC59 set to Boost mode. This will provide 6 minutes of highest suction for really stubborn dirt, but for regular vacuuming normal mode should work effectively.
To switch back to normal mode, ensure your machine is fully charged (this will take a maximum of 3.5 hours), then hold down the on/off trigger, and at the same time, press the illuminated Boost button on the rear of the machine.
You might also find our Getting started guide useful:
I'm confident this will resolve the issue, but if you would like some further advice from our experts after giving this a try, please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 13, 2014 | Dyson DC59 Animal Bagless Cordless Stick...
Dyson hand held vacuum starts and stops though fully charged
Most Dyson vacuums have a built in safety system that stops the machine if it begins to overheat. This usually happens because the filter needs washing or your machine is blocked. If your machine turns off on its own, unplug it and leave it for at least an hour to cool down. Remember to check the filter and look for blockages before re-starting.
https://www.thinkcrucial.com/search?type=product&q=dyson
Ava B.
Jun 04, 2013 | Dyson DC35 Digitial Slim Multi floor...
My handheld dyson is not working - initially it was cutting out after only a few mins then seconds now it won't work at all despite showing green light ??
I'm sorry to hear your DC31 Animal is only working intermittently. When fully charged, this machine should have a maximum runtime of 10 minutes, or 6 minutes on the maximum power setting.
There are several factors which could cause this, and to determine what's at fault we'd need to take you through some quick diagnostic checks when you have your machine to hand. The machine would also need to be fully charged, so please make sure it's had 3.5 hours to recharge before calling us.
You can reach our freephone customer Helpline on 0800 298 0298 (UK), or 1-866-693-9766 (US). Our experts will be happy to help further.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Apr 07, 2013 | Dyson DC31 Animal Bagless Handheld...
Loss of suction and sounds like motor is juddering after a few seconds use
A pulsating sound from the motor, along with a loss of pick-up performance, will be due to a blockage somewhere in the machine - in the cleaner head, in the wand, or in the bin inlet. For help checking for this and removing any obstructions, please take a look at our online Support guide:
http://www.dyson.co.uk/support/dc35/dc35-multi-floor/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/check-wand
You may also want to take a look at the video below for guidance on removing any threads, hair or other obstructions from the brush bar and cleaner head.
I'm confident this will resolve the issue, but for any further assistance please give our Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Oct 24, 2012 | Dyson DC35 Handheld Vacuum
My dyson dc14 wont turn on
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Jul 04, 2012 | Dyson DC14 Animal Bagless Upright Cyclonic...
My dyson vacuum will not start
If your vacuum doesn't turn on, make sure that plug is fully inserted into a fully functional electronic outlet. If it still not turning on after verifying this, it could be that the power switch is malfunctioning. You may need to replace the power switch by opening up the handle of your vacuum. I suggest to refer to your manual on how to replace the power cord or contact Dyson for troubleshooting steps. 1-844-679-1647
Ava B.
Jun 10, 2012 | Dyson DC14 All floors Bagless Upright...
My Dyson won't start. I hardly used my vacuum and the other day i plugged it in and it didn't turn on. I have a clean container so it is not that it needs emptied. Any idea what I should try?
If your vacuum doesn't turn on, make sure that plug is fully inserted into a fully functional electronic outlet. If it still not turning on after verifying this, it could be that the power switch is malfunctioning. You may need to replace the power switch by opening up the handle of your vacuum. I suggest referring to your manual on how to replace the power cord or contact Dyson for troubleshooting steps. 1-844-679-1647
Ava B.
Jan 20, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
12 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
